Question about GE WCVH6260F Front Load Washer
I have a GE Front load washing machine WCVH6600HBB that leaks water when we do a load.
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
jtate9
  • 68 Answers
SOURCE: water leaking from under the front of the washing machine
The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Posted on Jul 29, 2008
SOURCE: GE Adora Front Load Washing Machine Problem
I had a similar problem...with the added issue of the door not locking at all. I cleaned the filter and all is well. However, it took me hours to find the 3 screws everyone was talking about The screws are at the very bottom of the washer, under the lip, facing front. If your machine sits on a pedestal drawer like mine, they are located between the machine and the pedestal. I hope these pics save someone a little time...
Posted on Aug 27, 2008
huuum
  • 750 Answers
SOURCE: GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Posted on Oct 04, 2008
  • 2920 Answers
SOURCE: GE WCVH6260 Front Load leaking water from bottom of the door
you have a bad door seal
Posted on Jan 17, 2009
Why does my GE front load model#GFWH1200DOWW leak water from the back?
had same problem on my washing machine. got some plumbers tape from the hardware shop and wrap in around the screw thread before fitting the plastic screw connector of the hose to the washing machine.and tigthening it up.
Jan 07, 2015 | GE GFWH1200DWW Laundry : Front Load...
Heavy loads like rugs do not spin and the machine jumps around and bangs into the wall. I have to turn it off and take my wash downtown to complete. The repairman says evrything looks fine. This is a GE...
Check for any movement from corner to corner (across corner to corner) if there is any AT ALL adjust legs to take up the movement / no movment is more inportant then being level a lot of techs miss this... anymore questions or problems just ask .....good luck
Feb 01, 2011 | General Electric WCVH6800J Front Load...
Wcvh6600hbb ge washer does not spin.... pump is pumping out the water.
could have a problem with the basket drive tube assy,,,,what happened to mine was the brass t-post on the bottom of the basket drive tube had been ground off causing my clip that holds on the brake release arm to fall off,the arm and cam fell down and thus had no spin,,,i bought a used tube installed it with a new clutch and it works fine now! I'd check that are of machine!
Feb 23, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
Won't spin or agitate
replace coupler between motor and transmission
Sep 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
GE WCVH6260F Front Load Washer Logo
376 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
