Question about Bissell Vacuums
I have a Bissell 1694. I purchased a new pump and belt. The machine came apart very easy, but I cannot get it back together. The hoses don't all have a place to go or something
    President:
  • 1,673 Answers
Don't know if this will help you out or not. it is for a different model, but the hose layout is about the same.
Posted on Jun 17, 2008
How to replace belts on bissell model 1694
Generally, remove the screws from the bottom of the vacuum, remove belt and try supergluing it together and leaving for 24hrs before putting it back as it's worked for me. Take a pic for reference so you can put it back correctly.
Jul 14, 2014 | Vacuums
Changing a drive belt
Turn the unit upside down and on each side of the roller brush is a red piece of plastic with screws remove and take off roller then you will see the belt drive stem place around stem and on roller and pop back in, Reassemble. Steve
Jun 06, 2010 | Bissell Powersteamer 1694 Upright Vacuum
Bissell steam shampooer
There is a lint screen, but not really another filter per say. But you may have a stretched pump belt. Here is a link to your manual at the manufacture's web site. This link is only to YOUR manual so I am not suggesting any particular place to purchase from. http://www.bissell.com/images/UserGuides/1694-8806_607.pdf
When you look in this manual, on page 11 you will see the common wear parts on your machine... it's a good idea to have extra belts around incase you are having now.
I hope this helps.
Jan 20, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell power washer 1694 shampooer
First off is the gasket on the bottom of the tank vavle or sitting in the hole. It has to be on the bucket. May have a problem with the handle not pushing the valve (in the handle)open when you squeeze the trigger. Check the back end of the top cover to make sure it hasn't broken loose from the base, if it has, that raises the top so water won't dispense from the tank. The draw back is that Bissell has obsoleted some parts for this model.
Sep 20, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Replacing belt on bissell model 1694
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=707372 Generic problem for all Vacuums
Replacing belt on Bissell model
Posted by chi_agee on Jun 25, 2008
Replacing belt on Bissell model 1694
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Most of the Bissell’s the belt is changed from the bottom or the top is removed and you service it from the top. There are usually screws, clips or levers to remove the bottom plate or top cover and once that is removed then the belt change. If the belt is a flat belt the recommended belt change is every 4 to 6 months and id it is a geared belt then you would change it once a year for the best cleaning. If you have questions, refer to the owner’s manual in the trouble shooting section, if you don’t have an owner’s manual then you can contact the Bissell Factory cust serv listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 25, 2008 | Vacuums
No water
It is easy to take the top off. Mine has just 6 screws. Then you can see all the tubing and parts. For example, you can unclip the nozzles and see if water flows. Try blowing through the nozzle to see if it is plugged. Some people say the heating unit in the handle plugs up, particularly if you put soap in the water tank. I haven't dealt with this, but it should be easy to open the handle and bypass the heating unit.
Aug 19, 2007 | Bissell Powersteamer 1694 Upright Vacuum
Vacuums Logo
90 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
