I have a legacy HP 9100 DIgital Sender scanner and it has an old password set on it. We need to give it a manual IP address but we cant reset the machine because of the admin password, is there a default
  • 8,197 Answers
Welcome to FixYa!
To Reset the HP 9100C Digital Sender's administrator password:
1. Press SHIFT+ALT+Duplex (the button under the green and red buttons)
2. Type "erase password please" (without quotes, but including spaces)
3. Press OK
Good Luck if you have any questions please ask.
Posted on Nov 12, 2010
Will not print under OSX 10.7
QMS is a legacy company under then Minolta, now Konica Minolta I believe page pro 9100 is very old I believe that it would work with windows 95 or xp at best.
Nov 13, 2011 | Minolta QMS PagePro 9100 Laser Printer
This router was previously used by my sister-in-law in manila...then i brought this router in japan...when i want to install it in my computer i cant access on the site that written in the...
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your
router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 08, 2011 | Computers & Internet
Im using a tenda wireless broadband..my problem is i cant get the right pre-shared key pls help
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Sep 07, 2011 | TP-LINK Tenda W311R WirelessN Router AP...
I'm forget admin password on hp 9250c. Please, how recovery admin password.
Cold reset for HP9250C
A cold reset resets the values of permanent storage variables to factory default. Often this is necessary
for clearing the HP MFP Digital Sending Server IP address.
The following items are cleared during a cold reset:
Embedded Jetdirect IP address
SMTP IP address
LDAP IP address
Embedded Web server password
All control-panel configurable items
The following items are NOT cleared during a cold reset:
Local address book e-mail addresses
Real-time clock (date and time)
Page counts and maintenance counts
Product serial number and formatter number
Service ID
Event log
To perform a cold reset
1. Turn off the digital sender.
2. Turn on the digital sender.
3. Immediately after turning on the device, press and hold down the #6 key (do not wait for the memory-count). When the three status LEDs are illuminated, release the #6 key.
4. Press the #3 key four times until the display shows COLD RESET.
5. Press the #6 key once to initiate the cold reset. The product will continue its boot-up sequence.
Oct 04, 2010 | HP 9250c Printer
Hp officejet 7210. When router resets, I loose my printer connection.
IS this printer wired LAN to your router? If so, look in the settings to your printer and check the IP address.
Now in the settings menu, it should have an option for you to set DLNA or manual. Set to manual. Enter the same IP address the machine originally had. If you could not find what ip address your printer had, in windows startmenu find run or command prompt and type ipconfig all.
Find the ip address for your computer. Add 10 to it. For example, if it is 192.168.0.2 than give your printer 192.168.0.12 If it asks for a subnet mask use 255.255.255.0
I believe the problem you are having is that every time your router resets it gives your printer a different ip address (dynamic IP), so your printer driver software can no longer find it. You need to use a static ip address (manually giving the printer an ip address) so it never changes and the driver can always find it.
Sep 24, 2010 | HP 7210 OfficeJet All-In-One Printer
How can i hook up the scanner?
Hook the network cable to your scanner nec card on the machines, note that this machine has two nec cards, one for printer and one for scanner.
after that Go to the setting and under setting/Scanner Default create and ip address for the scanner. after you done from that go to the computer browser, type in the ip address, you can choose scan to smb or pc.
Scan to smb needs shard folder but scan to pc needs to run software on your computer on your pc.
Setup the sender list which you need to fill only the ip address of the machine as sender.
Go to destination setup the ip address of the computer you scanning to, the path is the shared folder name, and the user name and password of your computer and you good to go.
To make it easy for you, Provide me your email and i will attach the scanning manual to help you setup it correctly and you can always get back to me in any question.
Best Regards
Kyocer/copystar Expert
Jul 13, 2010 | Kyocera Copystar 221 Black and White...
How do i reset the entire system back to default? Previously someone had put an admin lock on it so now i cant use it properly and i need to reset the menus.
Hi
· It is called the Cold reset
A cold reset resets the values of permanent storage variables back to factory default. Often this is
necessary for clearing the HP MFP Digital Sending Server IP address.
● Embedded Jetdirect IP address
● SMTP IP address
● LDAP IP address
● Embedded Web server password
● All control-panel configurable items
● Local address book e-mail addresses
● Real-time clock (date and time)
● Page counts and maintenance counts
● Product serial number and formatter number
● Service ID
● Event log
3. While the product is performing its memory count, hold down the #6 key. When the three status
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 02, 2010 | HP Digital Sender 9250c scanner Printer
Default hp 2015 password so I can change the IP address
make a cold reset or NVRAM reset
To do a cold reset you power on the printer while holding down the go button for about 5 seconds and then release the button. If the button is held for more then 15 seconds it may do a NVRAM reset
Jun 10, 2008 | HP LaserJet P2015dn Printer
Scanner password
HI there try the following.
  • Open Internet Explorer
  • Type in the address bar the IP address of the scanner (If you do not know this print out a status page)
  • Once you have typed in the IP address you will then have the scanner configuration screen on the left you should have passwords section you will be able to change it from there.
Hope this helps you
Thanks J
Jan 14, 2008 | Kyocera CS-2550 Black and White Copier
HP 9200C Digital Sender
replace the jet direct card
Apr 26, 2007 | HP 9200C Digital Sender
98 people viewed this question
jasbo
jasbo
