Question about Ovens
Cleaned oven earlier today on our GE Profile Model JGSP40AES2AG. Now the range will not stop beeping and shows an F 1 fault code. Oven will not heat, turn on, etc. What do we do?
  • 2,299 Answers
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On some ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Posted on Nov 12, 2010
Keep getting F1 error code (constant beep) on my GE profile oven.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
&%YR
May 11, 2010 | GE Profile JTP56 Electric Double Oven
%#$TEF
Mar 18, 2010 | GE Profile JTP56 Electric Double Oven
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
The upper and lower oven will not turn on there is power to it and clock and oven lights work there is an FO red light that comes on and beeps and flashes
Built In Oven Fault Codes
F0 or F1 - Failed transistor in control - If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Sep 21, 2009 | GE Profile JTP56 Electric Double Oven
GE Profile Double Oven F1 Error
&*&^%rt
Aug 08, 2009 | GE Profile JTP56 Electric Double Oven
F7 Code on my GE Profile Oven
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
GE FTP18
I have the same problem, although my oven is 3 years old. I am having the door latch replaced today. cost $240. The repair company that I contacted sid that these ovens are their bread & butter!!! If I could afford it I would ship all of my GE appliances(which are only 3 years old mind you) to them and tell them to shove them!! I alreadt spent over $200 on my GE dishwasher which at the time was only 1 1/2 yearsd old.Did you clean the oven before the error code started flashing?laurieslovett@yahoo.com
Jun 25, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile 2002 Wall oven JCKP18BA2BB Code faults
Try my solution for the F7 problem at the following link:
http://www.applianceblog.com/manuals/Dreaded_F7_Problem.pdf
I have shared this with over 1500 folks and most report success.
Please let me know. Also, what is your model number, how old is your oven and where are you located? I am making a study of this problem. You can email me at: hutchipop@yahoo.com
Jan 08, 2008 | Ovens
Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Jun 07, 2007 | GE Profile JTP56 Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
