Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Where is the lamp reset button on my panasonic PT-50LC13
  • 8,197 Answers
To reset the lamp on the Tv you need to Hold down vol - on tv and hit either PIP or SPLIT on remote Good Luck
Posted on Nov 12, 2010
Panasonic PT-50LC13 50 blinks 8 times at power button
hi, make sure the lamp is fitted securely and the lamp cover as well you may need to reset the lamp counter hope it helps
regards
shaun
Nov 27, 2011 | Panasonic PT-50LC13 50" Rear Projection...
How do you reset a "lamp hour meter" on a panasonic pt-50lc13-k? Lamp was replaced but this keeps coming on screen. appreciate any help! THX
here is the link that shows you how to replace it hope this was helpful
http://www.fixyourdlp.com/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Sep 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How to reset lamp timer on pt 50L C-13
Their manual says:
After lamp replacement, you must reset the lamp
time. Refer to the instructions enclosed with the
lamp unit (Part No.: TY-LA2005).
lamp unit (Part No.: TY-LA2005)."
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC13
Aug 09, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the lamp on a panasonic tv pt=50lc13 ?
I think you hold down the volume - button on the TV and the SPLIT or PIP button on the TV remote at the same time for 5+ seconds. Becareful that your arm does not block the remote from getting to the TV. A message will appear when you are successful. Best wishes.
Jul 13, 2010 | Panasonic PT-50LC13 50" Rear Projection...
PT-50LC13 reset lamp timer
Replaced the Lamp, on my PT-50LC13 pan TV. But cannot reset the timer because the screen does not light up. and the instructions say to hold down the -Vol button and the pip button. But which one? there are 3 buttons with the word PIP
Apr 02, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How do you remove the lamp
To replace lamp in Panasonic PT-50LC13 tv, please follow this...
1- Place your fingertips under the front cover and pull it from the projection display.
2- Loosen the lamp cover screw using a screwdriver.
3- Using a screwdriver, loosen the lamp unit screw.
4- Grasp the lamp unit handle and slowly pull the lamp unit from the projection display.
5- Put new lamp and fix things in reverse order.
Now need to reset lamp timer as follows,
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneously for more than 5 seconds.
When lamp timer will reset, tv sill show "lamp time was reset to 0" message.
Hope this info will help you.
Thanks.
Feb 25, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I have replaced the lamp on my Panasonic PT-50LC13 but now it says I need to reset the lamp timer. How do I do this?
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds in
power on condition.
Sep 28, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I just replaced the lamp in my tv and now it shuts
You probably have a defective new lamp. Did you put the lamp door back on?
Aug 08, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
138 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
