Question about KitchenAid KUDR01TJ Dishwasher
How can I find a possible leak? - KitchenAid KUDR01TJ Dishwasher
  • KitchenAid Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Nov 12, 2010
Lots of rain water leaking into front passenger foot rest.
Are you certain it is rain water? It could be condensation from the A/C coil that fails to drain out of the drain pan, or possibly coolant from a leaking heater core. If you are certain it is rain water, depending upon the age of the vehicle, and possibly some other things, here are the possible options:
  1. Leaking door gasket.
  2. Leaking windshield seal due to rust
  3. Leaking windshield seal due to improper installation
  4. Leaking windshield seal due to acoustic (sound) over pressure (if you have extreme sound system with heavy bass)
  5. If you have a sunroof, if the drain hose comes down the passenger side door column, it could be leaking into the passenger compartment rather than drain through the floor pan.
Oct 29, 2015 | Cars & Trucks
Engine codes PO 128, PO 440, PO 456 and PO 622
Trouble Code: P0128
Thermostat Rationality Test
Possible Causes:
Check the operation of the thermostat (it may be stuck open).ECT Sensor is contaminated, damaged or it has failed.Inspect for low coolant level or for an incorrect coolant mixture.Trouble Code: P0440
EVAP Purge System Fault
Possible Causes:
EVAP purge valve vacuum supply is leaking or clogged.EVAP purge valve is stuck closed.EVAP purge solenoid has failed.NVLD assembly (leak detection) is damaged or has failed.NVLD switch circuit is open or the NVLD switch has failed.Ground circuit is open.PCM has failed.Trouble Code: P0456
EVAP Small Leak (0.020") Detected
Possible Causes:
.EVAP fuel tank or canister vapor hoses leaking or damaged.EVAP system component leaking, fuel cap loose or missing.Leak detection pump damaged or leaking.Trouble Code: P0622
Generator Field Control Circuit Malfunction
Possible Causes:
Generator field control circuit is open or is shorted to ground.Generator field control circuit is shorted to system power (B+).Generator field ground circuit is open.Generator is damaged or PCM has failed.PCM has failed.Here are the codes and causes.
Nov 25, 2012 | 2002 Dodge Intrepid
Over heating and leaking coolant
Is it a drip from area of the drive belt? if so sounds like the Water Pump.
is it from the front of the vehicle? possibly radiator.check the hoses..
is it leaking inside the vehicle? possible heater core....
Is it leaking from the area of vehicle where the engine is closet to the vehicle?possible heater hose....
You'll have to be specific where its leaking from....
Jul 18, 2012 | 2003 Chrysler Town & Country
Possible oil Leak at Knock Sensor
if I'm not mistaken, the knock sensor is mounted on the transmission bell close to the motor and detects the flywheel position. It is possible that the valve cover gaskets might be leaking from the bottom side and dripping onto the knock sensor, but it is also possible that the leak might be from the rear main seal of the motor. If that is the case, you will have to drop the ****** to replace the seal. If the knock sensor was bad your vehicle would not start at all, just crank. Try to wipe all the old oil with rags and look very closely where it gets oily again
Jun 23, 2012 | 1991 Buick LeSabre
97 ford windstar leaking transmission fluid
Possible leaks are 1. Transmission belly Pan gasket 2. Front pump/torque converter seal. 3. Transmission fluid cooler lines 4. Axle seals at right and left half shafts.
Feb 13, 2012 | 1997 Ford Windstar
P0455 evap leak
P0455 - Evaporative Emission Control System Leak Detected (Large Leak). Possible causes - Missing Fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- Incorrect fuel tank vacuum relief valve
- Leak is in line between intake m
Possible solution - Retighten or replace fuel tank filler cap
- Replaced damage or leaking EVAP canister
Mar 07, 2011 | 2001 Dodge Durango
I have a leak where the hose meets the bottom of the filter, I purchased a product FIX A LEAK they say I have to reverse the direction of the pump in order for that to work is that possible It is a...
Anything is possible, but this would require you to replumb the pump in backwards, and then replumb it correctly again after that. If I were you I would:
1. Try to replace the pvc line where the leak is occuring. (if possible)
2. if number 1 is not possible, aquire a fiberglass wrap kit from the local hardware store, drain the tub below the leak, dry the area thuroughly and apply the wrap to the outside of the leak (if the inside can be reached, apply to the inside as well.
Nov 19, 2010 | Jacuzzi Flange Pump Suction Model JCM
OBDII SETS CODES P0401, P0171 & P0174 . 1998 Mercury Sable
P0401- Exhaust Gas Recirculation Flow Insufficient Dectected
Possible causes - Harness or connectors (EGR volume control valve circuit is open or shorted.)
- EGR volume control valve stuck closed
- EGR volume control solenoid valve
- Dead (Weak) battery
- EGR passage clogged
- Exhaust gas leaks Possible solution - Clean EGR Valve
- Repair EGR harness or connector
- Replaced EGR volume control solenoid valve
- Replaced EGR volume control valve
Code P0171- Fuel Injection System Too Lean Bank 1 Possible causes - Intake air leaks
- Front Heated oxygen sensor may be faulty
- Injectors may be faulty
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Mass air flow sensor may be faulty
- Incorrect PCV hose connection Possible solution Dirty air filter of faulty air flow sensor are common causes of the problem P0174- Fuel Injection System Too Lean Bank 2 Possible causes - Intake air leaks
- Exhaust gas leaks
- Lack of fuel
- Incorrect PCV hose connection Possible solution Dirty air filter of faulty air flow sensor are common causes of the problem.
Jun 28, 2010 | 1998 Mercury Sable
Getting P1151 and P1131 codes on my 98 Ford Taurus. ''Lack of HO2S-21 and HO2S-11 Switching, Signal Low Input. Does this mean the O2 sensor(s) is defective, just durty, or some sort of vacume leak, or??
No that is it, More then likely your 02 sensor needs to be replaced.
But other possible causes would be excessive fuel pressure, leaking/contaminated fuel injectors, leaking pressure regulator, low fuel pressure or running out of fuel, vapor recovery system.
Other possible causes could be: Air leaks after the MAF, vacuum leaks.
Possible causes PVC system:
improperly seated engine oil dip-stick.
Possible causes EGR system:
Leaking gasket, stuck EGR valve, leaking diaphragm or EVR.
Possible causes Base engine:
Oil over filled, cam timing, cylinder compression, exhaust leaks before or near H02S(s).
I know its a lot of info but it could be anything. Take your time, good luck. Let me know how it is going.
Apr 26, 2010 | 1998 Ford Taurus
Vac code came on 0455
Evaporative Emission Control System Leak Detected (large leak)
A large leak has been detected in the evaporative system. See TSB 25-001-02. Also, possible faulty or loose gas cap. Note: The respective Powertrain Diagnostic Procedures Manual will direct the technician to determine if the vehicle evaporative system has an external system leak. Examples of some external system leaks are: a loose gas cap, a disconnected evaporative system hose, or a loose hose connection. Remember that the evaporative system may also have an internal system leak. This internal leak may be caused by an intermittent or permanently stuck open Duty Cycle Purge (DCP) valve. This leak source is considered to be internal because any escaping emissions enter into the engine system and not directly into the atmosphere, unlike an external leak. An internal leak may cause one of the above DTC?s. Possible causes of a stuck open (intermittent or permanent) DCP valve are: 1. Corrosion due to system moisture or possible water intrusion into the system.
Jun 30, 2009 | 2001 Dodge Stratus
KitchenAid KUDR01TJ Dishwasher Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
