Question about Acer Aspire One PC Notebook
The laptop will not startup. It takes me to the boot screen, if i choose the Safe mode's it just totally does not work. if i click normal or last known working mode it just keeps on doing disk checks forever.. is there any way to fix it without sending it to the manufacturer
  • 516 Answers
If you know how to format your laptop so go ahead. But always keep in mind that when you format your laptop all of your data or files will be deleted. So i suggest to have a back up first. Manufacturers gives warranty for hardware not the software.
Posted on Nov 12, 2010
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
How to get off safe mode
Step 1
Getting out of Safe Mode may be both easy and complicated at the same time. The primary consideration is the reason why the machine is booting into this status. If it was user initiated, the easiest way is to click on the 'Start' button and select the 'Turn Off Computer' option.
Step 2
This will bring up the window with the 'Standby', 'Turn Off', and 'Restart' options. Choose either 'Restart' or 'Turn Off'. Upon rebooting or powering up of the machine, the Operating System should automatically load into Normal Mode. Take note that some users are misled into believing that the system is in Safe Mode primarily due to the incorrect setting of the video. If the system is in Safe Mode, it should be stated at the corners of the screen.
Step 3
If the system keeps on rebooting on Safe Mode, this is a possible indication of a problem in loading startup components. Reboot the machine.
Step 4
During the reboot process, press the 'F8' key to display the boot-up options. In this window, select the 'Last Known Good Configuration' option. The Operating System will attempt to locate the last settings that successfully loaded the Operating System.
Step 5
If still unsuccessful, allow the machine to boot into Safe Mode. Click on the 'Start' button and choose the 'Control Panel' option.
Step 6
Click on the 'Performance and Maintenance' category and click on the 'System' icon. This should open the System Properties window.
Step 7
Click on the 'Hardware' tab and click on the 'Device Manager' button. Check for any exclamation or question mark beside any entry. Reload the corresponding device driver for the erroneous component. Repeat Step 2; this should boot the system in Normal Mode.
Step 8
If the computer system entered Safe Mode via the System Configuration utility, then it can only boot in Normal Mode using the same tool. Click on the 'Start' button and choose 'All Programs'. Click on the 'System Tools' category and select the 'System Information' option.
Step 9
From the new window, click on the 'Tools' Menu and select 'System Configuration Utility'. Under the 'General' tab, select the 'Normal Startup' option.
Step 10
Click on the 'OK' button and restart the machine as described in Step 2. This will load the system in Normal Mode.
Aug 11, 2014 | Dell Inspiron 570 Mt Desktop Computer
How to safemood in asus x200m
Normally on start up screen bottom left should say press f2 for bios you should press f8
Jul 22, 2014 | ASUS NB X200MA-QSP2T-CB 11.6 Pentium N3520...
Blue screen
Which operating system you are using??
You can follow the given steps to avoid blue screen error..
Start Windows in Safe Mode:
Step1: Turn on your computer and press the F8 key repeatedly from your keyboard. You must press F8 before the Windows logo appears. It will display the Advanced Boot Options screen.
Step2: From Advanced Boot Options screen, choose Safe Mode option then press Enter.
Step3: If Windows loads and works fine in Safe Mode, a bad driver is probably causing the error. Uninstall device drivers and reinstall them. If Windows experiences issues in Safe Mode also, repair your hardware.
Startup repair:
Step1: Shut down your computer and then restart it in Safe Mode (see step1).
Step2: From Advanced Boot Options screen, select "Repair Your Computer" and hit Enter. Choose your preferred keyboard layout and then click "Next."
Step1: Click "Startup Repair", and follow the on-screen instruction .Startup repair can solve this problem.
System Repair:
Step1: Follow step1 and step2 from Startup repair section.
Step3: Now select system restore from the System Recovery Options menu. And follow the on-screen instruction to select a restore point.
**If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Jan 24, 2013 | Acer Aspire Computers & Internet
When I turn on my laptop it goes to a windows error recovery page and gives me the options to launch startup repair or start windows normally. When I launch the startup repair my screen goes black and only...
Hello.
Sounds like the Windows Recovery Partition is corrupted or your hard drive may be faulty.
But, first try to boot your system in Safe Mode (press F8 repeatedly as it boots) and choose Safe Mode or Last Known Good.
If it still doesn't boot properly, try the diagnostics to determine if a hardware problem - boot your system and press F 12 (or F2) repeatedly.
Hope this helps.
Jan 11, 2012 | Toshiba Computers & Internet
How do I get my IBM computer windows 2000 out of safe mode??
Hi,this should help.Don't forget to rate.... Getting out of Safe Mode may be both easy and complicated at the same time. The primary consideration is the reason why the machine is booting into this status. If it was user initiated, the easiest way is to click on the 'Start' button and select the 'Turn Off Computer' option. This will bring up the window with the 'Standby', 'Turn Off', and 'Restart' options. Choose either 'Restart' or 'Turn Off'. Upon rebooting or powering up of the machine, the Operating System should automatically load into Normal Mode. Take note that some users are misled into believing that the system is in Safe Mode primarily due to the incorrect setting of the video. If the system is in Safe Mode, it should be stated at the 4 corners of the screen. If the system keeps on rebooting in Safe Mode, this is a possible indication of a problem in loading startup components. Reboot the machine. During the reboot process, press the 'F8' key to display the boot-up options. In this window, select the 'Last Known Good Configuration' option. The Operating System will attempt to locate the last settings that successfully loaded the Operating System. This feature was introduced under the Microsoft Windows 2000 Operating System platform and retained in newer Microsoft environments. If still unsuccessful, allow the machine to boot into Safe Mode. Click on the 'Start' button and choose the 'Control Panel' option. Click on the 'Performance and Maintenance' category and click on the 'System' icon. This should open the System Properties window. Click on the 'Hardware' tab and click on the 'Device Manager' button. Check for any exclamation or question mark beside any entry. Reload the corresponding device driver for the erroneous component. Repeat Step 2; this should boot the system in Normal Mode. If the computer system entered Safe Mode via the System Configuration utility, then it can only boot in Normal Mode using the same tool. Click on the 'Start' button and choose 'All Programs'. Click on the 'System Tools' category and select the 'System Information' option. From the new window, click on the 'Tools' Menu and select 'System Configuration Utility'. Under the 'General' tab, select the 'Normal Startup' option. Click on the 'OK' button and restart the machine as described in Step 2. This will load the system in Normal Mode.This is all that can be done hope this helped.
Nov 17, 2010 | Computers & Internet
How to get out of safe mode
Step 1 Getting out of Safe Mode may be both easy and complicated at the same time. The primary consideration is the reason why the machine is booting into this status. If it was user initiated, the easiest way is to click on the 'Start' button and select the 'Turn Off Computer' option. Step 2 This will bring up the window with the 'Standby', 'Turn Off', and 'Restart' options. Choose either 'Restart' or 'Turn Off'. Upon rebooting or powering up of the machine, the Operating System should automatically load into Normal Mode. Take note that some users are misled into believing that the system is in Safe Mode primarily due to the incorrect setting of the video. If the system is in Safe Mode, it should be stated at the corners of the screen. Step 3 If the system keeps on rebooting on Safe Mode, this is a possible indication of a problem in loading startup components. Reboot the machine. Step 4 During the reboot process, press the 'F8' key to display the boot-up options. In this window, select the 'Last Known Good Configuration' option. The Operating System will attempt to locate the last settings that successfully loaded the Operating System. This feature was introduced under the Microsoft Windows 2000 Operating System platform and retained in newer Microsoft environments. Step 5 If still unsuccessful, allow the machine to boot into Safe Mode. Click on the 'Start' button and choose the 'Control Panel' option. Step 6 Click on the 'Performance and Maintenance' category and click on the 'System' icon. This should open the System Properties window. Step 7 Click on the 'Hardware' tab and click on the 'Device Manager' button. Check for any exclamation or question mark beside any entry. Reload the corresponding device driver for the erroneous component. Repeat Step 2; this should boot the system in Normal Mode. Step 8 If the computer system entered Safe Mode via the System Configuration utility, then it can only boot in Normal Mode using the same tool. Click on the 'Start' button and choose 'All Programs'. Click on the 'System Tools' category and select the 'System Information' option. Step 9 From the new window, click on the 'Tools' Menu and select 'System Configuration Utility'. Under the 'General' tab, select the 'Normal Startup' option. Step 10 Click on the 'OK' button and restart the machine as described in Step 2. This will load the system in Normal Mode. Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 30, 2010 | Computers & Internet
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
I have an hp compaq nx4800 laptop which diplats ounce on booting and then off,i dont its problem
try to go in safe mode or choose last known good configration
In safe mode, go to start->run, type in msconfig, and the system configuration window will come up.
First, try clicking on startup and say disable all, then say apply. Try restarting your computer and loading it normally, and see if it lets you get anywhere. If it does, you can go back into msconfig and start enabling startup items again until you find the one that is messing you up.
If that didn't work, try going back into msconfig, keep all the startup items disabled, and click on the services tab. check the box saying hide all microsoft services, then click on disable all, and hit apply. Try restarting into Windows normally again, if it works, then again, you have to figure out which service/startup items are affecting your boot up.
If that didn't work either, then you may have a graphics card issue. Where does it stop when you try to load Windows normally?
Mar 13, 2010 | Compaq Computers & Internet
Cannot start in normal mode without blue screen popping up
Duing the startup, can you hit F8 just after the bios shows. You should see a list. If you choose, last known good configuration, what happens? If it blue screen's again, can you startup in safe mode? This is also a item on the list from F8.
Did you install any drivers recently, in the last day or two?
If so, when you boot into safemode, uninstall that driver and try to boot to windows normally.
Jul 28, 2009 | Acer Aspire One PC Notebook
Acer Aspire One  PC Notebook Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
