Question about Lexmark X2670 All-In-One Printer
When i send to print not print inmediaty. i have to turn off the computer when i turn on again print only some pages not all. when turn on again the computer print again few pages not all. and so
  • 30 Answers
Have you installed any new software or hardware recently? It could be causing conflict with the printer.
If you use windows, try the "fixing a printing problem" troubleshooter. Click "Start" , select "Help and support" then "printers and faxes". Deleting and reinstalling the printer drivers could help too if above doesn't.
hope this helps
LC
www.inkbank.com.au
Posted on Nov 12, 2010
Will not respond when I send to print
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow question / exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver
select properties again you will have the similar options also you can troubleshoot the device
you might have many prints backed up ((make sure you have the printer turned off)) otherwise it might print another page
if you have multiple prints in the queue you will have to open a file that you are about to print click ok a page will open with a
display print queue tab you can see all prints right click on the ones you don't need select cancel
hope this helps
Jun 06, 2012 | HP Photosmart C3100 series
Lexmark wireless printer 1400 series prints blank pages
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark Z1400 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Jan 22, 2012 | Lexmark Z1420 Printer
Printing from a computer, get paper jam, clear it, then the printing sarts over from zero again, so get too many copies. Any fix in the software? The counter on the machine doesn't operate when...
You can work this around by using a little manual labor. Whenever the paper jams and doesnt continue from previous page, you can unplug the printer from the electricity. (not just the on/off button). This way it loses the document that was printing from the memory. Then you can send the doc for printing again by designating which pages to print.
ex. if your document was stopped at the 12 pg and it has 20 pages.. go to print> and then choose which pages to print i.e. 13-20.
I hope this helps.
May 22, 2011 | toshibadirect.com
My ip4300 keeps printing the same page over and over again. There's nothing in the print Q, but no matter what new job I send to the printer it prints the same old page. Is there a way to reset the printer...
Have you rebooted your computer? The printer's memory is very limited -- certainly not enough to hold an entire page. Your computer feeds the printer a line at a time, so it would seem that your computer's print spooler is 'stuck' on that print job. Try shutting the computer down completely, then restarting and see if that print job clears out.
Mar 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Printer was turned off during a print job and now will not print an entire page. Is there a master reset on this printer?
I would suspect it is the computer sending the printjob and not the printer itself. uninstall the printer software and reinstall it. after that perform all updates and attempt to print again and should receive a full document.
Sep 26, 2009 | HP LaserJet 1320 Printer
Printer prints partial page and then stops
We have had the same problem. I have found that if I close all windows not being used on the computer, then try to print the document again the entire document prints. This happens on an older computer we have that doesn't have alot of RAM.
Dec 04, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Trouble with duplex printing
I think your problem is that the 5550 supports manual duplex printing. Print every other page then feed them through again. Never tried it though. Dave Reed
May 23, 2008 | HP LaserJet 5550 Printer
I have an hp deskjet 940c, when I turn it on the two lights to the left flash repeatedly and it refuses to print anything. my computer recognizes the printer and will send print jobs to it but nothing ever...
first of all print a test page aftergoing to the printer maintenance section.if it successfully prints the printer cartriges are ok otherwise replace them .
OR
Install the printer driver cd again .
May 04, 2008 | Office Equipment & Supplies
Samsung 2010R
turn it off, take out the cartridge and put it back in. that should do it! it helps for me
Oct 23, 2007 | Samsung ML 2010 Laser Printer
Lexmark X2670 All-In-One Printer Logo
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
