Question about Microsoft Xbox 360 Console
I turn on the XBOX360 and the ring which normally indicates a controller is connected (green light) is flashing red. there is no signal to the TV
    Sergeant:
  • 389 Answers
I CAN FIX IT! There are links that show you how to repair this issue yourself (but they are not very clear and every thing is very fragile inside the XBOX 360) or you can contact me via reply on here and we can discuss the issue further as I recently repaired my XBOX 360 with the same issues and it works better than when was brand new.
or search google xbox 360 rrod and what do the lights mean
Posted on Nov 12, 2010
Tv will not turn on when tried on either tv or with remote green light flashes 3or 4 times then turns into red flashing light no picture or sound at all.Have tried changing batteries in the remote and fuse...
Hi.The signal lights red means the primary power of your tv is good and the signal lights green indicate the second power.If the green lights is flashing it means that they have shorted parts in the crt board.Maybe the problem is in the power section of the crt.Need for troubleshoot or repair the crt board.
Jul 03, 2011 | Panasonic Televison & Video
Tip
XBox360 error codes (Three Red Lights of Death, Red Ring of Death, X-Clamp)
Hi.
XBox 360 error codes are displayed with flashing lights in the ring of bi-color LEDs located around the start button, like in the picture below:
They are often called lights of death. The technical name from Microsoft is Light codes.
LEDs located around the start button can be green or red. When they get red it means that there is a problem.
When the XBox is operating normally The leds will be green. The number of green segments indicates the number of controllers connected to the Xbox.
Here a working Xbox with one and four controllers connected to the console:
If the lights are red instead of green, then there is a problem. Here the four common error codes:
A: The code in picture A, with only one red segment on and flashing on the fourth quadrant, means that there had been an hardware failure. The internal component failing is often not specified.
The light code is accompained by an error message on display, telling a numeric code that can better address the cause of the fault. The best thing to do is contacting Microsoft to find out the reason for the code. Depending on the code you may also be asked to perform a secondary error code retrieval procedure.
In the Example above E74 means that there is an hardware fault on video connections or GPU.
B: If the first and fourth quadrant LEDs are on, that means that there had been overheating. Internal fans, CPU and board must be tested.
C: General hardware failure. This means that the console detected an internal failure, but no error code is displayed on screen. Call Microsoft to get instructions on detecting secondary code or sending the console for repair.This error code is commonly called Three Lights of Death.
D: The last error means that there is a problem with the AV connection to the monitor or TV. The code is not displayed if you use HDMI connection, in that case you get an on-screen error code. Test using different cables. If that does not fix the problem, this error means that the XBox Gpu is fried. This error code is commonly called Red Ring of Death or RROD.
In the near future I plan to publish a new article explaining how to troubleshoot secondary error codes. In the meanwhile, if you need more support, you can ask a question to our experts or contact Microsoft.
Regards.
on Apr 08, 2010 | Microsoft Xbox 360 Console
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
Two red flashing lights on top and two green on bottom
Two red lights generally indicate hardware failure. Two green lights indicate two controllers are connected. Both green and red lights will not be lit at the same time. The green light in the middle indicates that the console is turned on. For more help deciphering red light flashing errors, see this guide HERE.
Feb 02, 2011 | Microsoft Xbox 360 Console
Orange LED indicator on the "Power Ring"
From the sounds of things you have a bad RF Board. This is the board that controls the syncing of your controllers, as well as your ring of light. If there is someone in your area that fixes the RROD they may be able to replace your RF board as well. I'd be happy to do it, but shipping would be almost the same cost as the repair. Contact me at Jordan@jordanselectronics.com for more info.
Jan 09, 2010 | Microsoft Xbox 360 Console
Three red lights flashing
If this is your Xbox 360 console you are referring to, then you need a repair. If you are under your 3 year warranty from MS go to www.xbox.com/support to fill out a repair request, otherwise look for someone in your area that has experience repairing the Red Ring of Death.
Jan 03, 2010 | Microsoft Xbox Console
Controller wont hook up with console ?
Is this a new controller?
Are the batteries new/recharged?
This is the sequence summary on where you are going to focus:
Step 1 - Controller
Step 2 - Console
Step 3 - Console
Step 4 - Controller
Step 5 - Both
Assuming your controller is a wireless version, Lets start!
Step 1 | Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
Step 2 | Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
Step 3 | On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
Step 4 | On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
Step 5 | After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Light indicator on console
Green light in the center- power is on
Green light on one quadrant - controller is connected
Four green lights rotating on four quadrants - ready to connect with controller
Light indicator on wireless controllers
No lights - no batteries
Green steady light on one quadrant - connected
Blinking green lights - its either its ready to connect or the batteries are dying
*Make sure that you have a fully recharged rechargeable batteries
*Make sure that you have a functioning/new non-rechargeable batteries
*If the steps above aren't working use another Xbox360 controller and follow the same steps.
If the new/working controller is connecting with the console this means that the previous controller is faulty - needs replacement.
If the new/working controller is not connecting with the console this may mean that the console is faulty - needs repair.
*NEVER TAMPER WITH ANY OF THE TWO AS TAMPERING WILL VOID EXISTING WARRANTY.
Nov 23, 2009 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
I keep getting three red rings in the part where it shows how may controllers are playing and i can't get any of my games to play or my controllers to work
Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console.
You can try one or two things.
1. Turn on your xbox and check to see if the power supply light is green. If it is green there is a problem with the system. If it is red it means you should check your connections and restart the xbox.
2. These rings have a tendency of meaning that there is a problem with the system itself. Most companies sell extra insurance to cover this "ROL" Ring of life. You can contact Microsoft by calling them. The number is usually listed on the back of the video game booklets.
I wish you the best and I hope this resolved your problem
Happy Gaming
http://support.microsoft.com/kb/907534
Oct 18, 2008 | Video Game Consoles & Games
4 FLASHING RED LIGHTS
4 red lights is not necessarily a hardware failure or ring of death. The cause is usually from AV cable not being detected or not connected correctly. The Eraser trick is good for Error 0102 make sure which error number you have! Suggested Solutions: 1. Try to connect and disconnect the cable and see if it makes any changes on the red lights status. Note that not inserting the AV fully will cause the 4 lights error to appear. 2. Make sure the AV Cable and the connector in the Xbox console are proper and there is nothing banded or twisted. 3. Try to connect it to a different monitor maybe this is where the problem is. 4. Find the metal area where it plugs into the console this is called the AV Pack metal area. Use a dry, lint-free cloth and wipe it. Then try to plug the AV again. * If you still can't make it to work and you have your warranty just send it in. If you don't have warranty I suggest trying the live chat support on Fixya!
May 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
35 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
