Question about Epson LQ-570e Matrix Printer
Paper advances approximately 2 1/2 inches between printing on continuous cards 4 x 6. I need to change the amount of space between printings. How can I do this
    Guru:
  • 2,178 Answers
Go into the printer properties and set the printing preferences.
Posted on Nov 12, 2010
I have 4 GS6000 two of them are printing 1/8 or 1/4 bigger than the size shows in PhotoShop. Does anyone have any idea why?
First make sure there really is no invisible spacing around the images that are loaded to ONYX, Colorburst, whichever you use.
Is the media you are printing being fed to a take-up-reel, and are you using a tension bar? These all are likely causes. This problem is printer side I'm positive. I have 2 Epson GS6000 printers myself, and this happens often where after printing for a few days the sizes might start increasing.
You may need to go to the printer settings:
PAPER SETUP - PAPER FEED ADJUST - LINE FEED ADJUST
*It will then print some measuring lines that in my case are always close to 19 1/2 inches.
*You will also see on the display a option to adjust numbers
*If the sizes on both marks aren't exact 19 1/2 inches each, you need to add or subtract that amount, and then convert it to millimeters. This is the number you need to enter into the printer.
Press Enter on the printer to submit.
The next test print you do should be exact size you need.
Nov 14, 2012 | Epson Stylus Pro GS6000 Printer
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
There isn't a paper jam there is ink in the cartridges, i have selected the printer. when it prints the paper comes out blank
Make sure that the computer has available hard drive space
Printing requires the computer to have a certain amount of available hard drive space to process print jobs and to send them to the printer. Step one: Check the virtual memory settings Virtual memory is the temporary disk space on the hard drive that processes print jobs. It usually requires at least 200 MB of disk space but might require more or less depending on the printer. Insufficient virtual memory might cause the issue. Follow these steps to check and modify the amount of the virtual memory available.
Click Start , right-click My Computer , and then click Properties . Click the Advanced tab. In the Performance section, click Settings . Click the Advanced tab. In the Virtual memory section, click Change . For correct configuration, the Initial size and Maximum size settings must be less than the Space available on the hard drive. If the Space available on the hard drive is less than 200 MB , skip to the next step. Follow the instructions to clear space on the hard drive, and then start these steps over. The Initial size setting is the amount of space reserved for virtual memory on the hard drive. The Initial size setting should be about 200 MB, and greater than or equal to the recommended paging file size shown in the lower section of the dialog box. The Maximum size setting can be any number greater than the Initial size setting, but it should be at least twice the Initial size setting. Change the settings as necessary to conform to the information in this step. Click Set , and then click OK . Try printing again. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step
Step two: Run Disk Cleanup to remove temporary files Follow these steps to run Disk Cleanup. Click Start , click Programs , click Accessories , click System Tools , and then click Disk Cleanup . Disk Cleanup prompts you to select a drive to clean. Select the hard drive, and then click OK . Disk Cleanup analyzes the hard drive and presents a report. Select the following items from the report: Temporary Internet Files Downloaded Program Files Recycle Bin Temporary Files Click OK . If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step three: Remove unnecessary software programs Follow these steps to remove unnecessary software programs. Click Start , click Settings , click Control Panel , and then click Add/Remove Programs . Select a software program to remove, and then click Add/Remove . Repeat these steps for all software programs you want to remove. If you remove large software programs, run Scan Disk and Defrag on the hard disk drive. Look for these options in the System Tools section of Accessories
Mar 03, 2011 | HP PhotoSmart C4280 Laser Printer
Shows out of paper. Says paper jam. Open door . Clear carriage. Press ok. Cannot solve problem!!! 75 years old with 1st computer!
Out of paper
Cause: There is not enough paper in the input tray.
Solution: If the HP All-in-One is out of paper or there are only a few sheets
remaining, load more paper in the input tray. If there is paper in the input tray, remove
the paper, tap the stack of paper against a flat surface, and reload the paper into the
input tray. To continue your print job, press OK on the control panel of the HP All-in-
One.
Cause: The rear door is off the HP All-in-One.
Solution: If you removed the rear door to clear a paper jam, replace it.
rear door.
Paper can also jam in the automatic document feeder. Several common actions can
cause paper to jam the automatic document feeder:
• Placing too much paper in the document feeder tray. For information on the maximum
number of sheets allowed in the automatic document feeder, see Technical
information.
• Using paper that is too thick or too thin for the HP All-in-One.
• Trying to add paper to the document feeder tray while the HP All-in-One is feeding
pages.
To clear a paper jam from the rear door
1. Press in the tab on the left side of the rear door to release the door. Remove the door
by pulling it away from the HP All-in-One.
CAUTION: Trying to clear a paper jam from the front of the HP All-in-One can
damage the print mechanism. Always access and clear paper jams through the
rear door.
Paper specifications
This section contains information about paper tray capacities, paper sizes, and print margin
specifications.
• Paper tray capacities
• Paper sizes
• Print margin specifications
Type Paper weight Input tray1 Output tray2 Document
feeder tray
Plain paper 16 to 24 lb. (60 to
90 gsm)
up to 100
(20 lb. paper)
up to 50
(20 lb. paper)
up to 35
Legal paper 20 to 24 lb. (75 to
90 gsm)
up to 100
(20 lb. paper)
up to 50
(20 lb. paper)
up to 20
Cards up to 110 lb.
index (200 gsm)
40 10 N/A
Envelopes 20 to 24 lb. (75 to
90 gsm)
15 10 N/A
Transparency film N/A 25 25 or fewer N/A
Labels N/A 20 20 N/A
4 x 6 inch photo
paper
up to 145 lb. (236
gsm)
30 10 N/A
8.5 x 11 inch photo
paper
N/A 40 20 N/A
1 Maximum capacity.
2 Output tray capacity is affected by the type of paper and the amount of ink you are using.
HP recommends emptying the output tray frequently.
Paper sizes
Type Size
Paper Letter: 216 x 280 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Chapter 15
266 Technical information
Type Size
Legal: 216 x 356 mm (8.5 x 14 inches)
Envelopes U.S. #10: 105 x 241 mm (4.125 x 9.5 inches)
U.S. #9: 98 x 225 mm (3.9 x 8.9 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
Transparency film Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Premium photo paper 102 x 152 mm (4 x 6 inches)
A4: 210 x 297 mm
Cards A6: 105 x 148.5 mm
Index card: 76 x 127 mm (3 x 5 inches)
Index card: 101 x 152 mm (4 x 6 inches)
Labels Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Custom 102 x 152 mm up to 216 x 356 mm (4 x 6 inches up to 8.5 x 14
inches)
Top (leading edge) Bottom (trailing
edge)
Left and Right
margins
U.S. Letter
U.S. Legal
A4
Photo media
1.8 mm (0.07 inches) 2 mm (0.12 inches) 2 mm (0.12 inches)
U.S. Executive
B5
A5
Cards
1.8 mm (0.07 inches) 6 mm (0.24 inches) 2 mm (0.12 inches)
Envelopes 16.5 mm (0.65
inches)
16.5 mm (0.66
inches)
3.3 mm (0.13 inches)
Print specifications
• Resolution: 1200 x 1200 dpi black, 4800 optimized dpi color or 6 ink
• Method: drop-on-demand thermal inkjet
• Language: Lightweight Imaging Device Interface Language (LIDIL)
• Print speed varies according to the complexity of the document
(continued)
Print specifications 267
Copy specifications
• Digital image processing
• Up to 100 copies from original (varies by model)
• Digital zoom: from 25 to 400% (varies by model)
• Fit to page, pre-scan
• Copy speeds vary according to the complexity of the document
Mode Type Scan resolution
(dpi)1
Best Black up to 600 x 1200
Color up to 600 x 1200
Normal Black up to 300 x 300
Color up to 300 x 300
Fast Black up to 300 x 300
Try clearing all paper from all carriages (Top,Rear, Front, etc. then reinserting proper amounts. Even the smallest piece of paper can cause a jam. Here is a user manual in case you don't have one you can get it here: http://h10032.www1.hp.com/ctg/Manual/c00844812.pdf
This is a PDF and it is searchable and easy to navigate (Red lettering will take you to that section), so you will need Adobe Acrobat Reader (if you don't already have it you can get free here:
http://get.adobe.com/reader/
Also, once you have done all you can turn the printer off for a moment then turn it back on.
Hope this helps. Good luck
If this helps you resolve your problem, please
consider giving me a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 26, 2010 | HP Officejet J5780 All-In-One InkJet...
Hello All, I am facing an Issue with Printer. My Paper size is 8.65 inch X 8.9 inch. If I take continuous prints than after printing first page, Printer start printing after some space.( I concluded that...
go to start -> settings -> printer an faxes - > click file - > server propertiess -> click on create a new form -> give new name 8.5x6 -> set width 8.50in and height 6.00in - >save and exit open crystal report -> file -> printer set up -> click properties > click advance - > select paper size into 8.5x6 and save ok finish
by iswarpaniyur@yahoo.com
Sep 04, 2010 | Epson LQ 300+ Matrix Printer
Extra Long Receipts
we have Star TSP 700II and it is doing the same. not just 4inches but sometimes it adds extra 20-30 inches blank space. I think it was due to incorrect paper size settings.
Why dont you to go printer properties->Device settings and change the Friction size..as well as set Pagecut to Partial.
Also change preferences under Properties, advanced and change papersize to what suits you .
pl let me know what happens soon
sean
Feb 09, 2010 | Star Micronics TSP100 Thermal Printer
Trying to Print USPS Labels from PayPal on TLP 2844
see if you can set the printer preferences to borderless printing.
Jun 14, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Slow printing
try to verify your RAM space or do the following:
Step one: Verifying the amount of RAM
  1. Verify the amount of RAM installed in the computer.
  2. Determine the amount of memory currently in use by background programs or processes.
    Programs/processes will run in the background even when no applications are running. Most of these programs/processes will be indicated by an icon in the lower right corner next to the time.
    Less memory available for applications will result is slower processing time and consequently, printing speed.
    To determine processes running in Windows 2000/XP , do the following:
    1. Press Ctrl , Alt , and Delete simultaneously and then release.
    2. From the Windows Security box, select Task Manager.
    3. Click the Processes tab to view all running processes.
    4. Click the Performance tab to view the total and available amount of memory.
    To determine processes running in Windows 98 , do the following:
    1. Open the Device Manager .
    2. Click the Performance tab.
      The available system resources will display as a percentage.
  3. Turn off unnecessary background processes.
    This will free up system resources and increase printing speed.
    To turn off processes in Windows 98/ME/XP , do the following:
    1. Click Start , Run , and type msconfig .
    2. From the System Configuration Utility, click the Startup tab.
    3. Determine what processes are unnecessary and remove the checkmark those items.
Step two: Verifying the amount of hard drive space Follow the steps below to determine the amount of hard drive space on the main drive.
  1. Open My Computer , right-click the C drive, and then click Properties .
    This will display a chart along with the total hard drive space, used space, and available space.
  2. Verify that there is at least 2-3 GB of hard drive space available.
    The computer will require at least this amount to process printing data for simple text files, more for image files. The lower the amount of available hard drive space, will greater the time to process print data.
Step three: Ensuring the paper sensor is clean and not damaged The all-in-one product paper sensor plays an important role in determining the print speed.
Printing a self-test or demo page will ensure that the paper sensor is in proper working condition. If the page completes in less than 40 seconds, the sensor is working correctly.
Even if the sensor is working correctly, the printer driver might need to have the paper sensor turned off. To turn off the sensor, follow the steps below:
  1. Open the Printer folder, right-click the printer and click Printing Preferences or Properties .
  2. From the Properties box, click the Paper/Quality or Features tab.
  3. Under the Paper Type section, open the menu and select Plain Paper instead of Automatic.
    This will disable the paper sensor and increase the print speed.
May 15, 2008 | HP PSC 1350 All-In-One Thermal Printer
Hp deskjet 940c printer
1.Setting DPI values
2. Follow one of these paths to select your print options, depending on the
software program you are using:
• Click File > Print, then select Properties
–or–
• Click File > Print Setup, then select Properties
–or–
• Click File > Print > Setup, then select Properties.
The printer properties box appears with Setup, Features, and Advanced
tab options.
3. Select the Setup tab, then choose the following:
• Print Quality: Best
• Paper Type: The appropriate photo paper type
• Photo Paper Printing:
- PhotoREt for best print speed and quality
–or–
- 2400 x 1200 dpi for source images greater than 600 dpi (requires
400 MB or more hard disk space and takes longer to print)
• Paper Size: Appropriate paper size
4. Select the Features tab, then choose the following:
• Orientation: Appropriate orientation
• Two-Sided Printing: Unchecked
• Copies: Up to 20
5. Select the Advanced tab if you wish to make optional adjustments to
color, ink volume, or ink drying time.
6. Click OK to return to the Print or Print Setup screen.
7. Click OK to print.
Apr 08, 2008 | HP DeskJet 940c InkJet Printer
Blurred bands in prints
Try changing ink cartridge. Print only "grayscale" and if that happens, you need a black cartridge changed. If, not color
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Mar 16, 2017 | HP DeskJet 460WF Mobile Color Printer
Epson LQ-570e Matrix Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
