Question about Toshiba Satellite Pro L300 Notebook
I have pluged for charging the laptop in 32 amp socket and after some time the laptop stoped working and it is not switching on. can i know what could be the resoan for not working or damge and how can i get it reparied and at what cost. george
  • 2,296 Answers
1. Take the battery out, drain the power out of the laptop, put battery back in place and see if it turns on.
2. If that doesn't fix it, open it up get a measurement unit and see if you have any power on the mother board. If no power, mobo might be gone.
Posted on Nov 12, 2010
Plugged into mains, says 'plugged in, charging' 34% activates for about 20 seconds then stops. Never gets above 34%
will your pc run with it just pluged into the mains with out the battrey in? if it does then it could be your battrey stoping it from running.
Mar 29, 2015 | Computers & Internet
Wont switch on
POWER SUPPLY & BATTERY PROBLEM
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 20, 2012 | eMachines Computers & Internet
Lenovo g410 not charging
This is going to be one of three things either your power supply is not giving out enough voltage to charge the battery, have you tried another psu?
If its not the psu then it could be the dc socket being loose on the mainboard or the fuse which controls the charging section has blown which means you need a replacement mainboard. Usually its either the charger or dc socket
Mar 23, 2012 | Computers & Internet
I HAVE A 4736Z LAPTAOP .MY PROBLEM IS WHEN I CHARGE THE LAPTOP THAT TIME SHOWS CHARGING WHILE A SECOND THAT GONE CHARGING IS STOPED THAT TIME SHOWED POWER LIGHT AND LAPTOP CHE]ARGING LIGHT BLINKING...
Hi there charge the battery first then go in control panel and make the power setting. Make sure the low battery time make long & others too. After that if you face the same problem then its a time to change the battery & buy a new one. Thanks.
Dec 06, 2010 | Acer Aspire 4730-4947 Notebook
My hp 6735s laptop battery not charging says pluged in but not charging only 1 year 6month old
r u getting the message when on AC power that the "smart AC adapter is not providing enough power" ?? If yes then remove the battery and c if the laptop works fine with just the adapter plugged in ...
if yes then take power cord out of the adapter from the end that goes to the wall socket .. that side is removeable ..then plug it back in and flip the way its plugged into the wall socket .. c if this helps ..
Oct 22, 2010 | HP Computers & Internet
Help, Toshiba Satellite M35X-S111 laptop has stoped charging the battery. The light stays orange no matter how long its pluged up. You have to move the plug around to get it to power, I had it checked by...
what is the age of the laptop?
How old is the battery?
Try this...
1. Check/test the battery
2. Test the charger.
One of these seems to be the problem...
Jeff
Oct 25, 2009 | Toshiba Satellite M35X-S111 Notebook
Laptop will not turn on or charge?
If the battery is fine, then the only other power source is the power adapter cord. You'll have to borrow/buy one and make sure the wattage which is on the square part of the adapter matches...if you have any questions let me know..
Apr 27, 2009 | Fujitsu AMILO PC Laptops
Mainboard shutdown
Never do that to fuses, search the web (especially the site of your laptop's maker) for common cures to your situation, and failing diagnosis recommending a particular cure, don't do stuff at random.  That sort of thing sort of sounds like a battery issue; won't the thing come on with no battery, but the power power connected?
Sep 10, 2008 | Intel Motherboard
EVO n600C NOTEBOOK battery not charging.
1. Check the socket u pluged it in
2. have the charger tested for continuity.
Mar 14, 2008 | HP Compaq Evo Notebook N600c
Toshiba Satellite Pro L300 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
