TOSHIBA SATELLITE P35-S611. Everything seems to be ok but it will display only on external screen. I have tried three different glossy screens that I know to be good with no success. I have tried Fn & F5 with no success. Any suggestions will be much appreciated. Thanks, Jim Jackson
  • amfriction Nov 30, 2010
    I tried as you suggested but still nothing through the laptop screen - only though the monitor. Any more suggestions? Thanks,
    Jim Jackson
  • 3,530 Answers
Welcome to Fixya
Sounds like you are having a bad LCD there. Try to discharge electrostatic energy of the motherboard. Take out the battery and unplug the power adapter from the computer. Press and hold the power button for 30 secs. Put everything back in and turn on the computer.
Please let me know what happen after doing this.
Thank you for using Fixya!
Posted on Nov 29, 2010
  • Jose Cada
    Jose Cada Nov 30, 2010
    sound like you already have a bad LCD on your laptop or the problem could be a loose connector from the motherboard to the LCD.
I have a Satellite P35-S611 that will display fine on a external screen. I have tried three different screens on it that I know is good but no luck. the screen plug seems firm and looks to be good. Any...
Hi and welcome to FixYa!
As a first course of action I strongly suggest that you reinstall the motherboard driver. You may have a system crash on the graphic card that's why it won't work on external monitors.
If the problem still persists then there are two things to look at. First, the connection of the motherboard to the external monitor socket can be damaged or loose so you will have to use soldering gun and lead to attach it. If the motherboard and external monitor socket looks fine then the problem can be on the graphic card itself. This will sure need replacement for it to work.
Hope this helps and thank you for using FixYa! Have a good one!
Dec 01, 2010 | Computers & Internet
Laptop shows Toshiba Logo, then Bios option, and then goes black
yes its very possible maybe the one u replaced was faulty?
Apr 08, 2010 | Toshiba Satellite P35-S611 Notebook
Toshiba satellite p35-2611 2 inch(1
the worse thing it could be is the lcd going out in a very bad way. Yes likely to get wrose over time, No not the video card because it happends on every screen, boot,preboot,and windows so guess what? If you have the lcd replaced you will be looking at a good laptop once again. Price aroung $75-100 bucks where? Ebay of all sources. Thanks I hope this was Very Helpful to you if so lay ing your ratings.
Dec 13, 2009 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me caligayanstep@yahoo.com i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
Satellite P35-S611 has trouble charging
If you have to wiggle the power cord it is most likely the DC jack on the motherboard. It is usually the center pin in the the jack that breaks the solder point and the small tension band inside the jack housing weakens.
Sep 26, 2009 | Toshiba Satellite P35-S611 Notebook
Slow Hard drive
That model is only IDE capable and has no SATA ports on the motherboard. You should get a faster IDE harddrive OR an external USB harddrive .
May 08, 2009 | Toshiba Satellite P35-S611 Notebook
Lines on screen
usually when you have lines on your screen then you have to buy a new one
Apr 22, 2009 | Toshiba Satellite P35-S611 Notebook
Screen problem.
Does your LCD look like this or similiar? (below) If it does, there should be a female plug similiar to the picture also below.
Hook smaller end of cable to your laptop, the other end to your external monitor. Turn on your laptop. If the vertical lines are not present then its probably your LCD, which will more than likely have to be replaced. If lines are present, then like tom19511 said it may be the video drivers. I've had this same problem with my Toshiba Satellite p35 5 times already. Toshiba had to replace my LCD each time. LCD's are more expensive than an inverter. Good luck, I hope you get it fixed.
Dec 13, 2007 | Toshiba Satellite P35-S611 Notebook
Computers & Internet Logo
David Payne
David Payne
