Question about Lexmark X4650 InkJet Printer
How do i run the printer's Wireless Setup Utility on my computer to configure the printer with the new wireless settings. i have the lexmark X4650
    Genius:
  • 1,087 Answers
If you have already installed the printer software on your computer, try these steps:
Using Windows
  1. Go to Start menu.
  2. Click All Programs/Programs.
  3. Click Lexmark 4600 Series folder.
  4. Click Tools
  5. Click Lexmark Wireless Setup Utility. Follow the prompts on the computer screen.
Using Macintosh
  1. From the Finder desktop, double-click the printer folder.
  2. Double-click Lexmark Wireless Setup Assistant.
  3. Follow the instructions on the computer screen.
If you have not installed the printer software yet, refer to this article from the Lexmark website for the setup guide. How to Install the X4600 Series on Wi-Fi Network. Hope this helps.
If you need additional assistance, please contact Lexmark technical support. Thanks.
Posted on Nov 12, 2010
My wi fi orange light is blinking on my lexmark x4650 printer
The blinking WiFi light on your printer indicates either your printer is trying to communicate with your wireless network or your printer is not connected at all. For a quick fix, try to disconnect your printer from the power outlet. Power cycle your router and reboot your computer. Then, power on your router first, then your printer and lastly your computer. Check the WiFi light on your printer. If it goes to a solid green, that means you are connected back in your network. If not, you may reset your printer's wireless network adapter to its default settings. From the printer operator panel, press the Setup button > Network Setup > Reset Network Adapter to Default. The WiFi light on your printer will momentarily turn off then back on solid orange. Then try to run the Lexmark Wireless Setup Utility on your computer to reconfigure your printer to connect to your wireless network.
I hope this helps.
Nov 20, 2011 | Lexmark X4650 All-In-One InkJet Printer
How to stop wi fi from flashing orange on my x4650 lexmark printer
I hope this helps.
Nov 20, 2011 | Lexmark X4650 InkJet Printer
Hi their, im matt Right, i reinstalled everything on my computer because i wanted to start a fesh installation. Im running windows 7 ultimate 64bit. I have tried to reinstall my printer but no look. I...
Check if your printer is still connected to the same network as your computer. Refer to this article: How to Print the Network Settings Page on X4600 Series All-In-Ones (AIOs). If you the printout, check the SSID and other network information. If printer still belongs to your network, then it could be a firewall issue. Make sure to allow all Lexmark and printer communications in the program rules/permissions for your firewall. If printer doesn't belong the same network as your computer, then you need to reset the printer's wireless network adapter and re-launch the Lexmark Wireless Setup Utility. How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults
May 29, 2011 | Lexmark X4650 InkJet Printer
My printer is connected to another wireless network which is not the same as my laptop how do i connect it to the right one?
I`ll guess You`ll have to connect your PC to the printer with the use of a usb cable.
Then run the Lexmark software (Lexmark printer home) or similar (don`t know what you are using?)... Go to "settings"; and choose wireless setup utility. You`ll have to manually set the SSID (the wanted wireless network) and the WIFI password for this network. Hope this will help.
May 23, 2011 | Lexmark X4650 InkJet Printer
After the power went out and came back up the wireless printer is orange and i reinstalled all the drivers on all the laptops, but it wont communicate with the printer lexmark x4650
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Frequently, issues are caused simply by a break in the signal sent from PC to printer or vice versa. Unplugging and re-plugging the printer allows the small amount of on-board memory on the printer to be cleared, with the result that the PC recognizes the machine properly. Programs continuing to run in the background of the operating system (OS) can cause the signal to be lost. Rebooting the PC ends all programs that may be running and makes a 'clean' start, allowing the signal to be detected.
If connection is still not established, try to print the network settings page to determine if your printer is still registered in your wireless network. 1. Press Setup (pattlnk_632008_2048-x4650stup.jpg) on the printer operator panel. 2. Press the right or left arrow button until Network Setup is displayed, and then press(pattlnk_632008_2052-x4650ok.jpg). 3. Press pattlnk_632008_2052-x4650ok.jpg at Print Setup Page. 4. Press pattlnk_632008_2052-x4650ok.jpg when prompted to Load Paper. 5. Press pattlnk_632008_2052-x4650ok.jpg. The network settings page will now print.
Check the SSID and the IP address on the settings page. If info shows that your printer is no longer registered, you may need to reset the wireless network settings of the printer.
Follow steps 1 & 2 above, 3. Press the right or left arrow button until Reset Network Adapter Defaults is displayed, and then press pattlnk_632008_2052-x4650ok.jpg. 4. Press the right or left arrow button to display Yes, and then press pattlnk_632008_2052-x4650ok.jpg. 5. Observe the message"Clearing Wireless Settings". The WiFi light will momentarily turn off then lights up solid orange. You can now launch Wireless Configuration Utility or Wireless Setup Assistant (Macintosh) to reconfigure your printer to connect to your network.
Sources: How to Print the Network Settings Page on X4600 Series All-In-Ones (AIOs) & How to Restore the Network Settings on the X4650 AIO to the Original Factory Defaults.
May 11, 2011 | Lexmark X4650 InkJet Printer
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
Apr 07, 2011 | Lexmark X4650 InkJet Printer
How to turn on wifi
Configuring the optional internal wireless print server
If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
wireless print server" in the "Setting up the printer" chapter.
2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
3 Click Wireless Setup.
4 Click Start.
5 Follow the instructions on the computer screen.
6 Click Finish to complete the installation.
Also here is the link to the setup guide and user manual
click here
configuring the wireless is in the setup guide
Oct 18, 2010 | Lexmark X3550 All-In-One Printer
Ive recently changed the password on my wireless network and now my printer keeps flashing orange which means it wont connect to the wireless. From reading a similar post i saw you recommeded to reset the...
To reset the printer's wireless network adapter:
  1. Press Setup(wrench icon).
  2. Go to Network Setup, press OK.
  3. Go to Reset Network Adapter, press OK.
WiFi light will temporarily turn off then will turn on solid orange. Now, run the printer's Wireless Setup Utility on your computer to configure the printer with the new wireless settings. You will need the USB cable temporarily to successfully configure the printer. Thank you for choosing Lexmark.
Sep 10, 2010 | Lexmark X4650 InkJet Printer
I have a lexmark x4690 wireless printer. I had to change my bell sympatico dsl router. Now I need to change the network on my printer but I can't. I no longer have the driver cd and I tryed downloading...
You will need to reset the printer's wireless network adapter then reconfigure it with your new wireless network settings. On the printer's operator panel, press Setup button > Network Setup > Reset Network Adapter > hit Ok. The Wifi light will momentarily turn off then will turn on orange. Once you have that, run the Lexmark wireless setup utility on your computer to configure the printer with your new wireless network settings. Thanks.
Aug 04, 2010 | Lexmark X4690 Wireless InkJet Printer
I can print wireless or with a usb connection yet yesterday i could, the only thing that has changed is i have a new router
Hi If you replaced your router your security settings and all other settings will be different. You will need to do uninstall the printer and install it back again or use the Wireless Printer Setup Utility. You can find that by going to start -> all Programs -> Lexmark -> Wireless printer setup Utility and follow the steps to configure your printer on the new router. I believe that you will have to connect the printer via USB to your computer to do this procedure.
Jan 10, 2010 | Lexmark X4650 InkJet Printer
Lexmark X4650 InkJet Printer Logo
975 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
