Question about Garden
Where is a good place to get replacement parts for a fl1500 leaf blower?
  • 718 Answers
Posted on Nov 13, 2010
How to adjust carb on F25 leaf blower
Initial setting to start is 1 full turn on both low and high adjustments
Oct 07, 2014 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Carburetor adjustment procedure
low and hi speed mixture screws
one adjusts for proper idle
one adjusts for proper high rpm operation
turn them in or out to get the best throttle response and proper wide open throttle rpm's
Aug 26, 2014 | Weed Eater Fl1500 Le Leaf Blowers
Is getting air in gas line, will not start
If the hoses are connected right and they are in good condition, it could be bad gas,sparkplug or carburetor needs cleaned and/or a rebuild kit. Check the link below for parts:
http://www.ereplacementparts.com/poulan-fl1500-type-blower-parts-c-16962_31724_31725.html
Feb 02, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Will not fire after replacing spak plug
if it will not spark after the plug change, then you need to go deeper to the coil, and the magneto, alot of times the magneto plate just needs to be sanded or wire brushed.
Nov 13, 2010 | Weedeater Featherlite Blower 18 Cc 150 Mph...
I need to repair the starter mechanizum on my weedeater fl1500 gas blower. How do you get at it?
Oh, are you in for a job.
here we go,,,,pull air output tube. then remove bottom of air intake shroud...then remove impellar, then remove top half of air intake shorud... now all starting parts will be visable. They are mounted on top of the top half of the air intake shorud......careful, the fuel tank is mounted to the top half of the shroud...Good luck.
May 29, 2010 | Weedeater 2 Speed Gas Blower FL1500LE ()
Weed eater Feather Lite Blower - replacing pull cord -can't figure out how to get to it
This should help you out. Go to Poulon's website. Look for a tab to "order parts". Model is fl1500. That will take you to a page that you can look at the blower "chassis" to order parts. That shows you how the bottom housing goes together. You have to take off the bottom housing, the blower fan, the top housing. That should take you to the starter cord mechanism.
Good luck.
http://www.ordertree.com/ARI.aspx?Mfg=75&Model=FL1500 Gas Blower Type 3&AFID=59
Nov 21, 2009 | Garden
Weedeater leaf blower FL1500
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray withcarb.cleaner.Make sure the small screen is free of debris. (Should beable to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 19, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
