Question about Bosch Hammering
Oil running down chissel bit on bosch electric jack hammer
5 Suggested Answers
brewerstool
  • 141 Answers
SOURCE: bosch brute 11304 runs but does not hammer at bit
Sounds like you have a broken connecting rod. The easiest way to check for this is to remove the 4 cap head bolts holding the cylinder on and remove it. If the hammer piston comes off with the clinder you should be able to see the break. If that is ok you may have some stripped gears or a broken spindle somewhere. But I really think it is the connecting rod.
Posted on Sep 12, 2009
SOURCE: is there any maintenance I can do on a Kango 950 Jack hammer
Ureythn GE00 is madr by Fuchs in Germany - see their website.
Darina is made by Shell - see internet for comparable grease
Posted on Mar 02, 2010
  • 1388 Answers
SOURCE: How do I drain the gear oil from a Bosch Brute
Brute hammer uses special grease sold as service kit. This kit contains enough grease to lube hammer and replacement bolts that hold springs along the bottom. Check www.toolpartsdirect.com for parts and kit. Remove the lower half (tube) of hammer, also remove three bolts that hold springs and remove assembly from tube. Wash out old grease. Grease will be oil-like only when hammer is very hot, otherwise grease is paste-like. Good luck.
Posted on Jul 08, 2010
  • 1388 Answers
SOURCE: I have the Neiko electric
I have seen many different brand names on this tool depending or retail outlet / where purchased, including Sears, however none of the sellers offer replacement parts or are much help when a problem arises. This tool is a Chinese copy of the Hitachi h65 and parts list for Hitachi hammer can be seen at www.toolpartsdirect.com and many other web sites found by google search ( hitachi h65, or hitachi h65 manual ). Instead of taking apart the lower end of the hammer (if hammer still functions ), just remove the oil fill compartment cover and the oil felt retainer ( or only the felt) and introduce light oil directly into hammer to flush out old oil / debris. After you are satisfied with lubrication of the hammer, clean felt with diesel fuel and re-install. The felt is a wick and transfers the oil to crank. Place the wick in proper place for crank to catch oil (or replace wick with hitachi part). If oil does not transfer, use lighter weight non detergent oil. If you still want to take hammer apart, (remember that no parts are available) you will need to take the rod off the crank by removing the side cover to easily pull the lower end. Good luck with your repair.
Posted on Apr 21, 2011
Bosch hammer electric Hammer Jack is losing power and shutting off
The efficient design of Ingersoll Rand 114GQC Air Hammer allows the users to quickly change the spindles on the drill. It is able to deliver 2-5/8 inches of strokes with a BPM speed of 3500 so it ensures total efficiency.
Apr 05, 2018 | Bosch Hammering
I have a 3600w arksen jackhammer. It does not have an oil site gauge on it that I can see. what do I do about adding oil to this unit?
all these types of jack hammers hammers use 40 w oil
its electric
cant find a user manual for it online
if no visible site glass or oil filler
whats the chances you have to undo part of the jack hammer
at the Allen key bolts
reviews say these arksen units leak oil often
Jul 20, 2016 | Cars & Trucks
Bosch 11241EVS won't hammer
Not all bits for hammer drills are the same as the slots in the sides of the shanks are different between makes . There is a standard between hilti and ramset drill bits but other makers have different ideas Check out the shanks of your drill bits and look for the slot that holds in the bit.
May 26, 2013 | Bosch 11241EVS SDS-Max Rotary Hammer
Do you have to grease or oil anything on the bosch jack hammer
Grease bosch order nr 1 615 430 001 225 ml for 1 service OR 1 615 430 007 1000 ml for bulk repair.
Mar 16, 2013 | Bosch Brute Breaker Hammer 11304
On my BOSCH CSB 470-RLE 470w electric drill the chuck is slipping i can hold it in my hand and it wont move
It is a spring loaded hammer drill. You need to push the chuck down just a bit for it to engage the clutch. If it is still slipping then either the clutch pieces (items 23 and 32) are worn or item 32 is spinning freely on the spindle shaft. Here is a parts diagram.
Bosch CSB470-RLE diagram
Aug 16, 2012 | Bosch Drills
what caused grees to round down chissel from bottom of tool
Mar 26, 2012 | Bosch Brute Breaker Hammer 11304
Hammer runs but bit does not move much
how much oil do i put in my bosch jackhammer?
Jan 30, 2011 | Electric Demolition Jackhammer
No hammer function
if the tool still runs and you have inserted the proper bit, what I would try first is jamming the bit into the concrete to see if the striker is stuck and if still no hammer it would need to be taken apart and rebuilt with all new o rings and seals. if you try this yourself make sure you buy the small bottle of oil and some lube the the seals.
Sep 23, 2010 | Bosch 11240 1-9/16" SDS Max Combination...
How do I drain the gear oil from a Bosch Brute Jack Hammer
Jun 22, 2010 | Bosch Brute Breaker Hammer 11304
Bosch 11222EVSG hammer drill not turning
Couple things to look at, First is the selector in the hammer/rotation mode? Without a bit in it does the collar turn when in the rotation mode. Are you using the right bits for this tool. If yes to all of these I would look down the spindle and make sure that the pawl are in place (they lock to the bit for rotation) Let me know and we will dig deeper.
Mar 06, 2009 | Bosch 11222EVSG 1 1/8 Inch Grounded Sds...
Hammering Logo
146 people viewed this question
Top Bosch Hammering Experts
John Trevino
ken skalski
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
