My Comcast DTA remote (the one I got with the upgrade to digital cable with the converter box) will not change channels. All the wiring has stayed the same (I checked to make sure it was still attached) and the light on the converter box is still green, as in, it is unchanged from when I installed it. The remote will power on and off and turn the volume up or down, so it is clearly working with the television, but not the cable controls themselves. I doubt this means I need to reset the code since that was for linking the remote to the TV, which seems to be fine. I would really like to be able to change channels. Somehow it got stuck on CSPAN
Did you ever figure it out? I have the same problem and Ive talked to 3 techs, and no one can come out for at least a week. Im about to throw the receiver through Comcast's window.
Please let me know! elr05@fsu.edu
Posted on Jan 28, 2011
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
How to setup Toshiba CT824 tv with digibox (I have no user manual)
You can connect the digibox (digital converter box) or DTA to the TV using coax jumpers and tuning the TV set to channel 3 or 4 in some cases.
Connect the input (wire from the wall or floor) to the input on the digital box.
Connect the output of the digital box to the input of the TV set.
Turn on TV and digital box, tune TV to channel 3 using the TV remote or the buttons on the TV itself.
Use the digital box remote to change channels. You may need a code to program the remote to work the TV set.
I hope this helped.
Cheers!
Apr 27, 2010 | Televison & Video
Comcast dta remote codes for trutech klv3112
I have a Trutech 10 inch under cabinet DVD/TV and needed the codes for the new Digital Adapter that Comcast is forcing everyone to move to. The short answer is that there isn't a single code that will work for what we all need. After much research I have an answer. It's largely unsatisfactory, but its somewhat of a work around. If you use code 10451 you can get the channel up, channel down, the number pad and the "last" button to work. To get volume functional, change the volume lock on the comcast box. To do this:
1. With the TV on, manually set the volume to a medium high setting
2. With the comcast remote, press and hold SET until the red light blinks twice.
3. Enter 9-9-3 (red light blinks twice)
4. Press and release the digit 1 (red light will blink 4 times)
Now, in addition to channel control, you have volume control. I can't do anything about the power button or other functions. However, this at least makes the remote functional.
Good luck to all!
Jan 10, 2010 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Need code for Audiovox LCD TV (Model LCD1900W) for COMCAST DTA
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off
Aug 28, 2009 | Televison & Video
Have sound on some channels but some no sound
If you are using a comcast D.T.A. (Digital transport adapter) THAT LITTLE BOX FOR 2ND OR 3RD TV IN YOUR HOUSE. GO to channel with no sound then press LANG button on the remote that came with your DTA box. Press it only once. This worked for me .
Jun 20, 2009 | Philips Magnavox 51MP392H Rear Projection...
Product DMR-EH50, UNABLE TO DOWNLOAD TV GUIDE ON SCREEN SYSTEM.
I think I may have the "answer".
I am in Atlanta and have a Panasonic DVR that was working fine and sometime during the past month or so we lost the channel listings. I've tried many resets as well with negative results.
I called Comcast tonight. The agent helping me took a long time to research the issue and gave me this answer (which sounds reasonable). By the way, this is for the Atlanta area and may not be applicable to other areas of the country.
Due to delays in the conversion to broadcast digital and the fact that Comcast is experiencing bandwidth issues, they have digitized the "channel listing" signal. By mid-June Comcast's signal will be all digital and you won't be able to watch a TV connected directly to Comcast cable - regardless of whether it has digital or analog tuner (or both). This is contrary to what I'd heard before.
After mid-June, you'll either need to use a cable box OR what she called a "Digital Transmitter Adapter" (let's call it a DTA). Prior to being converted to "full" digital, you'll get notification from Comcast. She said I'd be able to get 2 DTAs at no charge (I currently have one Comcast HD DVR box). Additional DTAs would be $1.99 a month. DTAs will only provide access to the "basic" cable channels, but the good news is that the Panasonic DVR should be able to obtain its channel lineup through this DTA box.
If you have any questions, please feel free to contact me directly at richard_gladney@yahoo.com
Good Luck!
Mar 30, 2009 | Panasonic DMR-EH50 DVD Recorder
TV Guide on Line for viewing and recording was there and poof
Good Luck!
Mar 25, 2009 | Panasonic DMR-EH50 DVD Recorder
On screen guide
I am in Atlanta and have aPanasonic DVR that was working fine and sometime during the past monthor so we lost the channel listings. I've tried many resets as well withnegative results.
I called Comcast tonight. The agent helping metook a long time to research the issue and gave me this answer (whichsounds reasonable). By the way, this is for the Atlanta area and maynot be applicable to other areas of the country.
Due to delaysin the conversion to broadcast digital and the fact that Comcast isexperiencing bandwidth issues, they have digitized the "channellisting" signal. By mid-June Comcast's signal will be all digital andyou won't be able to watch a TV connected directly to Comcast cable -regardless of whether it has digital or analog tuner (or both). This iscontrary to what I'd heard before.
After mid-June, you'll eitherneed to use a cable box OR what she called a "Digital TransmitterAdapter" (let's call it a DTA). Prior to being converted to "full"digital, you'll get notification from Comcast. She said I'd be able toget 2 DTAs at no charge (I currently have one Comcast HD DVR box).Additional DTAs would be $1.99 a month. DTAs will only provide accessto the "basic" cable channels, but the good news is that the PanasonicDVR should be able to obtain its channel lineup through this DTA box.
Good Luck!
Mar 21, 2009 | Panasonic DMR-EH50 DVD Recorder
Is Audiovox VE1020 HDTV compliant?
Audiovox VE1020 is not a digital set. To see digital broadcast you will need another digital reciever or a long lead to connect to your existing one.
This set does not have very good reviews either.
Hope that helps!
Jun 06, 2008 | Audiovox VE1020 10.2 in. TV/DVD Combo
Channels are not available on phillips tv
HI
CHANGE YOUR TV TUNER CHIP.
ALSO PUT REMOTE CONROL CHIP AND NEW REMOTE .
Mar 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
