Question about Kenmore Sewing Machines
Kenmore ziz-zag sewing machine model 96, tension assembly
I took apart the tension to clean it. I lost order. I need to reassemble it.
5 Suggested Answers
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
frangel
SOURCE: I RECENTLY BOUGHT A KENMORE 10 SEWING MACHINE IN A...
Front upper right: bottom horizontal dial, set width to 0 (zero)
Posted on Jun 30, 2010
sewinsnap
  • 135 Answers
SOURCE: Top thread keeps breaking during
This could be more than one issue, first I don't think you have the machine threaded correctly. Make sure when you thread that the thread is seated betweeen the tension disc on the top and also, make sure that you have properly but tin the bobin
Posted on Aug 14, 2010
  • 10865 Answers
SOURCE: I have taken the tension
hello dtho.... go to searspartsdirect.com
Enter your model number and you will see an exploded view of your machine with all of the parts labeled and in the proper order. Joe
Thanks for choosing fixya!
Posted on Mar 10, 2011
My new Singer 4411 will not do zig zag or other stitches, just plain sewing
josephamoi Nov 17, 2017
When sewing ziz zag stitches the zig zag dial on your top right hand must be set any thing thing above 0. The setting is 0 to 6. Only on straight stitch this dial be set at zero.
Nov 15, 2017 | Singer Sewing Machines
How do I rebuild the upper tension mechanism for a singer sewing machine model 507?
It's far too complicated to explain on here. You need to get a service manual for your model, or find one with a similar dial. Make sure the manual covers tension dials. Getting the spring wound correctly can be a challenge. Have you checked to see the if the presser foot lever is pressing against the tension dial from the inside of the machine?
Mar 01, 2015 | Singer Sewing Machines
Upper tension assembly apart need to know how to reassemble
Assembly is easy, calibrating it... not so much.
Bring it to a service center.
Apr 14, 2014 | Kenmore Sewing Machines
I have used my machine for over five years, never had a problem until today, the arm wheel at the side is suddenly stiff to turn and its not sewing a zig zag I was doing.
Try unpluging it from the power. It may need to resent . Try a basic straght stitch and see what happens. Then go back to your Ziz zag stitch.
Mar 05, 2014 | Brother CS6000i Computerized Sewing...
My New Home SD 2014 is set to ziz zag stitch but keeps sewing straight stitches.Randomly starts to do ziz zag then goes back to straight. Can anyone help
the gear or cam inside the sewing machine could be worn or broken, it would be a good idea to have the sewing machine checked at a repair shop.
Aug 05, 2013 | Sewing Machines
How do i fix sewing machine tension?
#1 rule in dis-assembly of anything is to lay out the parts in the order they came off. I do this with a piece of tape turned sticky side up on my table. (for future reference)
As for your machine.. since you did not provide a model number the best I can offer is this parts page which has some diagrams under each model. Please locate model from the several pages listed... and view the diagrams.
http://parts.sears.com/partsdirect/getProductType.pd?parentCategory=Laundry+%26+Garment+Care&productType=Sewing-machine-Parts
Aug 19, 2012 | Kenmore Sewing Machines
Top thread keeps breaking during sewing. Tension adjustment does not solve the issue. Also, machine is skipping stiches and will not sew anything but a straight stitch: needle moves in the ziz=zag or...
Aug 13, 2010 | Husqvarna Sewing Machines
Sewing Machines Logo
103 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
