Question about Microtek ScanMaker V6UPL Flatbed Scanner
My computer don't detect my scanner. I use windows xp service pack 3 and I have a microtek scanmaker v6upl.
    Genius:
  • 1,325 Answers
Hi
according to the specs on this item, it is compatible to Windows 95/98/Me
Winodws XP drivers not available for this item.
see link, http://support.microtek.com/static/smv6upl.html
Posted on Nov 12, 2010
Windows 7 will not recognize my v6upl scanner which worked in Windows XP. Problem seems to be that Device Manager sees it as an Unknown Device under the Universal Serial Bus controllers.
Unfortunately, Microtek doesn't support the V6UPL for any Windows OS beyond XP. The drivers are available here: http://support.microtek.com/downloads/bycategory.phtml?slct_tbl=1&slct_mdl=2 .
What version of Windows 7 are you running? Click Start > Control Panel > System and Security > System. If the version name ends with x64, you have the 64-bit version; otherwise you have the 32-bit version.
If you have the 32-bit version, try using the driver from the above site with the compatibility mode. Right click on the .exe file and choose Properties. Then select the compatibility tab. Set the program to always run in the compatibility mode for XP. Then right click again and choose Run as administrator. (You may need to disconnect the data cable and uninstall the Unknown device before trying to install the XP driver).
This will probably not work for Win7 x64. There are workarounds that you can use. You need to connect the scanner to a computer running an older version of Windows. This can be a physical second computer, a dual boot computer or a computer running a virtual version of the older OS. If you have Win7 Pro or Ultimate, or upgrade to one of those versions, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode (in order) from Microsoft. Then install the XP scanner driver in the XP mode program as if that is the only computer running. The only issue is that you can't share files or your printer between the virtual and real computer at the same time. You will be prompted to uninstall the printer if you try to install it on both machines. You can put files on external media to share them. Other virtual computer programs are Parallels and VMWare. However, you need a licensed version of the older Windows OS to use any of the other alternatives.
I hope this helps.
Aug 18, 2011 | Microtek ScanMaker V6UPL Flatbed Scanner
I installed my scanner on windows vista business. It will not work . It worked on Windows XP service pack 3. Is there a driver I can download for Windows vista business? I need this scanner to work...
Unfortunately the last driver that Microtek released for this device was for Windows XP. I'm posting the link to Microtek's support page for this device below. You may be able to contact Microtek directly (contact info is on the support page) for a possible workaround.
http://support.microtek.com/product_dtl_2.phtml?prod_id=3
May 03, 2011 | Microtek ScanMaker X12USL Flatbed Scanner
I need driver for microtek scanmaker 3840
you can download it from
http://www.driverskit.com/freedownload/Scanner/Microtek/ScanMaker_3840_3830_3800_ScanWizard_5_5_93/14515.html
Feb 26, 2010 | Microtek scanmaker 3840
Microtek Scan Maker 3880 Software
i want to the download the installer of microtek scanner 3880 scanner please anybody could give me this.
May 18, 2008 | Microtek ScanMaker V6UPL Flatbed Scanner
Microtek Scanner installation issue
If running XP SP2, then try clicking Start > right click My Computer > properties > Hardware tab > Device Manager button > expand Imaging devices > right click on your Microtek ScanMaker > uninstall > Re boot > and let XP pick up the device and let the found hardware wizard configure it.
I have seen plenty of hardware that when following the devices manufacturer's instructions for install, such problems as you're having occur and XP SP2 usually will cure it, though you may still need the device manufacturer's CD (for the driver) in your optical drive.
This link: http://support.microtek.com/downloads/bymodelname.phtml?viewtype=2&srch_in=ScanMaker+5950&frmsearch.x=10&frmsearch.y=11&frmsearch=Search&frm_rqst=2&axn=1 will allow you to select between the 5950 and 5950 Pro then on the next page you will be able to download the latest XP driver for your Scanmaker among drivers for other Operating Systems also.
I hope this helps, and Good luck.
Mar 21, 2008 | Microtek ScanMaker 5950 Flatbed Scanner
Microtek Scanmaker 4850 not compatible with XP
Hi.
You need to update your XP with the service pack 2, it's available on
http://www.microsoft.com/downloads/Browse.aspx?displaylang=en&productID=38DF6AB1-13D4-409C-966D-CBE61F040027
Note the star * requires validation of your installed windows
Feb 18, 2008 | Microsoft Windows XP Professional for PC
Won't recognize scanner when installed
First, make sure your computer has been updated to at least Windows XP Service Pack 1....Service Pack 2 is even better. You can check this by right-clicking on my computer and selecting Properties from the menu. If you're using Service Pack 1 or earlier...it would be a good idea to run through the Windows Update process a few times.
Try downloading a new Scan Wizard file from this page on the MicroTek web site. When you do the install, it should remove any previous drivers and clean things up.
If this doesn't help, try to find the Windows Scanner and Camera Wizard...usually located under Start>All Programs>Accessories. It may work even if the MicroTek software doesn't.
Good luck...and I hope this is helpful!
Jan 13, 2008 | Microtek SCANMAKER 4850 Flatbed Scanner
How do I find instructions on How to download and install ScanWizard 5 software to my computer?
I found it here.. and there .. http://www.opendrivers.com/driver/233289/microtek-scanmaker-series-scanwizard-5-v6.11-windows-98-me-2000-xp-free-download.html http://kmkm.dk/scanner/MicroTek/33289/Microtek-ScanMaker-Series-ScanWizard-5-v6.11-Windows-98-ME-2000-XP.html
Dec 26, 2006 | Microtek ScanMaker V6UPL Flatbed Scanner
Microtek ScanMaker V6UPL Flatbed Scanner Logo
144 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Tony
shelmnot
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
