Question about GE Profile WPRE6100G Top Load Washer
Coin stuck in agitator. how is agitator removed
Got braclet stuck in the between top and bottom of agitator? GE Profile Washer top Load any suggestions?
Posted on Feb 06, 2013
    Problem Solver:
  • 5 Answers
Normally you can take the top of the agitator off with the use of a screw driver or by turning couter clockwise. Once the top is off you should see a nut or bolt. Removing this will allow the agitator to be removed.
Posted on Nov 12, 2010
How do I remove the agitator from LG top Load washer
the agitator is held by a bolt with a 7/16 drive nut located inside the middle of agitator from the top downward? however by ur description sounds like maybe u have bad bearing in the hub? the cam dogs in the agitator dont usually make any noise especially when bad they just dont allow the agitator to move or catch the groves to agitate. The grinding could also be coming from something stuck inside the tub or on its outside and thus is hitting the wall lining and makes a screeching scraping sound, Ive seen this several times, a bra wire, or loose coin or key, etc
Sep 28, 2014 | Washing Machines
Coin in Whirlpool washer tub
remove the centre of the agitator (Soap dispenser) using a long extension bar and a 10mmm socket remove the bolt holding the agitator in. Pull agitator up and out Remove coins and anything else there replace is the reverse procedure.
Aug 17, 2013 | Washing Machines
Maytag top loader HE: coin under impeller(agitator). how to remove agitator?
Take a water hose and blow it out.
G.e. Agitators normally need a special puller to remove tub
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 05, 2010 | Hotpoint VBXR1090D Top Load Washer
My Whirlpool Cabrio washer has some coins trapped in the inside of the machine. I need to find out how to remove the agitator to check inside for more coins.
They are not in your agitator. they are in the pump on the bottom left if you are standing behind the machine. Be VERY careful. That litle pump seems to be the beginnig of many leaking problems.
May 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I think there may be a coin in the drum, how do i get to it
Try removing the top plastic cover from the agitator which may either unscrew or pull up. Then there is a nut which you can unloosen to remove the agitator itself. and possibly get at your elusive coin. If you can't then the only way after that is to disassemble until you can remove the agitator and drum.
Mar 14, 2010 | LG WFT1071TP Top Load Washer
I have a LG WM2016CW washing machine and there is change (penny,nickle,dimes ect.)stuck in the drum some were, how do i get them out?
You said "stuck" in the drum somewhere? Like under the agitator vanes? You should be able to take the lid off the agitator, it should either clip in or have a screw holding it on, and there you will see the nut, or keeper that holds the agitator on the motor shaft. Remove that clip or nut and you can lift the agitator out of the washer. From there you will see all of the wash drum and should be able to remove any foreign objects. If these "coins" are between the inner and outer tub, then you will have to remove both the top cover and lid, and remove the agitator and the inner drum to get to the outer drum in order to reach these objects. Not a hard job, but it will take you a little while. You could try reaching with your fingers around the agitator bottom and see if you can "feel" the coins or objects and possible use a small brush or stick or popsicle stick to move them out so that you can reach them, Kinda like "fishing" under the refrigerator or the couch. In the alternative, you could enlist four friends and unhook the washer from the water supply and the electric, and turn it upside down and try to shake the coins or objects out the top of the drum. Tilting the machine to one side will let them fall to the cabinet sides and possibly drop out the bottom when it is uprighted. Now I know why Mom always "checked" my pockets before she washed Dad and my clothes. We left a little of everything in there, from time to time. Good Luck with this.
Sep 27, 2009 | LG WM2688HWM TROMM SteamWasher
Maytag washer model number lnc6760 how do you get
Hi, Remove the cap on top of the agitator and you will find a bolt holding the agitator in. After the bolt is removed, the agitator should lift out.
Please let me know if this helps or if i can assist you further.
Vic
Jul 05, 2009 | Washing Machines
Fridgidaire gallery
From the sounds of things, you are talking about a front loading dryer. The agitators in the dryer can get coins stuck inside them. Remove the top and rotate the drum to reveal the screws which hold the agitators to the drum. Remove the screws and the agitators, empty the coins or other debris and reinstall.
The loud squeal sounds like the pad under the open side of the drum is worn out. There may also be a dry main bearing in the rear of the dryer. Lubricate the bearing and reinstall the drum. The squeal should disappear.
If this is not a dryer or a front loading washer, none of these suggestions will apply, Sorry
Feb 08, 2008 | Washing Machines
GE Profile WPRE6100G Top Load Washer Logo
402 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
