I have tried this on my Garmin 205:
1) Turn the GPS while holding on the lower-right corner of the screen as the GPS powers up. Keep your fingers there until a message box appears.
2) Select "Yes" when the message box asks if you want to clear all user data. As a result, all original settings will be restored and any saved items will be immediately erased. You can now reset your password.
Before doing this procedure, please do a backup of your SD-micro card by copying the contents to another similar memory card.
SOURCE: forgot password on my garmin 255W
Page 37 of this manual gives some tips:
http://www8.garmin.com/manuals/nuvi205_OwnersManual.pdf
Basically, if you want to turn the system on, just return to your "Security Location."
If you want to reset the 4-digit code you will need to send your nuvi to Garmin and provide proof of purchase or valid registration.
SOURCE: forgot my password, need a reset code
To reset the GPS, put your thumbnail under the Garmin logo and pull off the faceplate. Press the reset button.
If you still need PIN, you can either drive to secure location to unlock the GPS and if you don't know it, the only other way to unlock it is to contact Garmin.
SOURCE: I received a Garmin nuvi gps as a gift. I forgot
http://www.garmin.com/garmin/cms/home/support/searchsupport?search_key=forgotten%20password
SOURCE: i forgot the password on my garmin nuvi 205, how
I've been trawling for unanswered questions; this information may
be too late for you (or perhaps it may help you resurrect a useless machine which
you have put away) but it will certainly help others searching for advice with the
same problem.
You have Garmin Lock activated on your nuvi: there are only two ways you can unlock it.
1. Enter the PIN code (but you clearly don't have it or you wouldn't be reading this).
2.
Take the unit to the Security Location you chose when activating Garmin
Lock: it will then unlock without the PIN code and you can then either
reset the PIN or disable Garmin Lock. The Security Location should not
be the owner's home address, but many owners ignore this recommendation.
Many owners choose their workplace or a close friend or relatives
address for this purpose.
If neither option works then your unit
is useless unless you send it to Garmin with proof of purchase. Garmin
charge for the service and if your maps are not up to date then it's
really a waste of money as the investment would be better spent on a new
unit with current mapping.
I hope that you manage to either fix
your problem using my advice or at least can decide whether to abandon
the unit and buy another.
