Question about GPS
My new 2011 Nissan Rogue's dashboard computer temperature indication light keeps blinking (ex. 8 degrees celsius). When I first drove the car yesteday, the temperature indication was steady. How can I fix this please? Thank you kindly.
Go to where the dash board is and you will find a nob that you can push that will show you different settings. Keep pushing until you see settings. Push in the knob, you will see "Warnings" push in the knob to select "Warnings" and from there you will be able to turn off the warning for the temperature gauge.
Posted on Nov 17, 2010
  • 869 Answers
You just need to select the warning option in the menu which u can see somewhere near dashboard.
Posted on Dec 30, 2010
I just bought a brand new 2017.5 Nissan Rogue . I drove it home and parked it. Turned it off . 2 hours later, The park (P) indicator light is still illuminated. Is this normal?
Look in your manual I would think it's for safety reasons meaning the car is parked and in perk and can't roll away just thought I'd throw that in anyway please just look in your manual
Oct 28, 2017 | Nissan Cars & Trucks
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
How to switch temp. readings from celsius to degrees?
Celsius IS a temperature measured in degrees, as is Fahrenheit.
I don't know about your rig, but my guess is that you can hold down the menu button or go to "set up". Get the temp to flash, push the up/down button until the change. If you are needing to make a manual calculation, Celsius is changed to Fahrenheit by multiplying the reading X9, dividing that by 5, and adding 32 to that number.
Ex== 30 degrees C to F is 30X9/5+32= 86 degrees.
Oct 19, 2014 | 2015 Jeep Wrangler
What does the wrench warning light on my dashboard of my 2012 nissan rogue?
its time for a service. or the mechanic who last serviced the car did not reset the service light counter
Jul 23, 2014 | 2012 Nissan Rogue S 4dr SUV 2.5L 4-cyl....
Left turn signal on 2011 Nissan Rogue blinking fast
Check all the turn signal bulbs. The most common reason for fast blinking is a blown bulb. Check they are all working then remove each one in turn to check the connections are clean and dry. If they are all ok your looking at it being a wiring issue.
Feb 23, 2013 | 2011 Nissan Rogue
When the temperature drops below 38 degrees on my brand new Rogue a "Dangerous Temperature warnng appears and then the tempearture starts flashing. How do I get the flashing to stop?
I want to answer this question without sounding like a smart a**, but if it's brand new, can't you go to the dealership and let them deal with it?
Oct 28, 2011 | 2011 Nissan Rogue
What type of oil grade should i use in my 2001 audi 2.8 a4 quattro..this car came with no owners manual,and its time to change..thanks
Engine oil capacity with oil filter replacement = 6.0 litres.
Oil grade for 2001 Audi A4 Quattro 2.8
1. SAE 5W-30 / 5W-40, VW 502.00 - all temperatures.
2. SAE 10W-30 / 10W-40, VW 502.00 - all temperatures.
3. SAE 5W-50, VW 501.01 - all temperatures.
4. SAE 10W-50 / 10W-60, VW 501.01 - all temperatures.
5. SAE 5W-30 / 5W-40, VW 501.01 - bellow +15 Celsius degrees.
6. SAE 10W-30 / 10W-40, VW 501.01 - bellow +15 Celsius degrees.
7. SAE 15W-40 / 15W-50, VW 501.01 - above -15 Celsius degrees.
8. SAE 20W-40 / 20W-50, VW 501.01 - above -15 Celsius degrees.
LONGLIFE engine oil:
1. SAE 5W-30, VW 504.00 - all temperatures.
2. SAE 0W-30, VW 503.00 - all temperatures.
Please do rate my response. Thanks!
Jan 26, 2011 | 2001 Audi A4
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
GPS Logo
2,851 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
