Question about GE CustomStyle PSC23NSTSS Stainless Steel Side by Side Refrigerator
GE Profile Side by Side model PSC23NSTC ss - Ice make stopped working. Water is working. It jams with frozen blocks of ice periodically, which I clean out. Put empty tray back in early today and it's not making ice. Noticed a little ice in the back behind where the box sits and chipped most of it away. Thanks
3 Suggested Answers
SOURCE: GE Profile PSS26SGRB SS small water seep
under the trim there are 2 openings on on each side insert a flat head screw driver and twist so it will unlock and then it will be off hopefully you dont have to remove all insternal parts inside dispencer i will try one tomorrow at work and let you know
Posted on Oct 15, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Posted on Aug 04, 2009
My GE Profile psc23sgrc ss will not stop beeping ... the door is shut. Can i bypass the sensor?
ck door switches, they just pull out. you may have two in freezer. one is ice interlock.
Sep 17, 2012 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE Profile REfrigerator: Model PFSS6PKWASS Problem with loud clicking coming from icemaker every 2-3 seconds. Will do this for 30-60 minutes constatntly, then will stop clicking for the same period of...
i have same fridge with same prob makes 6 cubes of ice in a day with a lot of noise like you discribed also i have water collecting under crisper drawer of fridge i have to clean out water once a month or so still trying to figure out how to take ice maker out to fix
Jan 25, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a GE PROFILE side by side refridgerator model # PS123MGPCWW. my water and ice dispenser stop working periodically (for days at a time) and then come back on. it doesn't appear that the water...
Sounds like the water pump is bad .This is located at the back of the refrigerator. It's is a small pump and if you trace your water line you should be able to find it .Just replaced it and you should be fine
May 22, 2017 | Frigidaire Refrigerators
The Side by Side GE Profile refrigerator does not dispense any water or ice. It worked for a short period of time but just stopped working. Also, all the options that are suppose to be lite go off when the...
Could be several problems (I'm a homeowner, not an expert). GE had a problem with the water line in the freezer door: not enuf insulation so the line freezes, hence no water flow. I would look at this first, especially if you press the water dispenser handle and you hear the pump, but no water comes out. Ditto if the ice bin is empty or the ice maker isn't making any more ice. If the icemaker is making ice but not dispensing it, then the auger (thing that agitates the ice cubes in the bin) may be broken or frozen. (if frozen be sure ice cubes in bin are loose and not frozen into one big ice cube).
Aug 13, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice door not working
I have the GE Profile BSS25JSRF SS and have had similar problems: fixed the water dispenser by putting a hair dryer on it for 2-3 minutes. Sometimes this will freeze up and needs to be thawed. However, I still get no ice through the door. Hope this helps.
Apr 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a GE Profile Stainless Steel refrigerator; the Model number is PFS22SISBSS. The ice maker stopped working.
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 01, 2008 | GE Refrigerators
GE CustomStyle PSC23NSTSS Stainless Steel Side by Side Refrigerator Logo
141 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
