Question about Black & Decker 19" Electric Lawnhog Mulching Mower
Replaced the switch and cord on B&D electric mower but it still shorts out and will not run. What next?
    President:
  • 1,140 Answers
Unfortunately, you probably have a short in the motor windings and will therefore need a new motor. Motors can be re-wound but it's not that cheap and not many people do it these days. It's far easier to get a new motor.
Regards,
BElectric
Posted on Nov 12, 2010
My mower stopped working. can an electric mower be repaired?
depends on the fault
if it is a battery unit then the battery may need replacing or the terminals cleaned or bushes in the motor replaced
if electric power cord operation , could be the start/ run capacitor, broken cord, faulty switch
best you take it to an accredited service agent and have the problem properly diagnosed before making a decision
Jun 27, 2015 | Electric Garden
Corded mower starts and trips circuit switch immediately & will not stay on?
There is a short in the system . The safety device is kicking in check cord for brakes or nics
Jul 08, 2014 | Remington PowerMower 17-Inch 60-Volt...
Neighbor mowed the extension cord and mower won't start
Check the cord has been properly replaced. Check circuit with a meter (NOT connected to mains) The live pin on plug should connect to live pin on motor switch etc. (need to take off cover on switch unit)
Cutting through the cord should not have damaged the mower.
Jul 13, 2013 | Electric Lawn Mower
Two-year-old Black & Decker 19"
if its not in the cord. it may be the brushes in the motor. if they are worn down and not hitting armature. motor will not run. good-day !
May 05, 2011 | Black & Decker 19" Electric Lawnhog...
Have a black and decker 19in electric mower. was
The "wedge" of the plastic lever wears, so you need to replace the lever or build up that section of the lever. Some cyanoacrylate (Super Glue / Krazy Glue) and a piece of a zip tie will work.
Sep 23, 2009 | Black & Decker 19" Electric Lawnhog...
Why does electric mower shut off my breaker when switch is turned on?
you are probably overloading a busy circuit and the mower is pulling enough to trip breaker....try another source that is hopefully more than 15 amp rated and not running the rest of the house. otherwise mower motor could be failing and shorting or drawing too much amps(electrical current) overloading and tripping breakers
Jun 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
My lawn mower doesn't start -all wires and cords are ok - and then sometimes it starts itself and when i move it it stops again. it was working perfectly fine one day and then the next....its gone it's a...
sometimes you get an internal break of the electric feed cable which shorts out with movement and gives problem that you are having , another fault with them is that the switch has a safety machanism in it which can cut power for up to twenty minutes before it will reset which is done by operating lever as you would normally ,occurs a lot with m/cs used with adittional extension cables,hope this helps
Mar 23, 2009 | Electric Lawn Mower
Black & Decker 19" Electric Lawnhog Mulching Mower Logo
149 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
