Home | Kenmore | 16602 / 16604 / 16609 Built-in Dishwasher | Kenmore 665.16389300
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Problem for Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
By Buff1954 on Jun 17, 2008
Dishes on top rack not cleaning. I took out upper rack and checked for debris in upper spray arm and feed and it is all clear. Any suggestions ???
Same Problem
May 16, 2009
-   I have the same problem. I have checked and the upper spray arm doesn't rotate, nor is there enough water pressure to create a spray. There is water flowing into the spray arm. -   dhaugen1
May 11, 2009
-   I have the same issue. I tried to look in the filter under the lower arm but I CANNOT get the lower spray arm off. I try to reverse loosen the plastic nut to get it off but it just turns and turns and turns and it doesn't come off!
Very frustrated!
Any suggestions??-   cmscudder
Dec 15, 2008
-   I have a Kenmore Ultra Wash 665.1604, the dishes on the top rack are not getting cleaned, any ideas??? -   Guest
Solution #1
posted on Jul 06, 2008
Somewhat Helpful)
jbjaxiis
Rank: Wiz
Rating: 84%, 56 votes
Test by pulling out the lower rack and run an upper load, it may just be a loading issue. Some washers are better than others, in that they have stronger moters and impelors than others. The impellor may have something like a fork, knife, or broken glass in it.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 16602 / 16604 / 16609
Questions and Unsolved Problems for Kenmore 16602 / 16604 / 16609
Do you recommend Kenmore 16602 / 16604 / 16609 Built-in Dishwasher?
Answer
Answer
dishwasher not cleaning dishes as good as before. is there a filter that needs cleaned or changed... (More)
Answer
front control panel not working properl, cannot push start
Answer
Wont fill with water. And i out a new solenoid on it
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 16602 / 16604 / 16609...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
