Question about Toshiba 40RV525U 40 in. LCD TV
My Toshiba 40RV525U resets it's self everytime I turn it off. When I turn it back on, I have to reset all of the prefernces.
  • lovellt2000 Nov 15, 2010
    Mine does the same thing. It just started doing and I've have this tv for over a year. It has something to do with the HDMI Control.
5 Suggested Answers
SOURCE: toshiba 40rv525u will not turn
I have the same problem. Hopefully someone can tell me what is wrong or I will have to junk it for parts.
Posted on Feb 23, 2011
SOURCE: I have a Toshiba 40RV525U LCD TV. Wondering how to
my tv wont switch from 1080p to 720p while changing chanels. in order to watch 720p chanels I must turn off the tv and turn it back on, then the 720p chanel will come in. it will change back to 1080p if the chanel is changed to a 1080p chanel but not back to a 720p chanels.
Posted on Aug 25, 2010
rulds2008
  • 3866 Answers
SOURCE: Power surge how do I
Many times just unplugging the Tv from the power outlet will do the trick.
Checking the manual on this TV, there is no true hardware reset other then unplugging the TV from the wall, then plug it back into the wall outlet.
Many times TV's that receive a surge would experience damage to a power board or a capacitor inside the tv itself.
The best way to check if its a power board is opening the unit up and verifying if there is any damage. Now if your not good with doing that I would recommend you leave it to a local TV repair shop to check out.
Many times repair shops would take it on consignment and if its repaired there the charge to look at it would be included in the final price.
Judging if its a power board you looking at anywhere from $125-$150 for the part, $80 to $100 for labor. Keep this in mind while your shopping to see if its better to repair or buy a new one.
Thanks for using Fixya.com
Best of luck to you,
Rulds2008
Posted on Jul 01, 2011
  • 181 Answers
SOURCE: I cant get my toshiba
It'll only display a 1080p picture if you're sending it a 1080p signal. As far as I know, HD cable boxes only broadcast in 720p or 1080i. Currently, you'll need to be playing a Blu Ray disc on a BD player, preferably connected via HDMI to get 1080p.
Posted on Jul 18, 2011
How do I reset the volume on my tv?
your controlles on the tv set itself goes faulty simply spray some switch cleaner in buttons should sort you out
Sep 15, 2014 | Toshiba 40RV525U 40 in. LCD TV
Toshiba backlight problems?
Without a remote control, you can't enter its service mode to unlock it. Try to get an original remote control. Contact the authorized service center.
Jul 01, 2013 | Televison & Video
Reseting a toshiba tv
Going to need an original remote for this and NOT a universal.
Google the model number for an original remote.
Mar 21, 2012 | Toshiba 40RV525U 40 in. LCD TV
My toshiba 40RV525u flat TV is muted, the tv seems like it controls itself when i go to Menu (selection flashing nonstop). I tried to turn up the volume, but it turned off itself. the entire problem is the...
Do a hard reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 27, 2017 | Toshiba 40RV525U 40 in. LCD TV
if it is with hdmi input call toshiba--free software upgrade
Jul 12, 2010 | Toshiba 40RV525U 40 in. LCD TV
Resets by itself to factory settings at least once every day. also will not hold favorites list once tv is turned off.
Unplug it, press and hold the power button down for 30 seconds, plug it back in and turn it on.
Jan 06, 2010 | Toshiba 40RV525U 40 in. LCD TV
No sound with HDMI cable and Xbox 360
FROM THE TOSHIBA MENU, (FIRST MAKE SURE YOU ARE SET TO
THE HDMI PORT THAT THE XBOX IS PLUGGED INTO) THEN SELECT
HDMI SETTINGS, UNPLUG HDMI CABLE FROM THE TOSHIBA TV (LCD
FLAT, MINE IS A 42") WAIT FOR THE SETTINGS TO HIGHLIGHT OR NOT
BE GRAYED OUT, THEN TURN OFF THE THREE SETTINGS, FOR COLOR
AND LIP-SYNC., SCROLL DOWN AND PRESS THE RESET BUTTON,
WAIT FOR MESSAGE TO APPEAR. TURN OFF THE TV AND PLUG IN THE XBOX.
TURN EVERY THING BACK ON. SEE IF IT WORKS.
NOT ALL CABLES ARE THE SAME AND NOT ALL TVS ARE THE SAME.
READ THE TV OWNERS MANUAL CAREFULLY, (RTFM), I FOUND A NOTE ABOUT
THESE SETTING ON THE SPECIFICATIONS PAGE.
Mar 26, 2009 | Toshiba 40RV525U 40 in. LCD TV
TOSHIBA FLAT SCREEN TV has black screen but power light is on!?
Try resetting the TV by leaving it unplugged for an hour.
Plug it back in and check to see if it works normally.
If that doesn't work, rule out the Directv box by pressing the reset button near the access card. The box could be putting out a signal that doesn't have video or audio.
If everything fails, have the tech man come back to check everything that he did before you use the warranty on the TV.
Feb 20, 2009 | Toshiba 40RV525U 40 in. LCD TV
Toshiba 40RV525U 40 in. LCD TV Logo
394 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
