Question about Toshiba Satellite A135-S4527 Notebook
I have a desk top computer & a laptop computer. My desk top internet works fine, but I have a Netgear Router for my laptop. I once was using my laptop on line, no problem, but now I cant go on line with my laptop. Help
  • 65 Answers
Seeting may have got lost in yuor network. I would reset the router, and set it up again, It is possible it could have lost your IP.... thats a starter, take your laptop to other places where there is wifi and make sure its not your wireless card.
Posted on Jun 17, 2008
Router problem. unable to connect wirelessly
This is usually up address conflict. You will have to assign the wifi or lap top to different IP addresses. You have to refer to the modem manufacturers instructions or search on net / YouTube how to do this. It's too detailed to do it here I think.
Oct 17, 2017 | NetGear WGR614 Wireless Router
Connecting my Home Hub to Netgear to have wireless setup
3ee198b3c15f6ca7320d6cda56a651c7.png Netgear DG834G 54 Mbps Wireless ADSL Firewall Router Set-up Guide _________________________________________________________________________________________________ _________________________________
Oct 05, 2008 | NetGear DG834G Router
Have a new desk top bought the wireless-g usb adapter wg111 to pick up my netgear range max wireless router wpn824v3. After installing the wireless-G picked up internet once but after the system was shut...
I have the WPN824v3 and it can be balky finding and connecting to a network sometimes. It works best (and gets the best range) using the Netgear RangeMax Wireless USB 2.0 adapter (WPN111). The router and this adapter are (according to Netgear) specifically designed to work with each other, thereby maximizing both the range and the speed of the router.
Feb 02, 2010 | NetGear RangeMax WPN824 Router
Have internet on desk top pc, but netgear wireless router will not connect IP is 192.168.1.1,but do not know how to configure router
Once you connect the router, attach a CAT-5 cable between the router and your computer. Once this is done, go to http://192.168.1.1 and log in to your router. The login info is also in the manual. After logging in, fo to the Wireless section; set your network's name (SSID) then your security. I prefer the WPA-PSK[TKIP] for its simplicity. The rest of the router settings are pretty much automatic and not messed with usually. Feel free to ask if you have more questions.
Nov 11, 2009 | NetGear WNR2000 Wireless Router
Lost internet connection
If that Toshiba laptop is not in use do you still experience that problem?
You may change wireless channel in your router.
Do a firmware upgrade for your router as well.
Hope this helps!
Nov 14, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Setting up wireless network 4 computers with Netgear
Assuming they all will work with the version of wireless the netgear works with (802.11a/b/g) then you really just need to enable the wireless network on the netgear and choose how you want to protect it. I recommend using WPA or WPA2 if all your devices will support it - this depends on the wireless cards in all your pc's - just set up a name for the wireless network (not recommended that you use the default because everyone does) set up your WPA/WPA2 passphrase on the netgear and it should be pretty much ready to go. On each pc then, once they are able to see the wireless network with the unique name you gave it, just hit connect in your wireless settings and enter the passphrase. Each pc should be set up.
The only other thing to consider is to make sure they are all using DHCP via the wireless router or, if you prefer setting up their IP addresses manuall, make sure none of them conflict with eachother (each one needs to be unique).
Jul 15, 2008 | NetGear Computers & Internet
Problem with initial install
hello!
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on
Step 7: test the Internet connection on both pc
if this still didnot work, upgrade the firmware of your router
May 30, 2008 | NetGear WGR614 Wireless Router
Question on setting up two computers
Yes, I have pretty much the same setup at home. Wired desktop and wireless laptop. On the back of your wireless router, there should be 4 or 5 wired connections which you can use. You will only have to use the setup disk on one computer. Basically, the setup disk is for the router, not the computers, it simply guides you through the router configuration process. You can also do this manually, the manual for the router will give those instructions as well.
Apr 07, 2008 | NetGear WGR614 Wireless Router
NetGear WG111 802.11g/b Wireless Adapter
After a small amount of trouble, I have configured my Win 98 laptop to use
Netgear WG111v2 wireless modem to connect to my wireless router. I used
the driver from the CD that came with the modem, following the instructions and
got to the point, after rebooting a couple of times, where I was connected to the
router, but could not reach another computer on my network (or the outside world).
I double-clicked on the wireless model icon in the system tray and noticed that,
on the NetGear SMART WIZARD panel, the WEP key was set to use the
"Create from passphrase" option, even though I supplied the already generated key (the
hex numbers) during installation of the modem. (The modem was using the key
as a passphrase to create another key.)
To fix this, on the SMART WIZARD panel, I
selected the "Enter key manually" option and, er, entered the hex key (the one
the router/access point uses for security) manually.
I hit "Apply" on the Wizard and, lo and behold, I was pinging the rest of my network.
I rebooted one more time (I had some leftover bad settings in my "Network Connection"
TCP/IP entry for the WG111 connection; I reset them before the reboot
to allow my network to automatically assign an address) and I was then able
to view my favorite site (bythestadium) from my favorite browser (firefox)
Jan 29, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Toshiba Satellite A135-S4527 Notebook Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
