Question about Keurig B60 Coffee Maker
The pump is have trouble pumping water into the brewer.
! had the same problem,so I descaled it .Empty your holding tank Fill it with white vinegar run it 4 times then let it sit for an hour or so then clean your tank and fill with clean water run it through until the vinegar is out you should be good to go
Posted on Nov 13, 2010
Pump makes sound no water comes out
Use a pin to clean Port (Needle) it is clogged.
Mar 03, 2013 | Keurig B31 Red Mini Coffee Brewer Bundle
Keurig machine not pumping water.
Tube from Filter area clogged. Clean that first.
Jan 27, 2013 | Keurig B70 Platinum Brewer
After placing bottled water in the container, the unit sounds like it is pumping but no water.
If your brewer is not brewing the full amount selected, it may be caused by the following:
The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
First try to make a descale maybe repeat it the next day.
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Then try also this useful tip
http://www.youtube.com/watch?v=DqRs4Ott21s
Jul 03, 2011 | Keurig Platinum B70 Coffee Maker
Keurig Model 831 one-cup brewer seems to heat water, but fails to pump water from tank to brew.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jun 06, 2011 | Microwave Ovens
Our Keurig Elite barley pumps water through pods, without pods water pumps through fine. What is the problem?
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Jan 27, 2011 | Keurig B60 Coffee Maker
My keurig stopped pumping water through to make coffee. water just flows back into the reservoir.
heatman101
Jan 21, 2011 | Keurig Platinum B70 Coffee Maker
Pump does not prime, sometimes does not move water
I had a similar problem and I found the symptoms misleading! I used a pin to clean the upper needle and I found that after I did that the pump worked again. Not 100% sure it will work everytime, but cheap and worth a try!
Jul 03, 2010 | Keurig B60 Coffee Maker
No longer pumps water
I have fixed a couple of them by applying a thin layer of keg lube to the silicone flange underneath the water tank. Remove the bottom cover of the brewer and take out the two screws that hold the flange in place. This is where the pump draws water from the tank. Air can get in at that seal and it won't pump water if that happens. Keg lube will make it seal better. I got mine at Annapolis Home Brew dot com. Hope that helps!
Jun 23, 2009 | Keurig B100 Coffee Maker
Keurig B100 not pumping a cup of water through
After dismantling the B100 and trouble shooting the machine I determined that the hose leading to the air pump on the right side of the B100 allowed water to back flow into the motor. The small amount of moisture eventually caused the motor to fail.
I had to find a scrap machine, which most people that have bought this piece of equipment have just thrown it in the trash, and remove the motor from the opposite side which still functioned. Since it is designed to mount to a specific side I had to appoxy the motor into place. To keep the problem from occuring again I purchased a check valve from a local pet store and put it in-line with the motor.
This solved the problem at the source and has prevented moisture from getting into the motor. Now I am a proud owner of a Frankin Pot. It's alive!
Sep 15, 2006 | Keurig B100 Coffee Maker
Keurig B60 Coffee Maker Logo
196 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
