Question about Craftsman sears 18" Chain Saw Chain ( Model 35084 )
I have a Craftsman 18" - model 358.351820... this
  • 298 Answers
SOURCE: oil mix ration for craftsman chain saw #358-356-8-
Should be on the cap. SEARS is the site but try here too:
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action?psid=54057012&sid=PaidSearchxGooglexManuals
Posted on Mar 26, 2009
SOURCE: Craftsman weedwacker won't start
When the Craftsman Weedwacker starts in idle and then stalls and the primer bulb will not fill with gasoline or will not pop back after being pushed in, then you have a blockage within the carburetor. The bulb is intended to **** fuel into the supply line, to prime it. To solve the problem, remove the carburetor, open the side that has ONE screw holding it (not the side with four small screws), remove all the two lines remembering how they were attached (the feeder line from the fuel tank attaches to the straight copper tube and the tube going to the bulb intake side attaches to the bent copper tube) and blow out the material blocking the fuel flow inside the carburetor. Then after replacing the carburetor, press the bulb and it should **** and discharge fuel easly. I have had two of these and the fuel path within the carburetor clogs easly. Jim Hart
Posted on Jun 05, 2009
  • 13 Answers
SOURCE: Starts up fine then dies when hot
your automatic choke is defalting
Posted on Jul 21, 2009
SOURCE: Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
Posted on Aug 28, 2009
dontbother10
  • 2220 Answers
SOURCE: Craftsman gas chainsaw 18
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Posted on Sep 20, 2009
Frigeair refreator motor keeps running
Good Afternoon Friend,
I see that your Frigidaire refrigerator motor keeps running. I will be more than happy to assist you. If I could please have the model number of your refrigerator, this way I can better assist you in resolving the possible troubles with your appliance. Looking forward to hearing from you.
WP
May 13, 2014 | Frigidaire Refrigerators
Craftsman Intek Plus 18 HP engine won't crank
Adjust the valves. I had the same problem.
Jun 15, 2013 | Craftsman Garden
Craftsman 42 " mower w/Kohler 18 horse engine clicks, but will not turn over.
my westwood tractor 1600hp will not charge the battery
Apr 17, 2013 | Craftsman Garden
Craftsman 18" chainsaw runs but dies when I press the throttle, new carb and fuel lines low and high speed set at 1 turn .
remove the muffler and run it after seeing that it runs good open the muffler and clean the screen inside
Sep 27, 2012 | Craftsman sears 18" Chain Saw Chain (...
Describe your sears 18"
I put a new bar and chain on my craftsman 18" chainsaw because the chain keeps coming loose. I am still having the same problem, after running 10 seconds, the chain falls off.
Sep 11, 2011 | Craftsman sears 18" Chain Saw Chain (...
My 18 " craftsman chainsaw will not oil the chain.
Take the bar off and clean the grove out with something like a small flat blade screwdriver.Make sure its open where it bolts on.It gets its oil through the bolt holes.If you have a way to blow the dirt out it helps.You can try running the saw without the bar on to see if its putting out any oil.If not you will have to get to the oil pump to see if its not bad.
Mar 08, 2011 | Craftsman sears 18" Chain Saw Chain (...
Good afternoon, What is error "6l"?
Good afternoon, it is one worse than error 60 unless of course you know the printer make model and the operating system.
Jan 27, 2011 | Office Equipment & Supplies
Need image, assembled craftsman model 917.276813 lawn mower deck
Go to www.sears.com and on the tool bar click on parts direct. On the opening page click on model # and enter your model number. Then on the page that opens there will be a list of components. Click on the deck and it will give you an image of the deck with part numbers.
Hope this helps. Let me know.
Thanks
roundo4
Aug 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman lt1000 18 hp briggs keeps wanting to die
could be a dirty carb. Did you use stabil over the winter. Also could be a govener problem.
Jun 23, 2009 | Garden
Craftsman sears  18" Chain Saw Chain ( Model 35084 ) Logo
365 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
