Yes it can, but it requires the addition of some components. It isn't really a straight forward install. It needs some reworking. In my opinion, not worth the trouble.
Sounds like you want to run a linear amplifier. If you really want to run an amp, get a better radio to do it. There really is no other reason to lower the dead key that low. Also, 1 watt might be too low. May not drive the amp well.
If you just want to make the radio swing, 1 watt is way way too low. You will have barely any carrier and the radio will sound like ****. That radio stock dead keys 2.5 watts. That's perfect for swing. Now you just need to have more modulation. Find DM1 and unsolder 1 leg and pull it out of the board. Now you will have full modulation. You will deadkey 2.5 and swing to about 15 watts.
If you want to run an amp, get a good radio. If you like cobra, get a cobra 29. They are fairly cheap, and sound amazing. As well it is real easy to lower the dead key in that radio.
No Battery Charge DC output.
1. Battery posts are corroded. 1. Clean battery posts.
2. Battery cable is bad. 2. Replace cable.
3. Battery is defective. 3. Check battery condition; replace if
defective.
4. Receptacle is bad. 4. Contact Authorized Service Facility.
Hope this helps!
