Question about Garmin Forerunner 50
Foot pod is not being recognized with the fr60 I pressed settings , then sport , run, foot pod, then on. its reading sdm not found
Where can I get instruction details for my POD 550 watch?
RCX5 found it surprisingly light and small. It doesn't look like a computer on your wrist like many other GPS watches. Of course that is largely because the bulk of the GPS components and battery are in an arm band.
The armband and separate GPS device seemed like, and became, one extra piece of equipment to worry about.
The watch, heart rate monitor and foot pod all use watch batteries. Battery removal can be difficult, however once the back is removed the batteries are easy to install and replace. The GPS piece is charged with a standard USB cable.
The speed and cadence sensors batteries are not replaceable. These sensors must be purchased again when they wear out
The speed and cadence sensors are attached to a bike with zip ties. I found them easier to install than the Garmin sensor largely because they are separate devices. It was easier to position each of them so that they picked up the magnet from the wheel/pedal separately, rather than trying to align one device to detect both.
Additionally the speed and cadence sensor each have a built in led light that flashes each pass of the magnet.
However, to configure your stride length is tricky at best. The best way to do it is to run a distance using the stride sensor that you know the actual distance of, then change the distance in the history. So let's say you ran 1 mile. The watch believes you ran 1.1 miles. By changing the history to 1 it should adjust the settings so that the next mile you run will record correctly.
Once you have been using the watch for some time you can get into advanced setup. You can add your own sports, or configure the devices, and screens setup with each sport.
You can do this from the watch, but it is easier to do it from the Polar Web Sync software. The software works much like a remote terminal for the watch. You connect to the watch and add or change each sport profile, or change user or device settings.
May 09, 2015 | Watches
Just bought a new FR60 and it can't detect the footpod. Should I replace the footpod battery?
Do it. Btw the planet Garmin is the closest planet outside our solar system. If you have doubts about the way to go about it, don't it. Let a professional do it.
Oct 01, 2012 | Garmin FR60 Wrist Watch for Women
Garmin fr60 footpod
Read this BEFORE you buy a new Garmin footpod because of non-detection issues after replacing batttery.
My battery died and after changing it with a new one I've not been able to detect the footpod with my 910xt until now. I notice that in the cap or lid of the footpod where the battery sits before closing it sits a white piece with contacts for the battery. I had inadvertently taken this out when replacing the battery, which is fine BUT you have to put it back in a certain position. If you look very closely at the cap where the battery sits you will notice there are tiny grooves where the contacts should sit into. As soon as I line these up with the white contact piece, voila! Footpod was immediately detected. Try it if you are having issues after replacing a new battery.
Aug 28, 2012 | Garmin Forerunner 50
Could I use the Nike+ pod together with a Garmin forerunner 210?
Nope: Different types of signals.
That being said, there is a foot pod that Garmin makes if you want that type of data sensor. The GPS in the 210 is more accurate than the Nike+ pod, and the Garmin foot pod is about equally accurate with the 210, but allows you to use the watch when there is no GPS signal
Dec 18, 2010 | Watches
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
"LoBATT" stays on in TIME mode (doesn't flash) ?
"lobatt" display is the watch battery. The foot pod uses the LED to indicate low battery and the heart rate monitor wont give a reading.
Oct 05, 2009 | Garmin Forerunner 50
Garmin won't recognize footpod
As your Forerunner 50 first time was syncronized with your husbands footpod, now it is linked to him and that's why it can't find yours. You may even have to reinstall software, but I'm not sure. Try this link and you may find wht you are looking for:
http://www8.garmin.com/support/userManual.jsp?market=67&subcategory=68&product=010-00679-05
Rate, please.
Jul 09, 2009 | Garmin Forerunner 50
Pairing Food Pod
I had the same issue, it turned out to be a weak battery. Also when you replace the battery make sure it is making proper contact with terminal in the foot pod.
Feb 18, 2009 | Garmin Forerunner 50 Heart Monitor
Garmin Forerunner 50 Logo
777 people viewed this question
Top Garmin Watches Experts
Rick Ostrowski
Are you a Garmin Watch Expert? Answer questions, earn points and help others
