Question about HP Officejet 7210 All-In-One InkJet Printer
Printer will not turn on, all power sorces are good. is there a fuse that could be shot and if so where
    Guru:
  • HP Master
  • 2,178 Answers
Check the power adapter first to verify it is producing DC voltage to the printer, with a volt meter. If it's ok then click below for solutions: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01321436&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=391153
Posted on Nov 12, 2010
No Power. Blown fuse or dead power supply?
Replace the power supply. Definately not the fuser
Jul 23, 2017 | HP LaserJet 1200 Printer
Heat will not turn on but fan works
if no fuse its in off on switch or a bad wire from power sorce or plug in itself
Oct 14, 2013 | Sunbeam Heating & Cooling
MY EPSON ME 340 SHOT OFF DURING PRINTING AND WON'T POWER ON..
Two possibilities of dead part : power suplly or main board. Check output voltage of power supply, it must be around 42 volt. Check the fuse in main board. Good luck.
Jan 29, 2013 | Epson Office Equipment & Supplies
I HAVE A EMERSON TV AND IT WONT TURN ON, IS THERE A RESET BUTTON?
No reset or circuit breaker on this type of set--if you can safely open it follow the power cord inside to the fuse and check it first.
Nov 07, 2012 | Televison & Video
My power outlet in my 1995 Ford Mustang has stopped working. I replaced the fuses under the hood of my car with 20 amp fuses for the issue and still the power outlet isnt working. Is there something wrong...
first un plug the lighter use a test light ground 1 end and see if thare is power ive seen alot of the lighters be bad for what ever the reason if you have power to the wire with the key on its the lighter if not the best thing to do is put in a new wire to the fuse box that comes on with the key thare are always extras in the fuse box
Apr 22, 2011 | 1995 Ford Mustang
No rear brake lights, but 3rd one works. Fuses good, relays good, pedal area good, bulbs new, and new circuit board. What now
Im not sure the make ,year or model of your car but , the next thing to check as you already checked the fuses and brake light switch would be to check the wires going into the socket, the sockets go bad often so using a test light the next thing is to check the power and ground right before the socket, check the wires at the end before they enter the socket, if you have power and ground then the sockets are bad. you also know that the brake lights and the third light use diffrent power sorces, so just because the third light works doesnt mean the fuse is good for the other brake lights,good day,
Mar 29, 2011 | Chevrolet Silverado 1500 Cars & Trucks
The radio and power source blew when I used a compersor in the power sorce. Where is the hidden fusse 2001 dodge grand carivan sport modle 3.3 engin
these fuses are located under the hood in the engine compartment, you will see the fuse box there in the engine compartment remove the cover and check the fuses, the cover will list the correct locations of the fuses.
Oct 12, 2010 | 2001 Dodge Grand Caravan
Achiever Shredder PS150 not turning on.
You can take apart the shredder, and see if there is a fuse in this model. The fuse should have a thin wire running all the way across the fuse. If the wire is broken or burnt, replace it with same size fuse.
If the fuse is good, get a voltmeter, and test the connection where the power supply/high-voltage transformer (the box that has the plug-in attached to it) atttaches to the main circuit board. See what the voltage rating is. If there is no reading or barely any reading, then the power supply/voltage transformer is shot.
Feb 07, 2010 | Office Equipment & Supplies
Power windows, interior lights and remote key entry dont work
check the fuses.Maybe inline fuse on the alarm usually lights and sunroof run off same circuit
Jul 12, 2009 | 2000 Volkswagen Jetta TDI
HP Officejet 7210 All-In-One InkJet Printer Logo
44 people viewed this question
Seeker5211
Seeker5211
