Microsoft Windows XP Home Edition Logo
Posted on Nov 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to print scandisk report? - Microsoft Windows XP Home Edition
Anonymous
Level 3:
  • Master 2,296 Answers
  • Posted on Nov 12, 2010
Anonymous
Master
Level 3:
Answers
2296
Questions
0
Helped
833128
Points
6040
1. When report comes on screen, hit Prt Scr button on the keyboard.
2. When in Windows, open Paint and click Edit -> Paste.
3. Save as... and there is your image.
Sharp FO-4400 Manual
Setting 05: TRANSACTION REPORT PRINT SELECTION
This sets the condition for printing out a Transaction Report. Enter a number
from 1 to 5 as follows:
1 (ERROR/TIMER MEMORY): A report will be printed after an error, timer
operation, or memory operation.
2 (SEND ONLY) A report will be printed only after a transmission
3 (ALWAYS PRINTS) A report will be printed after each
transmission, reception, or error
4 (NEVER PRINTS) A report will never be printed.
5 (ERROR ONLY) A report will be printed only after an error occurs
My laptop keeps saying that i need to backup because my c drive needs repair what do i do
ScanDisk is a Windows utility which detects and corrects errors. Windows XP introduced a significant change to ScanDisk. The utility was integrated into the operating system. You should run ScanDisk whenever you notice a hard drive is not performing well and also on a regular basis to fix errors as soon as they happen.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions
  1. 1 Open "My Computer" in Windows XP.
  2. 2 Find the icon for the hard drive you want to run ScanDisk on. You can run ScanDisk on the system's primary hard drive and also on any secondary hard drives or external hard drives. Right-click on the icon for the hard drive and select "Properties."
  3. 3 Choose the "Tools" tab from the hard drive properties window. The ScanDisk utility can be activated from the Error-checking box at the top of the Tools tab. To begin, click the "Check Now" button.
  4. 4 Note the two check boxes displayed. You will want to choose the "Automatically Fix File System Errors" box. This will perform a basic fast scan of the drive, which will take only a few minutes.
  5. 5 Put a check in the "Scan for and Attempt Recovery of Bad Sectors" box for a more thorough scan. With this checked, Windows XP will take 10 hours or longer to run ScanDisk depending on the size of your hard drive. Run this if you have noticed a problem with the hard drive's performance. For regular checks, run the basic check most of the time and the longer check only occasionally.
  6. 6 Hit the "Start" button to start ScanDisk.
  7. 7 Wait for Windows XP to finish running ScanDisk and view the report. ScanDisk will tell you what errors it found and fixed. Click the "Close" button when are finished viewing the report.
Read more: How to Run ScanDisk in Windows XP ' eHow.com http://www.ehow.com/how_2126653_run-scandisk-windows-xp.html#ixzz1BXNDbxHd
I did a complete recovery on my computer and it was taking two days. It kept saying, 'applying setting " but never did So I turned the computer off. What should I do know.
1helpful
My HP 1040 fax prints a sending confirm notice after every fax is sent. Is there a way to turn this feature off as it is a major waste of paper.
Reports you can print
You can print these reports whenever you need to. Some of these reports can be set to print automatically also.
1. Press Report/Help.
2. Choose the report you want by using left or right arrow.
3. Press Start/Enter when the desired report is displayed.
4. The selected report will be printed.
Sending Confirm
A confirmation report shows whether the transmission was successful or not,
how many pages were sent, etc.
ON: prints a confirmation report automatically each time you send a fax.
OFF: never prints a confirmation report (You can print one manually using the
Report/Help button (see Print reports on page 51).
ERROR: prints only when an error occurs.
How to print auditron report (copy) from workcentre pro 128? Need step by step instructions- have no manual
Printing Service Reports
1. To access Service reports, follow the Entering UI Diagnostics procedure.
2. After entering the Access Number, press the Machine Status button on the Control
Panel.
3. Select the Billing Meter/Print Reports tab on the display.
4. Press the Print Reports/List button.
5. Press the CE button.
6. The following reports can be printed.
• Debug Log Report
• HFSI Report
• Jam Report
• Shutdown Report
• Failure Report
• Protocol Monitor Report
7. Select the required report and press the Start button. The selected report will be printed.
My 225GB hard drive has suddenly gone from 25GB used to full. What's going on?
Sounds like your OS is mis-reporting the actual HD space. Run scandisk, or of you have a Bootable recovery disk, boot with that and run the command "chkdsk /r"
4helpful
How can I print a fax confirmation on a specific outgoing fax
Checking a report for the transmission result (?TX Report? function) A report containing the transmission results can be printed. The machine can be set to either print or not print the transmission report or to print it according to the machine setting or only when a transmission fails. To print the transmission report 1 Press the [Fax/Scan] key to display the Fax mode screen. 2 Touch [FAX Menu]. 3 Touch [TX Report] on the Set 1 tab. 4 Select how to output the report, and then touch [Enter]. ? Default: The transmission report is printed according to the previously specified method. For details, refer to ?Specifying report output settings (Report Settings)? on page 10-48. ? ON: The transmission report is printed with each transmission. ? If TX Fails: The transmission report is printed only if the fax could not be sent. ? OFF: The transmission report is not printed, regardless of the transmission result.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Scandisk cruzer micro 8Gb
Don't mess with that , microcircuits are not to be tampered with unless you know exactly what you're doing and have all the nessessary tools and a clean room.
if it's not broken don't fix it.
How to print a fax report
Printing a report
Press Menu until System Setup appears on the bottom line of the
display and press OK.
2 Press the Scroll buttons until Report appears and press OK.
3 Press the Scroll buttons until the report or list you want to print
To print all reports and lists, select All Report.
4 Press OK when Yes appears to confirm printing.
The selected information prints out.
Other available reports(CLX-3160FN only)
Your machine prints the following reports automatically or depending on
your setting.
Multi-communication Report: prints automatically after sending
faxes from more than one location.
Power Failure Report: prints out automatically when power is
restored after a power failure if any data loss occurs due to the power
failure.
Disk crash data recovery
its time for a data recovery operation. you'll want to find someone nearby, as this is a 50/50 effort at best.
got backup?
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
