Question about Craftsman Garden
I have a 25cc gas trimmer. It leaks a little gas from the clear, flexible gas supply line(s). Is it possible (practical ?) to repair a leak in the gas line(s) ? Can the lines be replaced ? gordh@shaw.ca
    President:
  • Craftsman Master
  • 1,545 Answers
They get replaced all the time. The "new" gas with ethanol tends to deteriorate them more quickly nowadays. Small engine repair shop has the fuel lines you need. Repairing them is not done.
If you have the Craftsman trimmer, just ask for about a foot or two of each of the 2 different size lines. They are called "Tygon" fuel lines. Runs about a dollar/foot for the stuff.
Posted on Nov 12, 2010
I just put new fuel line on my trimmer now i cant start it not getting fuel the line never fills with fuel but i can **** fuel out so i know it not pinched it a weedeater brand ght-17
Make sure the little valve under the tank if you have one is fully turned clockwise. Make sure there is nothing clogging the tiny screen inside the fuel tank. Check or test your primer bulb it may be leaky. If carb or intake is leaking, you won't get gas either. If you have a filter on this model, try changing it.
Sep 10, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
Gas leaking out of center hole on gas cap sears weed trimmer 358795150
I had same problem and got a replacement cap at a small engine shop. Seems there is a baffle in the cap to allow the tank to vent and to close off to prevent fuel leaking. Appears rubber baffle deteriorates over time.
Jul 20, 2010 | Craftsman 25cc Gas Line Trimmer
Adjusting the carburator on a craftsman 25cc line trimmer
Replace all of the lines before any adjustments, too small to see air leaks are a common cause the issue you have.
Feb 27, 2010 | Craftsman 25cc Gas Line Trimmer
Weedeater will not run with choke off
Check your carburettor mounting screws,they might be loose and it would mean the engine is
getting to much air and it would leak gas. Stephen
Sep 06, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Trimmer Runs with choke at idle, then stalls
Sounds like somewhere you have a air leak. Most likely it's somewhere near the carburetor intake or maybe the carb itself. Could be a line from the primer if it has one and i do believe it should that could be leaking or loose. Good luck.
Aug 02, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc would not start. What can I adjust or change so that it would start?
mine leaks gas from the little hole in the front of the carburetor when priming bulb
Jun 04, 2009 | Craftsman 25cc Gas Line Trimmer
My craftsman weedeater was runing fine,now its leaking gas from bottom of tank and keeps shutting off. where do i start,and what do i do??
Replace the fuel lines and get a carb rebuild kit. If your mechanically inclided its not to bad to replace the parts. The fuel lines are not very expensive and you can get them from a auto parts store or and outdoor equipment parts dealer. The filter in the tank is a little tricky to get out/in but a long needle nose plyers get it done. Good luck..
Apr 05, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
335 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
