My rear projection tv does not have a pitcure. It started out as a small black line at the bottom of screen. The screen is now all black. I do have audio but no video
  • denton1000 Nov 12, 2010
    It is a Toshiba. The model is TP50F61.
    Do you have any ideal what is causing this problem.
    Genius:
  • 1,622 Answers
All plasma an Lcd ts have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em. Good luck.
Posted on Nov 12, 2010
  • 15,935 Answers
What is the make/model of the unit please?
Thanks!
When the screen is dark there are lines that run back and forth across the screen which is only noticable when pitcure is dark immage.
the screen bias needs to be turned down-ehind the front cover which is behind the grille there is a small black square about 3 inch square 6 little knobs sticking out 3 say in small letters screen and 3 say focus, don't adjust the focus just the screen for the coresponding color that shows up when picture is dark.best way to do this is darken the room and put it on video input with no signal if lines are white slowly
adjust 1 color after the other counterclockwise untill
lines disappear if only 1 color shows then only adjust the knob with the matching color. this is a very fine adjustment, to much will make your auto focus stop working. check it after you are done
Jun 20, 2010 | Sony KP-51HW40 51" Rear Projection...
Screen turn green tv is 57 rear projection
Good Day,
It appears that you may have a green drive issue. Try adjusting the Sreen Control it is located in the front of TV.
1) Remove Speaker Grill (it just pulls off) start at one end, 2) Remove cover (5-6 screws), 3) Adjust control. The control is located on lower right side towards bottom. A small black device with 2 rolls of controls, adjust the center control on bottom row counter clock wise, until you get a black and white picture.(adjust with color control to min).
If this does not work you light bulb (CRT) is bad about a $750.00 repair.
Good Luck, Big Irish.
Dec 07, 2009 | Toshiba 57H83 57" Rear Projection HDTV
Blue line at bottom of TV Screen
Check out the Sony Websites. They extended warranties on their Rear Projection TV's. I came across this website
http://sites.google.com/site/sonylcdrptvproblems/sonyrearprojectionlcdtv-opticalblock#TOC-Summary-of-Sony-warranty-extensions
If you bought your TV in Canada, check out their e-support website/news bulletin
Dec 04, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Rolling green horizontal bar from top to bottom,then bottom to top and so on. sometimes rolling fast,sometimes slow and sometimes the green bar stops in the middle of the screen.every once in a while the...
This TV needs a service adjustment done. Looks like a vertical or horizontal IC is failing. I'd go ahead, and shut off until services adjustment is made. Have you unplugged for a few minutes and plugged back in? However, I'd have a service tech look at it.
Oct 25, 2009 | Mitsubishi WS-48513 48" Rear Projection...
I have a small black line on my tv screen. I do
This is because of the horizontal deflection plates in ur tv...there is some problem in the receiver side of ur tv....make some arrangements in the cathode of the picture tube.
Apr 11, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green lines in pitcure
You need to have the TV repaired. That is a factor defect, look it up.
Sep 21, 2008 | Pioneer PRO-530HDi 53" Rear Projection...
60 inch philips magnavox
When you first turn on the tv, It goes from small picture to full screen and several corors around screen for a few minutes,I guess until it warms up? Could you please help? Thanks!
Mar 25, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
Top Televison & Video Experts
