Question about Garden
I have trouble getting my troybilt riding mower to start. I have to turn the engine over forever to get it to fire. Sometimes I have to spray starting fluid in the carb to get it to fire. I have changed the spark plug, the fuel filter, and im using fresh gas. After starting it runs fine. But after sitting for an hour, I have the same problem again. Any suggestions?
  • 297 Answers
It sounds like your choke is not adjusted correctly. Remove the air filter and do a visual check to make sure the choke is actually closing when it is applied. If not you can adjust the cable, that should solve the problem.
Hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 12, 2010
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Engine doesnt fire, battery charged, lights work
This is not an electronic issue...this is an engine issue.
Engines need 3 things to start
Spark
Fuel
Compression
First thing I would test first is for a fuel issue. Spray carburetor spray generously into the carburetor and the plug hole... once you put the plug back in, start the unit up... if it runs for a few seconds , you have a carburetor issue, which 8 outta 10 times, is the issue.
I'm guessing this is a riding mower... doesn't say what you are working on.
Oct 14, 2015 | Garden
Troy bilt troubleshooting
what are you trying to troubleshoot? heres the troybilt link to get you started
http://www.troybilt.com/equipment/troybilt/lawn-mowers/lawn-mowers?facet=cas_f9_ntk_cs%253A%2522Zero%2bTurn%2bTractor%2522&sortBy=3?cm_mmc=Google-_-Mowers-_-Zero%20Turn-_-Sponsored&gclid=CjwKEAjwi6OeBRCCrZqp-qaQhhISJACrfbtAq_Hepy9R8IgJYw_E9HkmY0pum-PDxyoqjOrFfOWq-hoCAknw_wcB
Jul 17, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Engine turns over but won't start
Use a starting fluid spray.
If the engine fires then the problem is lack of fuel. Clean and check all the fuel pathways starting at the fuel tank. If necessary strip and clean the carburettor. Check that the choke and throttle are not sticking.
If the engine doesn't fire check the plug(s) are clean and in good condition, plugs can fail under pressure. Check the cylinder compression. Check the ignition timing.
Jul 10, 2014 | Husqvarna Garden
My troybilt bronco riding mower won't start the gas n oil r fine when I turn key it has no fire
possibly a bad starter switch which has a built in kill switch. There is a wire that goes up to the coil that is used to kill the spark when you shut it down and also goes in the safety circuit to prevent it from starting unless everything is in the right position. sometimes you can unhook the wire and still run safely. if it doesn't shut down when the switch is in the off position a toggle switch can be wired in to ground the circuit if you need it.
May 12, 2014 | Garden
Troybilt mower want start. Model # 37120 13AN689G766 Serial #1C244B30107 002?
try and jump start it with your car then check the safety switches if jumping doesn't help
Apr 18, 2012 | Husqvarna Garden
My 1976 sears 18 hsp riding mower quit running now it just cranks but won't fire it has a onan engine
check for spark then spray a little carb cleaner or starting fluid in the carb if it fires its a fuel problem filter pump carb
Apr 10, 2012 | Craftsman Garden
My westwood ride on mower, model 2012 wont start.
Could be a few things, First, you say it's getting fuel, but is the fuel fresh? It may have water in it and act like your engine. Did this problem just start happening? Did you happen to ride over something that may have sheared the key on the flywheel? This would throw the timing off on the engine. If you can try to start it while spraying gas into the carb throat and it keeps running, then it could just be a dirty caburetor or a misadjusted carb float. Good luck, Bill
Dec 20, 2009 | Briggs & Stratton Garden
Unable to find the Troybilt deck V belt that fits my 2002
If it's the belt that just runs on the deck and not the one that goes to the engine, it is a 954-0349
Jun 24, 2009 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Garden Logo
107 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
