Question about Canon PC-980 Color Copier
The copies produced on my Canon PC980 are totally black.
  • billysealapp Nov 13, 2010
    Problem is fixed. Thanks.
  • 340 Answers
it sounds like you have a defective toner cartridge which needs to be replaced. Have you done any troubleshooting on this at all?
Posted on Nov 12, 2010
My canon pc940 suddenly prints copies with a dark stripe running down the middle of each page.
On your computer open the menu for your printer. Somewhere there you will find an icon that initiates a cleaning procedure. It usually takes just a few minutes and the printer wil go through the cleaning procedure on its own.
Jan 04, 2013 | Canon PC980 PC920 PC940 PC950 PC960...
We have a Canon PC980 black and white copier. When the "on" button is pushed, the error message "EO" appears. The copier will not operate at all. HELP!!!
E0 means a fuser problem, it does not heat up properly. It could be the heat element within the fuser or the overtemp fuse may have blown.
Anyway, you should really have an technician look at it for you.
Jul 05, 2011 | Canon PC-980 Color Copier
How can clear error e000 from my canon pc980 copier
Error 000-means an Error caused trough an ruined fixing unit. You have to Change the unit, the Mainboard or bring to a Repair Center, I am afraid...
Dec 22, 2010 | Canon PC-860 Black and White Copier
I have a Canon FC244 copier. The paper jammed and I have found a long plate with 2 springs attached loose inside. I cannot see where this should be fixed.
Hi Canon copiers are among the most common photocopying machines available on the market. They are known for their affordability and delivery of quality photocopies of printed pages, and because of this, they have been used in various business and office establishments. Like most copiers, Canon copiers also have their own setbacks and issues, but these can be fixed easily once they are properly diagnosed.
    Issues.Among the most prominent issues with Canon copiers is when the machine produces either full black or white copies. Most users tend to think that the problem lies with an empty ink or toner. If that were the case, however, then they would still receive copies, but the prints would either have unnecessary lines or blurry images. When the copier produces plain white or all black printouts, the problem has to do with internal parts of the copier. Causes.The causes of the production of black or white printouts can be traced to one of two roots: broken corona wires or faulty circuit boards. If the copier has an erratic circuit board, it not only produces all-black copies, it also has a misplaced light/dark slider that has to be manually adjusted in order to produce quality prints. Diagnostics.You can troubleshoot the problems concerning Canon copiers by doing a quick check to see where the problem lies. If you are experiencing intermittent black printouts, see if the bias lamps turn on during printing. These consist of small lamps at the bottom part of the copier drum, where the transfer corona is. The lamps should be not be lit whenever continuous black copies are produced. Faulty circuit boards, meanwhile, can be diagnosed when you have to slam the top-down cover of the machine in order to produce quality, and not blank prints.
Aug 08, 2010 | Canon FC-204S Black and White Copier
Copies made are totally black. what do i do? i changed cartridged, put in new paper then copied. it copied fine after 20pages, copy sounded like it was jamming up, paper came out with some parts black....
Hello limay_uera
Please check your Printer setup. or options ( I am not familiar with this printer. what terms they use- I'm not sure) Ther will be options for Print in Color or Black. Make sure the radio button for COLOR is checked. This way, black and color both will print in the correct color. So leave it on color even when you want to print in Black. The black radio button is there for a different reason.
Hope this will help you.
luciana44
Nov 19, 2009 | Canon FAX-L800 Plain Paper Laser
Our canon laser fax 1060p receives faxes fine but send out a total black page (also the copy function is a total black page)
No power/failed contact image sensor. If under contract get replaced. It is poss. that a "standard white setting adj." could fix it, but doubtful with a black copy. -Carl
Jul 17, 2009 | Canon L220 Plain Paper Laser Fax
Canon pc980 copier...changed toner cart. now the image it produc
Cartridge is defective. I suspect it was a 'compatible' or remanufactured unit vs. an original. Replace it and it will work fine.
Apr 20, 2009 | Canon Office Equipment & Supplies
COUNTER CHECK "CANON IMAGERUNNER 2200" BLACK AND WHITE
On the left side of the on/off switch is there a small button mark with 123 press that button and the meter reading will display.
101 TOTAL ***** -that will be the total of copies,printing,and fax receiving on A4
103 TOTAL LARGE ******-this is the total of the A3 copies,printing and fax receiving made
201 COPY(TOTAL) -this is the total A4 copies
203 COPY(TOTAL LARGE)-this is the total for A3 copies.
Apr 02, 2009 | Canon imageRUNNER 2200
Canon PC980 ADF PROBLEM
not really familiar with this model, however, you should be able to open the cover (slightly) where the paper feeds in and you will see some rubber rollers (likely top and bottom), try cleaning these with a rag dampened with some alcohol (preferably), or water, and turning gently (do not force). If you use water, dry them afterward
Feb 13, 2009 | Canon PC-980 Color Copier
4 sets of copy counter numbers on canon imagerunner 2200
101:Total black copies and printed pages
103:Total A3 black copies and printed pages
201:Total A4 black copies
203:Total A3 black copies
Oct 31, 2008 | Canon imageRUNNER 2200
Canon PC-980 Color Copier Logo
96 people viewed this question
old marine
old marine
