Question about Audiovox GMRS3082CH Two Way Radio
My radio is stuck on channel 2 and it makes a loud no signal sound , is there a reset button, How can i fix it?
So first unscrew all the screws there is going to be a label that says t8fj and blow beside that then take the pieces and throw them into the garbage and go to walmart target bestbuy future shop or anywhere and buy a new one cheapskate
Posted on Nov 12, 2010
One walkie talkie has static on every channel
It sounds like your monitor button is stuck and you are hearing the white noise. Try pressing the monitor button on your other radio and see if the noise is the same. If so, your button is stuck. If not...
Sometimes a lot of static can be an indication of a bad or poorly charged battery. To check for this trade batteries with your known good radio and see if it solves the problem.
Dec 27, 2013 | Motorola Walkie Talkie 2-Way Radio
MY BK EPH5102X makes a ringing sound when I push the PTT button. I have programmed several channels into the radio and that all seems fine, but it does the ringing sound on ever channel whether programmed...
It thinks the channel is "busy" when you hit the button. Set the squelch control until it doesn't hear a signal if there's no intelligible signal present, or set the CTCSS tones to a valid value for your system. The EPH is a very good radio, but generally takes an experienced technician to program it properly.
Sep 17, 2013 | Radio Communications
My 2 way radio is not working. When I put batteries in and turn it on, one turns on normally but when I trie to press the talk button it looks like it will work but makes a sound like when a phone signal...
when you press the PTT button it takes much current to operate if it didn't get much current it sounds a beep sound try it by fully charged battery if not you have to replace your battery
Sep 05, 2011 | Cobra FRS 225 (14 Channels) 2-Way Radio
I just bought a 2007 Dodge 3500 Laramie and signed up for Sirius radio. I gave them the 12 diget number that came up on the radio screen (channel 184) and when they tried three times to activate it nothing...
I bought a used 2008 Ram 1500 SLT Sport; satellite would stay stuck on channel 184 with no sound, etc.
Solution: Disconnect negative wire from vehicle battery; wait 1-hour then reconnect. This clears satellite radio cache (a.k.a. hard reset).
Turn on satellite radion; Call Sirius support to send activation signal. Wait on phone with tech support; may take them 2 - 3 tries to get signal to take on radio.
Aug 21, 2010 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
I have a 2007 dodge ram pickup with sirius already built in. When I hit the sat button it is on channel 184 and there is no sound. I cant change the channel and the volume control will only let me turn it...
Hit eject button and clock button at same time. Ur Id number will show up. It will only show 4 numbers at a time. Hit seek button 2 more times to get the rest of the numbers
Jul 07, 2010 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Radio Schack converter doesn't program Ch: 25 like Magnavox!
Returned product to dealer. That fixed my proble.
Thanks...
Aug 19, 2009 | Philips Magnavox 20MT133S 20" TV
Constant RX mode on Cobra Microtalk Walke Talke
I have the same walkie talkies and on mine I can hold down the mode/lock button and it will come off of the Rx mode. Also, you should be able to press the talk button and it will come off of the Rx mode.
Jul 06, 2008 | Cobra PR4100-2WXVP 2-Way Radio
Stucxk on vibrate
As per instructions of the manual:
"...Your microTALK® radio can alert you to incoming signals by
sounding an audible call tone, by vibrating silently or both. To change call settings:
1. Press the Lock/Mode button until the Call Setting icon flashes on the display. The current setting (“01” vibrate + ring, “02” vibrate only or “03” ring only) is displayed.
2. Press the Channel Up or Channel Down button to change the call setting.
3. Choose one of the following:
a. Press the Lock/Mode button to enter the new setting and proceed to other functions.
b. Press the Hi•Low/Enter button to enter the new setting and return to Standby mode
Should you need a copy of the manual, it is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 16, 2008 | Cobra 22 CHANNEL 2-WAY RADIOS
Rolling channels and bad sound on one channel
One channel with bad sound is most likely the station/cable or satellite provider at fault. With the channels changing on thier own look for a stuck button on the TV set such as the channel up or down. You might try unplugging the TV for 2 minutes and then trying to see if resetting fixes it.
Dec 01, 2007 | iLO 3200 32 in. LCD Television
Clarion SIRIUS Radio Receiver - Not Receiving All Subscribed Channels
My DX445 does the same thing. Here's my method for fixing it, it should work for any similar Clarion receiver:
1. If possible, make sure the radio is turned off when disconnecting the battery. If the radio turns itself on when the vehicle is restarted (for example after jump starting or battery disconnect for a few seconds only), turn the radio off.
2. Disconnect the battery by removing the negative battery cable from the battery. Leave it disconnected.
NOTE: Car batteries can be dangerous things. If you're unsure how to do this safely, get an experiences mechanic to help you.
3. Reset the radio. On my radio this is done by removing the faceplated, and pressing a tiny button for 30 seconds. Your radio may be different.
4. After waiting at least 20 minutes, reconnect the battery.
5. My radio displayes 'System Check -- Press Power'. After pressing the power button, the display reverts to the clock.
6. Turn on the radio. It should work fine on the broadcast bands.
7. Select 'Sirius'. The radio should display 'Updating'. Don't touch anything until the radio finishes its update phase. When it's done, it should tune to Sirius channel 1 and play as normal.
8. This should restore normal tuning. reset your presets and preferences.
What seems to happen is that the radio gets stuck in a 'Category Select' condition, but not all the categories will load, and manual tuning will not allow, say, Radio Classics to play when the radio is stuck in Pop mode.
On occasion (maybe 1 time out of 10), the radio hangs while doing the 'updating' in Sirius mode. If this happens, just shut off the radio and start over. I've never had to do the brute force reset more than twice since I stumbled on this method.
Aug 11, 2007 | Clarion (NAVSIR) SIRIUS Radio Receiver
Audiovox GMRS3082CH  Two Way Radio Logo
Top Audiovox Radio Communications Experts
eradiostore
eradiostore
john milligan
Computer Repairing
Computer Repairing
Are you an Audiovox Radio Communication Expert? Answer questions, earn points and help others
