Question about Kenmore 44042 Front Load Washer
Kenmore Front Load Washer Model 402.4903 powers up and starts and then all power shuts off in less than a minute. Electrical breaker is not thrown.
SOURCE: kenmore front load washer he2plus
The machine has to be level
Posted on Jan 29, 2008
  • 1028 Answers
SOURCE: KENMORE Elite HE 3T
no but there is a control bd it is probably gone
Posted on Jul 31, 2008
SOURCE: My Kenmore Elite front loader has no power.
the power is on but the start button does not start the machine
Posted on Jun 30, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a Kenmore Elite model 110.45872 402, front
To replace the door bellow on a Whirlpool Duet front loader, the following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear on the bellow.
Posted on Nov 11, 2009
jsrock516
  • 5911 Answers
SOURCE: The last 3 times after using my top load Kenmore
DO NOT use Draino or any other drain clog removal chemicals to clean a washer. It could damage the tub seal, drain lines and/or pump & impeller. If you wish to clean the washer, you need to access the drain pump and remove the drain lines and flush them out. The following link explains how you can access and remove the pump:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
I would recommend you UNPLUG the washer and take it to a location where you can flush water through it. Preferrably outside, or in a garage. If you lie the drain hose on the floor and fill the wash tub with a garden hose, simple gravity will flush water through the tub basin, drain pump and drain lines.
If you have any questions about these procedures, please post back and let me know. I hope you find this information helpful.
NOTE: The drain pump has only one moving part (the impeller). It is a common place for debris to collect. Remove the two drain hoses on the pump to inspect.
Posted on Jun 25, 2010
Frigidaire Affinity ATF7000E Front Load Washer locks the door then it doesn't start. What's wrong?
Good Afternoon Friend,
I understand the door locks on your Frigidaire Affinity washer, model# ATF7000E, and the load does not start. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Affinity ATF7000E Front Load...
How do i reset my kenmore he 2 washer
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 03, 2010 | Kenmore HE2 Plus Front Load Washer
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore model #110.26442502
Hello dagreen,
Welcome to fixya.
I'm Huuum and happy to assist you,
You said,
Last night you filled the washer with a comforter and pillow cases! It was working fine and then you lifted the lid. Now it wont start back. Any ideas. It is full of water and had already started agitating.
Check the breaker
Could the power be out due to an electrical storm while you were sleeping.
If not!
Try pulling the plug out for 5 minutes or turning the breaker off if you can't reach the plug.
Then try to start. this should have reset the system.
Some Questions to check
• Is the drain hose clogged, or the end of the drain hose
more than 96 in. (244 cm) above the floor? See the
Installation Instructions for proper installation of drain hose.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
• Is there excessive sudsing? Always measure detergent.
Follow manufactures directions. If you have very soft water,
you might need to use less detergent.
let me know how you do and that it works.
Huuum
please remember to leave a rating when your finished.
Sep 26, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE Elite HE 3T
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Total Power Shut-Down - Can't get it to come back on
Hi , recock the breaker ,one the line was disengage..
Jan 27, 2008 | Kenmore 46462 Front Load Washer
Kenmore 44042 Front Load Washer Logo
378 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
