Question about Electrolux EIDW6405HT Builtin Dishwasher
I can't get my electrolux dishwasher to run. It seems as though the touch pad is not responsive. It says to reset holding down the sanitize button, I do that it beeps but doesn't do anythng. All of the buttons are not lit up. I have to hold the delay start button along with the sanitize button to light the buttons up, still the buttons don't seem to be responsive, I touch the start and the lights go away and flashing numbers appear. Et 19 66 02 34 Any help would be appreciated.
SOURCE: Electrolux DX302 Dishwasher power button wont stay on
I rang Electrolux and have ordered a new switch....
Posted on Jan 14, 2009
  • 15 Answers
SOURCE: Panel not working on Electrolux Dishwasher
CONTACT ELECTROLUX. YOU EITHER HAVE A FAULTY TOUCH PAD OR A BAD RIBBON CONNECTION.
Posted on Apr 07, 2009
jan mczeal
  • 632 Answers
SOURCE: electrolux dishwasher delays before starting
  1. To cancel the delay.press the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
  2. To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
  3. Press Start/cancel twice to turn-off the dishwasher without draining.
Posted on Aug 31, 2009
SOURCE: I have an electrolux edw5505eps dishwasher. The
check out my thread on a similar issue. If your power button doesn't light and delay button does not light? Is the LCD screen display anything? check out my post several really good check lists.
Posted on Nov 26, 2009
tattootech2
  • 72 Answers
SOURCE: All the light on my new, Electrolux dishwasher are
Remove the kickplate at the bottom of your dishwasher and see what error you are getting. Likely a leak error.Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Posted on Apr 07, 2010
What are labels for buttons on electrolux edw5505eds3 dishwasher?
Unfortunately, the model number EDW5505EDS3 doesn't seem to exist. Electrolux does have a manual for the EDW5505 in the database: http://www.electroluxappliances.com/Owner-Support/Product-Support/ . The direct link to the manual is http://manuals.electroluxappliances.com/prodinfo_pdf/Kinston/6919940en.pdf . This is a generic manual but lists the touch pad options starting on page 17.
There is an Electrolux EDW5505EPS and a EDW5505ESS. If you look here, https://www.ajmadison.com/cgi-bin/ajmadison/EDW5505EPS.html , you can select the second picture and zoom in. That shows several of the buttons clearly.
I hope this helps.
Oct 16, 2016 | Electrolux Dishwashers
Electrolux EX600 Dishwasher loosing power during wash cycle
Hi dan76n - Typically PF appears in the display when the dishwasher is first installed, or when power has been interrupted. HI-TEMP WASH, SANITIZE and START/CANCEL backlighting will also flash. To clear, touch START/CANCEL pad. If it proves to be ineffective, once again try resetting the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, restart unit and select a cycle. If the problem continues, the dishwasher could possibly be experiencing a wiring failure or faulty board. At this point I will highly recommend connecting with a certified technician for a further diagnosis and to accurately assist with the repair(s).
Feb 26, 2013 | Electrolux Dishwashers
Electrolux 5505 dishwasher will not come on - no lights, nothing
Hello Kathy Prussack - I understand you said there are no lights on, however try unplugging the unit or flipping the household breaker off for two minutes to reset. Is there power to the unit? I suggest touching each button individually on keypad, does any lights turn on or does display change? If not, I would recommend contacting a professional because the unit may possibly have a defective keypad.
Sep 30, 2012 | Electrolux 24 in. EDW5500DSS Stainless...
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
I have an electrolux dishwasher model #=EIDW6105gS0. All lights are flashing on the console and will not let me select any of the modes...will not run at all. Is there any way to reset? I have tried...
Sorry for the delay in replying to you, but there has been a technical fault and we have not been able to answer your question.
The 6105G does not have a numeric display, so all of the LEDs flash when a fault is detected, but this does not indicate which fault has been detected. Resetting the dishwasher should clear the error message, but if there is a fault, the flashing LEDs will return after resetting the washer and further investigation will be needed to determine the cause of the fault.
You should be able to reset the dishwasher by entering the engineering test mode and then cancelling it:
1. Switch off the main power to the dishwasher or reset the breaker.
2. Switch the power on again.
3. Press SANITIZE and DELAY START simultaneously.
4. Press the START/CANCEL button to exit
5. Reset the power again.
Please try the above, then let me know if you the error persists and you need further assistance. You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Apr 06, 2011 | Electrolux Frigidaire Professional Series...
Dishwasher won't start. digital panel, control lock light comes on. Nothing in the manual describes this problem
Hold down the heated dry button for 5 seconds, if that does not unlock the control replace the touch pad. i can walk you though this repair let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | KitchenAid Dishwashers
Apr 02, 2009 | Electrolux Frigidaire Professional Series...
Dishwasher's cycle just stalls
It looks like you have a cold water supply problem. Check water entrance pipe, may be bend (if you have there a vane - see it is open).
Check that water entrance valve work (it is an electromagnet valve,located at the pipe's enterance to the machine).
If it doesn't work, test that it get power. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnected the power cable from machine before doing it.
Check as well for valve's coil resistance or you should replace for a new valve.
Feb 17, 2008 | Electrolux 24 in. EDW5500DSS Stainless...
Maytag Dishwasher
we have a model mdvtt53aww1 and you can push three buttons and will light up the hi temp wash, heated dry and sanitize is there a code make it start
Oct 01, 2007 | Dishwashers
Electrolux EIDW6405HT Builtin Dishwasher Logo
46 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
