Question about Saniflo Sanibest macerator with multiple connections
I have a saniflo sanibest model with a toilet, bathroom sink and shower hooked into it. The toilet and sink work fine, no problems, the shower however will not drain, not even a little. The shower is on top of a 2"x8" platform with a 2" drain, i removed the drain line from the unit and a bunch of water came out of the shower pipe, also, I pushed in on the check valve inside of the side inlet and a lot of water came out of the sanibest unit, there seemed to be no obstructions and the pitch from the shower drain to the sanibest is way more than the 1/4' per ft. required. Any suggestions as to what may be causing this problem and potential solution would be greatly appreciated. Thanks.
  • 2 more comments
  • ray_fragola Nov 12, 2010
    This is a new installment
    This is a new installment.
    Is this something that can easily be done by a novice, or should someone more familiar working with the units be called in to accomplish this?
  • 43,501 Answers
Where the water goes in from the shower there should be no check valve...the water should flow freely into the tank....there is no pressure that will open the valve....
You need to remove the check part or pipe it in somewhere else....
are you sure you did not pipe it into the outlet???
heatman101
Posted on Nov 12, 2010
  • 10,865 Answers
Hello Ray. Thanks for choosing Fixya! Your problem is most likely caused by a faulty inlet control flap. Often, a good and thorough cleaning of the inlet control flap is all that is needed. Certain bath shampoos and conditioning products have a tendency to "gum up" the flap preventing it from doing it's job. I am including a link to the installation manual for your product that will show you exactly where and how to get to the inlet control flap and maintain it. Joe
http://www.saniflo.com/pdf/install/BEST_US.pdf
P.S. If your efforts do not solve the problem please contact one of our service engineers by calling Saniflo's head office at 1-800-571-8191.
  • 2,299 Answers
Did this problem just start? Or is this a new installment?
Toilet and shower runs great for a year> just had a sink hooked up and now toilet and shower back-up> was the sink hooked up wrong? to a vent or wrong pipe>
Nah, that doesn't sound like the toilet or sink were hooked up wrong, your sewage tank is probably full, you can have it pumped out for $100 or so. They fill up every so often for w/e reason.
May 01, 2016 | Saniflo 002/005/007 Saniplus Toilet with...
Do the saniflow toilet need to be plumbed in to mains waste? I have a patient who needs a toilet located outside the house that needs to be trouble free
Hi and welcome to FixYa, I am Kelly.
In short yes it will need plumbed with a smaller drain line to the home waste drain.
The unit uses a fast-rotating blade to reduce waste and toilet paper in the flush water, which is immediately and entirely released under pressure through "small-diameter piping" to the sewer or septic tank. No special maintenance is needed and the pump is sealed for life. This simple and cost-effective alternative to conventional plumbing is ideal for basement renovations and other home-improvement projects. Properly sized, a Saniflo macerating system can handle all the fixtures in a bathroom, including the sink, shower, tub and toilet & endash; even on a septic system. What's more, these fixtures will work up to 12 feet below and as far as 150 feet away from a septic tank or sewer line.
Go to this page and download the manual for the installation instructions:
http://www.saniflo.com/Downloads.aspx
These are all the installation downloads available on that page:
Installation Instructions:
SANIBEST SANIGRIND SANIPLUS SANICOMPACT SANIPACK SANIALARM SANISHOWER SANISWIFT SANIVITE SANICUBIC Classic SANISTAR SANITOP
Thanks for using FixYa,
Kelly
Jun 01, 2010 | Home
Toilet works fine,but drains for sink and shower stall drain very slow
hello there:
sounds like you may be having a partial block in you're drain lines do too paper and things being flushed down the toilet you may need to go to the outside of the house and find the cap on the drain vent and use an industrial snake and run threw the drain lines to get ride of the clog this should solve the problem you should be able to rent one from ace....hope this helps you out thanks
May 29, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Thinking about installing basement Saniflo toilet
Zoeller makes the best unit out there do you research first
Nov 15, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Shower tray is low and fills before saniflow kicks in cant alter height of tray
See if you can adjust the highth of the saniflow,to make it kick on sooner. goodluck.
Jul 13, 2009 | Saniflo 013/005/007 Sanibest Toilet with...
Saniflo not flushing corectly
Does the shower or sink back up into the toilet bowel after running for a few minuits?
If not:
The bowel is clogged. Fill it with water then use a plunger
Nov 21, 2008 | Saniflo Sanibest Grinder Pump Only 013
Saniflo Sanibest macerator with multiple connections Logo
276 people viewed this question
Top Saniflo Plumbing Experts
Gil Shultz
Tom Chichester
Gregg Mahin
Gregg Mahin
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
