La impresora mp 250 no scnea y me indica error 2,140,2
trisha8765
  • 120 Answers
SOURCE: Any help with a Canon Pixma MP 250 P2 Error Code?
I found you a site where you can download the latest drivers to install at the link below Good Luck
http://support-au.canon.com.au/EN/search?canonsearch=1&lang=EN&category=All-in-One Printers&series=All-in-One Printers&model=PIXMA MP250&menu=Download
Posted on Dec 27, 2009
eagle338
  • 4889 Answers
SOURCE: error E 4, 2 canon pixma mp 160
E42 means scanner error. May require a hard reset(disconnect from power supply for 30 min). Otherwise may require factory reset procedure to be applied. Follow the steps below:
Mp160 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s)
according to the function listed in the table below.
(Each time the Stop/Reset button is pressed,
the LED lights alternately in orange and green, starting with orange.)
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset procedures below.
5 times Orange Destination setting See Destination setting procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Posted on Jul 09, 2008
giovarodrigu
  • 24 Answers
SOURCE: la impresora mp 130 yo la apago y cuando vuelvo a
intenta presionando el boton cancel (el triangulo rojo) por 6 segundos, a veces hay que repetir el procedimiento, eso deshabilita el sensor de cantidad de tinta en el cartucho.
Posted on Jul 20, 2009
puertobori
  • 7733 Answers
SOURCE: el problema es que la impresora HP j3600 no
Trata este enlace HP Support & Drivers.
Posted on Oct 20, 2010
Joed911
  • 4338 Answers
SOURCE: LA MÁQUINA INDICA ERROR E000805-001
1) Desconecta el poder de la impresora. 2) Quita el ladrillo/bloque negro del poder por detr?s de la m?quina. (Puede ser un malvado peque?o de sacarlo la primera vez usted lo quita.
3) Abre la cima de la impresora/multi unidad de funci?n.
4) tira Suavemente la cinta para centrar el portador de cartucho de impresora.
5) Abre o el lado de izquierda o derecha y quita el cartucho. (Depende de cu?l lado el error ocurre en, negro a la izquierda, el color a la derecha)
6) Verifica que toda la tira pl?stica que cubri? los nuevos contactos en el cartucho tiene de hecho fue quitada.
7) Toallita tanto los contactos de cartucho como impresora con una seco, hilas libertan tela.
8) Enjuga el fondo del cartucho con una h?medo, hilas libertan tela para verificar que la tinta fluye y los vistazos corrigen.
9) se Asegura de que no hay agua que queda en el cartucho.
10) Reinserta el cartucho en el portador y se asegura de que es profundizado y es insertado completamente al trasero de la ranura de portador.
11) Reinserta el ladrillo/bloque del poder.
12) Conecta de nuevo el cable de energ?a el?ctrica de impresora.
13) el Poder en la impresora y el error debe ser resuelto.
14) Corre la alineaci?n de impresi?n e impresi?n o copia varias p?ginas para asegurar el problema ha sido resuelto.
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Posted on Dec 19, 2010
Hola. Necesito escanear. Desconecte la impresora y apague la PC como me indica pero repite el mismo error. gracias. Juan Jose
Asegúrese de que el controlador de impresora está instalado en su ordenador. Si va a escanear un documento, asegúrese de que el software de escaneo OCR Lexmark (se usa para escanear un documento para la edición) está instalado. El software de exploración sólo está disponible en el disco de instalación que viene con su impresora.
Además, asegúrese de permitir el acceso completo a todo el software Lexmark y los procesos de comunicación de la impresora en las reglas del programa / permisos de su firewall.
Nota: Esto se traduce utilizando translate.google.com.
Jul 27, 2011 | Lexmark X2650 All-In-One InkJet Printer
Como resetear dcp165
Instrucciones para reparar el error 46 DCP-165C
Desconectar el enchufe de CA
Conectar de nuevo el cable de CA mientras mantiene pulsado el bot?n "Men?"
y manten?rlo presionado (por 15 seg)
ahora est?n entrando en el modo de mantenimiento aparece en la pantalla LCD "error 46"
Seleccione 8 utilizando el boton de flecha hacia arriba, pulse OK
seleccione 0 y pulsar OK
00:00 00:01 OK (en la pantalla se muestra este mensaje)
Presionar la tecla azul (star black) 25 veces hasta que salga PURGA: xxxxx
Seleccione 2, ok.
Seleccione 7, ok.
Seleccione 8, ok.
Seleccione 3, ok.
El contador de la purga indica ahora: purga: 00000
apaga la impresora, (desconctar el cable CA)
listo para imprimir!!!
May 26, 2011 | Brother DCP 165C Compact Color Inkjet...
Codigo de erro 3807 como resolver?
Para solucionar el mensaje de error que indica que se ha producido un error en el estado del sistema (c?digo de error 3807):
  1. Desconecte el adaptador de alimentacion de la impresora.
  2. Espere 30 segundos para que se reinicie la impresora.
  3. Conecte el adaptador de alimentaci?n a la impresora. Si fuera necesario, encienda la impresora.
Si el error continua:
  1. Abra la puerta de acceso de la impresora.
  2. Retire e instale el cabezal de impresion dos veces.
http://support.es.kodak.es/app/answers/detail/a_id/31546/selected/true
  1. Cierre la puerta de acceso de la impresora.
  2. Espere a que la impresora est? lista para su uso.
Si el error no se soluciona, pongase en contacto con nosotros:
http://support.es.kodak.es/app/answers/detail/a_id/22432/selected/true
Feb 25, 2011 | Kodak ESP 5 Printer
Cuando conecto el cable usb la computadora no reconose la impresora y en la pantalla de la impresora aparece inicializando y de ai no sale..ke puedo hacer de antemano muchas gracias
Por favor, el cable USB quese conecta la impresora y la computadora, asegúrese de que está correctamenteconectado. Compruebe si el equipo detecta la impresora por medio de cheque enadministrador de dispositivos. Intente cambiar a otro puerto USB, si tienecable USB adicional intenta utilizar un cable diferente. Una vez que elordenador detectará la impresora, aparecerá una notificación en la esquinainferior derecha de la pantalla que un nuevo dispositivo ha sido detectado.Paraobtener asistencia adicional, póngase en contacto con asistencia técnica deLexmark.
Feb 09, 2011 | Lexmark X500n Color Laser All-in-One...
Tengo una registradora Casio PCR262, aparece en la pantalla e94
Error de impresora. Aseg?rese de que nada se ha atascado en la impresora
Jan 24, 2011 | Casio Parts Cash Register PC Desktop
Mi impresora canon mp150 prsenta error 6500 y no encuentro solucion agradeszco su opinion
Un error 6500 hace referencia a un error de la placa l?gica en la impresora. Con el fin de solucionar el problema, le recomiendo lo siguiente:
1. desench?felo y desconecte la impresora del equipo. desenchufar la impresora de la toma de corriente.
2. Pulse y mantenga presionado el bot?n "On" durante 30 segundos, luego deje la impresora solo por 10 minutos. Esto permitir? que alll corriente el?ctrica para ser dado de alta de la impresora.
3. conectar todo de nuevo a la computadora y toma de corriente. Encienda la impresora.
4. eliminar los dep?sitos de tinta de la impresora, a continuaci?n, volver a asiento. Aseg?rese de escuchar cada "clic" en su lugar a medida que los puso pulg
5. Apague la impresora y, a continuaci?n, de nuevo, prueba para ver si funciona ahora.
Si no es as?, tendr?s que ponerte en contacto con Canon para la reparaci?n de la impresora / una junta nueva l?gica para la impresora.
Dec 28, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Dec 19, 2010 | Office Equipment & Supplies
La impresora canon ip4600 no reconoce los cartuchos. al encernderla parpadea las luces y sale el error 6502
C?mo restablecer el c?digo de error "6502" para CANON iP4300 ip4600? tal vez los siguientes consejos pueden ayudarle:
Con la impresora desconectada, retirar el carro de tinta a la derecha, Enchufe la impresora, presione el bot?n POWER, No suelte el bot?n de encendido, y luego presione el bot?n RESUME dos veces seguidas. Suelte el bot?n POWER, pulse el bot?n REANUDAR 4 veces.
La se?al ac?stica puede sonar una vez. Luego, con la impresora desenchufada, despu?s de que restablecer la unidad electr?nica de la impresora, abra la impresora y este proceso ha terminado.
Listen Read phonetically
Dec 14, 2010 | Office Equipment & Supplies
El problema que tengo es con una dell 3100cn y elo que me aparece en la pantalla es el siguiente mensaje "bandeja 1 debe de ser de 250 hojas" no me permite meterme al menu ni tampoco se queda...
Nused que cuando movi? la impresora que usted instal? atr?s encima de la bandeja de 250 hojas (es requerido para el modelo 3100cn), es posible que puedan haber da?ado la entierra-conexi?n el?ctrica entre la base de impresora y la unidad de 250 hojas de bandeja.
Devuelva la base de impresora de la unidad de bandeja y conjunto aparte. Examine con cuidado el conector en la unidad de bandeja y aseg?rese del corchete que contiene el conector no ha sido doblado ni ha sido deformado. Consiga alguna ayuda e incline la impresora atr?s suficiente distante que usted puede examinar el conector que aparea debajo de la impresora. Si no ayuda a estar disponible, desliza la orilla de la impresora lejos la orilla de una superficie fija s?lo lejos suficiente en ver la conexi?n.
Nov 30, 2010 | Dell 3100cn Laser Printer
Tengo una hp photosmart c6280 y tiene un problema con un error 0xc18a0001 compre los cartuchos nuevos y sigue reflejando el mismo error, compre un sistema continuo y sigue dando el mismo error,quiero saber...
if you speak english and can read english go here and scroll down to Re: hp photosmart 8250 by Anonymous (7/26/08 2:04 PM) reply There is also help from HP support online chat
http://www.fixyourownprinter.com/forums/printer/51559
si usted no habla Ingl?s o leer aqu? es la conversaci?n que le dir? c?mo resolver el problema paso a paso de este error. si esto no ayuda usted puede ir a CV y obtener ayuda en l?nea o hablar con un t?cnico por tel?fono.
Aceptar que ten?a el c?digo de error CV 0xc18a0001 problema y aqu? est? la conversaci?n que tuve con el ..... James Cowan tecnolog?a: el c?digo de error CV 0xc18a0001 llamarse Ernesto: Voy a ayudarle en este sentido James Cowan: gran llamarse Ernesto: Yo entiendo que una c?digo de error con 0xc18a0001 con "Error de sistema de tinta" se muestra en el panel frontal del dispositivo Todo en Uno de la impresora. En lo correcto? Soy James Cowan: correcta Ernesto: Gracias por la confirmaci?n de llamarse Ernesto: ┬┐Me puede dar el n?mero del modelo del dispositivo Todo en Uno que est? utilizando: James Cowan c6250 llamarse Ernesto: Gracias por la informaci?n. Gracias Ernesto: James, por favor h?gamelo conocer la temperatura ambiente en el que la impresora se sustituye James Cowan: 67 grados F llamarse Ernesto: Muy bien llamarse Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora para resolver el problema de James Cowan: puede llamarse Ernesto: Pulse la tecla "flecha izquierda" . Presione la tecla "Setup" clave y suelte ambas teclas, la pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte el bot?n "Aceptar". llamarse Ernesto Por favor, ignore los pasos anteriores, James James Cowan: ok si nada parec?a hacer nada Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora Earnest el: Pulse y mantenga oprimido el "Imprimir fotograf?as" y "ojos rojos" botones. Suelte ambos botones. La pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte en la secuencia de "ojos rojos", "Imprimir fotograf?as", "ojos rojos" Ernesto: la pantalla debe decir "apoyo" y mostrar el rev FW (algo as? como R0616R) James Cowan : Ernesto COxxFN0723BR: Bueno Ernesto: 2. Pulse y suelte el bot?n de flecha derecha hasta que la pantalla dice "Men? de configuraci?n del sistema James Cowan: puede llamarse Ernesto: 3. Pulse y suelte el bot?n "Aceptar". James Cowan bien y que dice llamarse Ernesto estado de fallo de hardware: pantalla debe decir "error de estado de hardware: Despejado. Pulse Aceptar para borrar". Llamarse Ernesto: Pulse y suelte el bot?n "Aceptar". Mensaje se convierte en "estado de error de hardware aclarados continuar. Pulse Cancelar para":. Llamarse Ernesto Pulse y suelte el bot?n "CANCEL" tantas veces como sea necesario, de modo que, ya sea el "Welcome to Photosmart Express", aparece la pantalla, o bien, la tinta " El fracaso del sistema "aparecer?. NO TRATE DE NO ESCRIBA EN ESTA ETAPA. POR FAVOR James Cowan: puede llamarse Ernesto: Con el bot?n de encendido, apagar la unidad y desconecte el cable de alimentaci?n de la parte posterior de la salida de la impresora y la pared:. Llamarse Ernesto D?jame saber una vez que se realizan con el los pasos anteriores James Cowan: ok su desenchufado llamarse Ernesto: Espere 30 segundos para que el poder ser dado de alta ya continuaci?n, conecte el cable de alimentaci?n al enchufe de la pared primero y luego en la parte posterior de la impresora llamarse Ernesto: Encienda la unidad. La impresora puede mostrar mensaje "USO DE ENERG?A BOT?N DE PARADA DE LA IMPRESORA" seguido de "Pulse Aceptar para continuar". Pulse Aceptar. James Cowan: puede llamarse Ernesto: Quisiera saber el mensaje que muestra en la parte frontal del panel de la impresora James Cowan impresora: preparaci?n ocurriendo - no interrumpir Ernesto Bueno James Cowan: puede hacer su Earnest: Vamos a imprimir una p?gina de autoprueba de la impresora ya James Cowan: tratar bien llamarse Ernesto: 1) Carta de la carga, A4, o de plano no utilizados legales, papel blanco en la bandeja de entrada 3. 2) Aseg?rese de que la impresora est? encendida y cargada sin usar con papel blanco), papel. Pulse Configuraci?n. El men? de configuraci?n. 4) Pulse el bot?n flecha hacia abajo para seleccionar Herramientas y, a continuaci?n, pulse Aceptar. 5) Pulse la flecha hacia abajo para seleccionar Auto-prueba de informe, y pulse Aceptar. El auto-informe de prueba imprime. James Cowan se puede imprimir llamarse Ernesto: Muy bien, por favor, compruebe si todos los colores pritned perfectamente en la p?gina de prueba James Cowan: perfecto llamarse Ernesto: Gran .. Saludos James Cowan:! Muchas gracias Ernesto: James, ahora usted puede seguir utilizando la impresora de llamarse Ernesto: Le agradezco su esfuerzo y paciencia para tratar de resolver el problema.
Oct 01, 2010 | Office Equipment & Supplies
362 people viewed this question
jasbo
jasbo
