Question about Echo CS310 14" Bar Length Fully Assembled Chain Saw
Echo cs-310....how to put chain on after it became lose....also how to tighen when it becomes loose.
  • 7,733 Answers
At the right side take out the panel that hide the bolt that has a large groove.When unbolt move froward the chain holder and tight the bolt but not too tight just go further until you can test it by hand making the chain to move freely but stable.Reverse the procedure.
Post / thumbs / testimonial are welcome!
Posted on Nov 12, 2010
Why does derate lose power?
OK things to check. Gas/Oil mixture make sure you mix it in right amount. Be sure chain is NOT too tight. Now be sure to let the saw do the work . if you put too much pressure on it or,the chain is dull , the saw will loose power. Let me know how it goes.
Dec 03, 2015 | Echo Cs-400 18" Gas Chainsaw 40.2cc Sealed
How to reassemble chain brake on an Echo CS-350T that jammed and was pulled apart by someone else?
From what I see you will need assemble thing leaving the main spring and brake cover off. Before attempting to put the main back in install a clutch drum inside the brake band. Then you slip on the main spring and pry the end on with a flat blade screw driver. Now install in the cover for the spring and brake. Reset the chain brake and remove the drum.
Now install the chain brake on the saw and test. Do not trip the chain brake without the clutch drum in place. If these are anything like the Husqvarna version after they get worn they will get where it is nearly impossible to reset.
Echo CS 350T Chainsaw CS350T Parts Diagram Page 7
Jan 12, 2015 | Echo Garden
Troubleshooting chainsaw
You need to clean the chainsaw areas where the dirt has gone with a water hose. You may have clogged up the oil thing that puts oil on the chain. Hope this helps! And yes, dirt will make a chain dull. You might have to replace the chain or have it sharpened.
Jul 20, 2014 | Echo Cs-310, 14" Replacement Chainsaw...
Do you have instructions and/or a video showing how to replace the sprocket and clutch assembly on a Echo CS 310 chain Saw
not on an echo but they are pretty much all the same.....go check out my youtube channel and look up clutch themowermedic1 on yt
Jan 12, 2013 | Garden
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
May 12, 2011 | Echo CS400 18" Chain Saw
Chainbrake spring broke need new one
Parts Catalogs Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04511001001 - C04511999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04612001001 - C04612999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04713001001 - C04713999999 Language: English
Jan 05, 2011 | Echo CS310 14" Bar Length Fully Assembled...
Problem with the chain losing, i get 2 cuts and it is lose why
Your chain is getting loose because you are not putting the bar in the adjustment peg. On the front of your saw there is a flat headed screw that screw adjusts the tension on your chain . When you replaced your chain on the bar there was a hole in it down buy the two that hold the bar to the saw,that hole is the adjustment hole where you can adjust the tension on you saw.....
Nov 24, 2010 | Echo CS400 18" Chain Saw
How to install bar and chain on cs 310 echo
A CS-310 OM follows:
http://www.echo-usa.com/pdf/documentation/CS310es1112_042310.pdf
There is a very good, model specific, procedure beginning on page 12.
There are 2 listed based on serial number I think, you can download the other and an IPL here:
EchoUSA
http://www.echo-usa.com/documentation.asp
If your saw is not listed type "CS" in the “Model:” window, click "Search" and select your saw from the list provided.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 21, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
I have an Echo CS-440 18" chain saw and the chain came off. Now that I have put it back on, it won't move either by hand or when the engine is running. Help
OK.  This is simple. Either the chain brake is engaged or the chain is too tight. Start by pulling back on the chain brake toward you.  There should be a "click" if the brake was released.  If the chain is still immovable, try resetting the chain tension. 1. remove the spark plug wire 2. loosen the two clutch cover nuts 3.hold the bar nose up and loosen the tension adjustment screw until the chain moves freely without becoming loose. 4. tighten both clutch cover nuts with the bar held up. 5. Pull the chain around the bar by hand.  Loosen the adjustment if you feel tight spots. 6. When the chain is properly tensioned,tighten clutch cover nuts securely.  Do not overtighten! 7.  Check chain brake operation and release. 8. Replace spark plug wire and operate  saw.
Hope this solution will Fixya.
Jan 10, 2009 | Husqvarna Chain Saw 20" Bar
Echo CS310 14" Bar Length Fully Assembled Chain Saw Logo
130 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
