Question about Samsung CLP-315W Laser Color Printer
I have a CLP-315W that a friend gave me. It prints fine with no problems. However the red light blinks slowly all the time. The printer seems to think the color toner cartridges are empty. Since if I print the configuration page it says that all three color cartridges are empty. However if I swap the color cartridges with a CLP-315 that I also have, the 315W ones read 95% and now the CLP-315 ones read 0% so it's not the cartridges. The black cartridge reads fine, and, as I said, the printer prints in color and b/w just fine. Is there a sensor or something that might cause this, or do I just live with it. Thank, Greg
  • gregw79 Nov 12, 2010
    I thought about it being a contact problem, except for the fact that it's doing it on all 3 color cartridges only.
  • 922 Answers
Just as you thought, your printer has a dirty or failed ink level sensor.
You should be able to clean it if it is dirty. First, UNPLUG THE PRINTER. Now look at the cartridge and find the metal contact points which allow it to communicate with the printer. Now find their counterparts in the printer and clean them. A Q-Tip lightly moistened with alcohol should remove any ink build up.
It is rare but I have seen printers with optical ink level detection. Look for an optical sensor. If you find one make sure it is clean and unobstructed.
If it has failed it is not worth fixing. Just ignore the light and just keep an extra cartridge on hand.
I hope this helps. Good luck!
Posted on Nov 12, 2010
  • 4,472 Answers
"blinks red each LED lights red Each toner cartridge is almost empty. You can print, but the quality is not reliable."
Most likely it could be a dirty contact or something a long those lines. I would just keep printing until there is a quality issue then you would know the cartridge is empty. I would just live with it and use it until you have a real problem.
Thank you,
Lee
  • Lee A.
    Lee A. Nov 12, 2010
    the toner uses a microchip that senses whether it is empty or not. So it's possible the printer isn't reading these properly. As long as you make sure not to run them totally empty you won't have a problem. Please reconsider and accept/rate my solution appropriately. If you need further assistance I would be glad to help you.
    Thanks,
    Lee
Samsung CLP-315w blocked after page count reset
Dear
either you buy the toner chips and image unit chips or reprogram the 24c04 on MPBA to factory value.
Thanks.
Jul 20, 2014 | Samsung Office Equipment & Supplies
Samsung clp 315 warm up and don't print it all
Dear Pl. setup samsung EASY PRINTER MANAGER or SMART PANEL, command a test print it will indicate the right problem with the printer.
Mostly the exit sensor lever may not returned to it home position after getting the print out, so after one page printing it indicate error.
Also check the paper setting in the printer driver and actual paper used Match it.
Thanks.
Nov 19, 2011 | Samsung CLP-315W Laser Color Printer
Switch on the printer and it goes through its cycle and a red light comes on. With the black toner blinking. I have changed the toner switched on and this time just the red light comes on. Samsung...
unplog the printer from electrik for 10 minutes and try aggain, if the problem still occure try to update the soft ware using the web side from samsung for this printer, this should solf the problem.
Apr 18, 2011 | Samsung CLP-315W Laser Color Printer
Samsung CLP-315W Color Laser Printer will print only half page
http://www.fixya.com/support/t3934542-exit_sensor_problem_samsung_clp_315
Mar 23, 2010 | Samsung CLP-315W Laser Color Printer
The red light has come on - mid-way through printing, and nothing I do seems to rectify the problem. It won't print. Just got the blue and red lights on all the time
Many things can cause that, toner box full, fuser not heating, paper empty, toner empty, paper scraps inside, imaging belt used up, If the owners manual doesn't help you locate the problem you may need a shop. Samsung customer support can help too, you'll find their number on line.
Jan 25, 2010 | Samsung CLP-315W Laser Color Printer
My samsung clp-315w prints smudgy black lines
Cleaning my unit resulted in the solution of this problem. I removed the toner cartridges, the imaging unit, and the waste bin, opened the back door as well, and blew it out with "canned air". This will not solve all problems, but it is the right place to start. be careful to keep the imaging unit out of bright light when you you have it out of the printer.
Dec 06, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP-315W Laser Color Printer Logo
231 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
