Question about Silverstone SST-ST405 (SSTST405) 400-Watt Power Supply
No Power I have a two year old Silverstone SST-ST405. My Silverstone system had intermittent lock ups and then no start up. I have VOM'ed the ATX and Molex plugs and I do not see any DC voltage. Any ideas?
  • Mark Hughes Jun 22, 2008
    The-Only-Sol,
    The jumper proved the PSU ok. I have voltage at the plugs. So,... it appears to be a motherboard or CPU problem. How do I tell which is the problem?
    Thanks,
    Mark
  • Mark Hughes Jun 25, 2008
    The-only-sol,
    Nice Avatar name. The PC does not boot. The GA-K8NF-9 MB does not show any visible signs of burn. The Athlon 64 3500+ is covered by a SilverStone Nitrogon SST-NT03 cooler. I haven't dismantled that yet. One step at a time.
    Thanks for your help!
    Mark
  • 144 Answers
Dear Sir,
I assume, you have voltmeter with you.
Set VOM to DC 20 V range.
Remove the Power Supply from cabinet. Be sure you have proper earth in your house/workshop.
On the 20/24 pin main connector of your power supply, short the pins carrying green & black wire.
Hook your voltmeter -ve on any black pin of the connector permenantly.
& then connect the mains power cord to your power supply.
If your power supply is ok, this shall start the fans of the power supply on & running. Now you can check the voltages on different pins. There is a sticker on your power supply showing the normal voltages on every wire.
If you don't see any / normal volatges, your power supply needs repairing. You can buy a new one/ repair existing.
Posted on Jun 22, 2008
  • Anand Salunke
    Anand Salunke Jun 23, 2008
    Dear,
    Please tell me whether your PC boots up/ not? to help you further.
    If the system restarts again & again, Maybe the Electrolytics in your PSU started swelling (i.e. Failing)/ Same can happen on your Mobo..
    Have a close examination of mobo electrolytics & PSU electrolytics for this..
  • Anand Salunke
    Anand Salunke Jun 27, 2008
    Dear Sir,
    Try Following in the same sequence
    1) Check your PSU by connecting it to another working Mobo. This is because your PSU may be showing all volts right but may be sagging under load..
    2) If you are confident that PSU is ok. Try following
    a.Remove all Peripherals & all drives from mobo. Try Reseating the RAM & Power Connectors on mobo.
    b. If above doesn't help then turn off power, unplug the power cord. Remove the Battery on mobo carefully & keep it aside for about 10-15 minutes. Re-install the battery & wait for another 10-15 minutes before plugging the power cable. Check the CMOS clear jumper is not coonected.
    c. Remove the RAM. Clean its contact with a soft & good quality pencil eraser. Turn on mobo without RAM & check if it gives you the beeps. If it does so, its sign of good bios & maybe a good mobo.
    d. Re-install the RAM & check whether mobo boots.
    e. if still no success, then try changing the RAM with a working/ new one.
    f. Check whether the monitor is ok
    g. Remove the CPU fan & CPU from its socket carefully. Check the thermal heat sink is not dryed/ hardened. If so, apply fresh heat sink. Install CPU & Fan & try again.
    h. Check your CPU in another similar mobo, which can accept your CPU.
    i. If still no luck, send the mobo for repair / buy a new compatible one.
Computer not powering up
bad power supply. just replace
Jun 07, 2012 | Computers & Internet
AFTER POWER OUTAGE IT IS DEAD
Voltage spike likely blew across the dielectric of several electrolytic capacitors. The internal fuse may or may not have survived. If it did not- replace it once and see if it is as simple as that, although you are likely looking something more.
If you want to try to salvage it, recap all electrolytics and tantalums. with new high ripple current types for the electrolytics.
Feb 07, 2012 | Silverstone SST-ST60F (SSTST60F) 600-Watt...
My bottom case where the support is for the front cover is broken Can I get the part?? Abe
No, there are no spare parts for it. If you break a part you either get one from a discarded case or you replace the case as a whole unit.
Jun 13, 2011 | SilverStone Kublai 3 Black Mid-Tower...
We had a power outage - the computer was on a circuit breaker outlet. The other computer came back on, but the one with the siverstone power supply will not start up
Hmmm, First of all check the fuses if any that may have burned out due to the power outage. If this doesnt help. Open up the power supply and smell it for any burned out parts. If you can smell the scent of burned electrical parts then you should replace the power supply. It should solve your problem. Also check the motherboard for any anomalies.
May 19, 2010 | Silverstone SST-ST60F (SSTST60F) 600-Watt...
I have a burned out Bestec ATX-250-12z power supply for a hp pavilion a320n. I need to know if a Dynex® - 400-Watt ATX CPU Power Supply, will work in its place.
yes it should do provided your current psu is not a small mATX one. ATX power supplies are pretty generic. Make sure you get one that has enough connectors to suit your system, having said that, Considering it's an off the shelf PC I would guess most PSU's would have the right number and type of connections.
Jan 10, 2010 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Hi, I've bought Silverstone SST-ST60F about 2 years ago. Yesterday I decided to clean it from the dust. I turned of power, disconect all cables and used vacum cleaner to pick up all the dust from it. After...
That sounds like you may have dislodged something inside the PSU which is now shorting out some contatcs. Be very carefull as you are dealing with mains electricity here. You could take t to a qualified Electricion to take a alook, but it is probably damaged now. I would replace it before doing any damage to Motherboard etc. -Not an expensive part.
Nov 30, 2009 | Silverstone SST-ST60F (SSTST60F) 600-Watt...
Where do I find a manual for this product?
you can find the manual at this link
http://www.silverstonetek.com/download/d_contents.php?pno=NT01-E&area=usa
Jun 21, 2009 | Silverstone Nitrogon SST-NT01 v2.0 Fanless...
Power supply not staying on
Sounds like when cleaning your computer, you have also cleaned your processors heat sink and fan. right.
if you have done this then there in lies problem.
either your heat sink is not placed correctly
or you forgot to apply a new thermal interface material. because once you remove the heat sink the interface material is of no use. you must apply a new one. and check that you have placed the heat sink correctly and firmly.
Apr 25, 2009 | Silverstone SST-ST60F (SSTST60F) 600-Watt...
Silverstone SST-ST405 (SSTST405) 400-Watt Power Supply Logo
136 people viewed this question
Top Silverstone Computers & Internet Experts
David Payne
David Payne
Are you a Silverstone Computer and Internet Expert? Answer questions, earn points and help others
