Question about Bang and Olufsen Audio Players & Recorders
I have a Beomaster 1900 Model 2904 that keeps blowing out the fuse in the unit. Any suggestions?
4 Suggested Answers
  • 154 Answers
SOURCE: RCA D52W20 52 Fuse problem
Well you could always use a bigger fuse but I would not advise to do it, it could and most likely will blow tv not fuse. Fuses ussually blow from a short or power surge. If it is new or under warranty I would return it for replacement or repair.
Posted on Jul 23, 2008
Grubhead
  • 5190 Answers
SOURCE: Keeps blowing the fuse inside the unit.
When a fuse blows suspect an overload in either the power supply or main amp stage. The most likely cause is some part acting like a piece of wire instead of doing it's job. In the power supply it could be the transformer, voltage regulator, or the rectifier or any diode. In the amp section any semi-conductor on the heat sink.
Check first for burnt or damaged parts. If you have a multimeter any transistor or diode will quickly show up. For when you have the meter on the ohms setting and touch the terminals with the probes, it will show as if you had touched the probes together.
Posted on Apr 02, 2010
Testimonial: "Much appreciated; clear direction. Thanks."
lpfaff1
  • 11573 Answers
SOURCE: I keep blowing the heater motor fuse motor tested good changed the resistor and the heater control unit but still blowing the fuse it doesnt blow if the resistor is unplugged any suggestions
Rick check for burnt/damaged wires/plug in the heaters wiring circuit especially at the motor and resistor, GM's were notorious for burning wires and melting the plugs in this area. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Wrong With My Blower Motor Fan Speeds
Sparky Answers 2005 Chevrolet Silverado Blower Inop
Blower Motor Problems Auto Repair Help
Posted on Jul 29, 2016
SONY RECEIVER MODEL STR - D315 keeps blowing a fuse
When the main fuse blows on a sony, it is usually caused by shorted output transistors. You would have to replace these transistors before the unit will not blow the fuse and power up correctly.
May 23, 2013 | Audio Players & Recorders
Bread machine blows mains fuse.
Depending on cost of unit it may be safer and better to replace it.
A word here about fuses----many are special--thermal, slo-blow and generic fuses from electronics stores may blow for no reason.
I would if the unit is expensive talk to the maker concerning this.
I also suggest you do not keep feeding it fuses as if it has a real problem there is always the chance it could catch on fire---no appliance is worth risking a fire.
May 15, 2012 | Televison & Video
I have a duo therm model 57915531. i have checked the breakers all the fuses and the thermostat. i have found a 3 amp fuse in the control panel of the roof unit. this fuse was blown. i replaced it and it...
That unit has a thermostat I believe and 12 or 24 volts to power it. The 3 amps tells me it may be either line or low voltage, see manual. the fuse blows due to a short in the control circuit, a transformer if low voltage.
Sep 10, 2011 | Dometic Rooftop RV Air Conditioner
Unit does not power up. Opened unit and found fuse closest to power switch blown inside unit. Will replacing this fuse get my unit working again? If so, what would cause this fuse to blow? please help.
It is possible that the fuse was blown due to a surge and replacing it will resolve the problem, but I wouldn't expect it. Usually when the main fuse blows, the primary stage of the power supply has a problem and the replacement fuse will blow as well. This is not a cheap amp and I would suggest that it be checked by a service tech. A few quick measurements internally can determine the likely fault and should not cost too much as an estimate fee.
Please keep us posted.
Dan
Jun 22, 2010 | Sonance Sonamp 1250 12-Channel Amplifier
Beomaster 2400-2 jumps radio station
Check the r/c is not causing this fault.Clean around the no4 pad.A b&o dealer should still be able to look at this unit assuming all their technicians are not youngsters given its age!
Aug 22, 2009 | Bang and Olufsen Audio Players & Recorders
Sound distortion on beomaster 3300
There is a defect in the pre-amp section of the unit. Without seeing it and taking a few measurements, I can't give you any particulars. A rough estimate for a repair wouldbe about $10-$25 in parts plus the local labor rate.
Dan
Sep 30, 2008 | Audio Players & Recorders
Jul 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
57 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
