Question about Epic 425 Mx Treadmill EPTL88105 !
My Epic 425 is getting louder and louder, a whirring noise, but can't seem to find maintenance help
  • 297 Answers
It sounds like you have a drive motoer failing. The only other place that can be load or making noise is the front and rear roller. The rollers bearings when failing make a "popping" or "clicking" noise, and increases as you speen up. The motor "growls", and the faster you go the noise is..... well loud. The way to confirm this is to remove the motor hood, then start the treadmill on power/speed level 3. Be very carefull, and use a broom stick (wooden) to put on the drive motor while it is running. You should be able to "feel" what you are hearing. You should then raise the speed, and you will then feel the increase as well.
The replacement motor is around $200.00.
Hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 12, 2010
Whirring sound when accelerating
May be something near/in the flywheel bell housing.
It sounds like a piece of rusted flywheel dust cover has bent in touching flywheel area as you travel.}
Could be debris from tall grass/weeds too.
Good luck.
Nov 12, 2017 | Worldwide 1992 Chevrolet G20 Sportvan 4.3L...
Free tv repair advice
The noise you hear must be from its back-light inverter board. The ferrite core in the inverter transformer may make a high whistling noise and will be annoying. Contact any technician. It can be stopped by gluing. But is a skilled work.
Apr 23, 2013 | LG 60PV450 60-Inch 1080p Plasma HDTV
Does Epic 425 MX parts can be removed? I cannot move the Treadmill in to my house due to too bulky for any door. Help!
Yes please see your instr. manual and follow the steps how to assembling and disassembling. if you do not have download for free
from www. fitness.manualsonline.com
God bless you
Nov 18, 2012 | Epic 425 Mx Treadmill EPTL88105 !
Removing cover Epic 425 Mx motor hood
you must have a Lamp for to help the screws. Unless the machine had not screws, must be adjusted to a pressure. You must use the screwdriver for to help to open the hood.
see the video:
Jul 29, 2012 | Epic 425 Mx Treadmill EPTL88105 !
Whirring noise when in drive
more likely a wheel bearing jack up each wheel and check for play,
May 24, 2010 | 2000 Pontiac Grand Prix
I have a whirring or griding in my drivetrain. I can coast donw a hill and let the engine idle and I still get the noise. It doesn't sound any different going around corners and gets louder as the speed...
this sounds like(no pun intended) you have a wheel hub bearing assembly failing. they will start a whirring or humming noise and then a growling or grinding noise the worse they get. from your description it is a rotational noise and gets louder and maybe a higher pitch as the vehicle speed increases. have this checked out right away so no further damage is done. they are not cheap assemblies as most GM and Saturn vehicles have the ABS sensor built into them(if your Vue has ABS).
Nov 06, 2009 | 2004 Saturn VUE
Louder whirring noise when turning on computer
trumpjd,
Usually on startup the fans work a little harder then slow down. On newer computers they still have noticable fan noise. Most of what ou hear while the machine is running after start up is the power supply fan. When it starts to go bad you'll hear it all the time.
randy320sgi
Jan 09, 2009 | E-Machines eMachines Desktop PC
Epic 425 Mx Treadmill EPTL88105 ! Logo
1,014 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Colin Stickland
Colin Stickland
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
