Question about Ricoh Aficio 450 Copier
I need an expert for sc555 ricoh 2060 - Ricoh Aficio 450 Copier
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Possible causes:
• Thermistor bent, out of position
• Fusing lamp disconnected
• Circuit breaker opened
Posted on Feb 02, 2012
    President:
  • 2,072 Answers
That is a fuser fault. Can be caused by dirth thermistors on the hot or pressure rolls.
Can be a bad heat Rod. But on a 450, It is almost likely a bad thermistor. It is the flexable temperature sensor that rests on the hot roll to monitor the temperature.
Posted on Nov 12, 2010
How to fix SC555 error ?
Same way you reset 542 enter service mode and cycle power
May 21, 2014 | Ricoh Aficio Office Equipment & Supplies
Printer isnt working properly
Yes people do, its a Ricoh box call your local Ricoh dealer, and they/we do service these, your problem is a hot section error.
Mar 12, 2014 | Lanier LD533C Magenta Toner Cartridge...
RICOH AFICIO 5500 - SC555 ERROR HOW CAN THIS BE CLEARED?
press yellow clear then enter 107 and press and hold the orange stop key untill you enter service mode.
select copy sp
press 7807 and then the # key. select execute on the righ on the display
when it says complete turn off the machine from the red power switch. turn machine back on. if error returns repost here .. you may need parts
Aug 08, 2011 | Ricoh Aficio 1224C Black and White Copier
Service Code Error SC555. This machine is not connected to the network. There is not an obvious paper jam. Can you describe a possible fix. Carolann
SC 555 is the main motor error. the main motor needs replacing. its the only solution. the main motor fits at the back of the machine. if you open the back cover, you will be able to see it.
Nov 19, 2010 | Ricoh Aficio MP1600SPF Copier
Mp6001 with sc555 error code
Fusing lamp overheat error (rear)
555 A
After the fusing
temperature reaches the
target temperature, the
fusing lamp does not turn
off for 20 consecutive
seconds.
?? Fusing thermistor defective or out of
position
?? Power supply board defective
u need a servise engineer to reset/fix it
Nov 18, 2010 | Ricoh Aficio MP1600SPF Copier
We have a Ricoh aficio 2051sp with error code SC555 what does this mean?
you will need to remove these and test with a multimeter. we are in michigan do you need a ricoh copier service 248-677-8112
Oct 07, 2009 | Ricoh Aficio MP1600SPF Copier
Ricoh 3800c Error code sc555
SC 555 Pressure roller
fusing lamp
When the fusing unit is not
running in the Ready condition,
the pressure roller fusing lamp
keeps ON with full power for
100 consecutive seconds.
Replace the fusing unit.
Dec 01, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh 3800c error code SC555
fuser related -- call tech to reset --- thermistors
Jam
SC555 is a fuser error there are a few possabilities that could have caused this..
1 You have a peice of paper trapped in the fuser unit(the heated rollers)
2 The fuser unit is not fully home
3 The thermistor/fuser lamp has a malfunction
Fusing unit SCs displayed on the operation
panel. The machine is disabled. The user
cannot reset the SC.
Turn the main power switch off
then on before entering SP mode.
Reset the SC (push "EXECUTE"
with SP5-810), then turn the main off then on again
Jun 26, 2008 | Ricoh Office Equipment & Supplies
Ricoh Aficio 450 Copier Logo
398 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
