Question about Delfield ST4048
Where do i find model # to order door gaskets
    Problem Solver:
  • 31 Answers
Model and serial tend to be locate on a data plate on an inside wall of your unit. Let me know if you need any help Identifying the gasket you need. We'd be more than happy to help!
Cooler Gaskets staff
855-288-2259
orders@coolergaskets.com
Posted on Jan 02, 2014
How do i get a gasket replaced on a sears kenmore freezer model 31165
Order the new gasket using your model number- 31165 is not a valid/complete model. Remove the door and lay it flat on the floor, then remove the screws from the upper half of the door perimeter- DO NOT remove all the screws at once or you will be unhappy! Pull the top half of the old gasket away from the door, then put the top half of the new gasket in place and screw it back down. Next, remove the bottom half of the screws and pull the old gasket off, then put the bottom half of the new gasket in place and screw it down. If you try to do it all at once, the door will flex out of plane and won't lay flat when you re-attach it. You might need a hair dryer to soften the gasket if it was deformed during shipping. If you have a newer, press-fit style gasket, just yank it and press the new one in... Door Gasket 241872513
May 20, 2016 | Kenmore Freezers
REPLACE OVEN DOOR GASKET
Here is the correct gasket to order for that unit. http://bit.ly/Qq3Vp5
Apr 16, 2014 | Kitchen Ranges
Ge pfs22mi door gasket
This is going to be tricky so watch the video and tell me if the answer to you question comes out and resolved by the tricks revealed in the below video.. Sea Breeze
When you say latch can you tell me the part number of the latch you say that you need replaced? Here is a link to the parts you are describing HERE
GE Profile French door bottom freezer Model # PFS22MISBWW Door Gasket and related parts
Apr 01, 2013 | GE Profile Bottom-Freezer Refrigerator...
Looking for part #s for all door gaskets
Barry,
We specialize in cooler gaskets. We are a great resource for OEM quality gaskets. We can ID the exact gasket you need for your model MT66 if you can also provide the serial # of your unit. Without the serial # I can point you in the right direction but I can identify the right gasket with both model and serial! - http://www.coolergaskets.com/beverage-air-side-gasket-52-1-8/
As for the wiper gasket your unit needs - we can also locate that for you too. We don't stock them but we can get your price and availability and sell them below the OEM list price.
We also offer custom gasket options if you have any older units that don't have model or serial available.
Hope to help you soon,
Matt
855-288-2259
Sep 03, 2012 | Beverage-Air MT66
My LG model LRFC25750TT french door gaskets are shot. Any tips on (a) where to order new ones (L & R); (b) how to remove old ones; (c) how to install new ones -- screws to take out or not, tools...
Ok the gaskets should be press in type. No tools just a hairdryer to take out any wrinkles from shipping. And just go slow dont stretch too much. And you can buy from sears parts driect. Just have your model number ready. I hope this helps.
Aug 23, 2011 | LG LRFC25750 Refrigerator French Door
Door gasket leaking
My GE washer model wcvh6400j0ww was leaking too. The repair person thought the same thing the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 20, 2010 | GE WBVH6240F Front Load Washer
Change out refrigerator door gasket
Hello D Lassiter, You can do this repair yourself with just some basic tools and a little patience and assistance.
You'll need to remove all food from the fridge as it will take at least 45 minutes or longer, depending on how well you do.
If you roll back the door gasket, you'll see the fasteners that hold the gasket in place. Remove these starting with the ones on the bottom edge and then the sides. Finally, remove the top ones, leaving the two top corners for last, that way you can have someone help hold the door liner, so it doesn't drop to the floor and get damaged.
I would also suggest that a day or so before you're going to do the repair, that you let the new gasket lay out on a floor somewhere where it can't get damaged so it will relax and get most of the kinks out of it from shipping, etc.
Then simply put the gasket onto the door liner and reinstall all the screws back onto the door frame.
There are some models (you didn't provide a brand or model number to zero in on the exact version you have) that have the door gaskets glued onto the door frame. On this types, you'll have to use either a plastic or metal putty knive to gently run around the entire edges of the door, between the gasket and the door frame, to get it to come off.
Then you'll need to have someone help you reinstall the new one, as you'll have to reglue the gasket onto the door frame. This will require some non-marring clamps (about 4-6) to hold the inner door panel and gasket onto the outer metal door frame, while the glue dries. Typically, this is done with the fridge door removed from the fridge and takes at least a day once it's installed to glue in it place and fully cure.
In either case, please go to the link below and enter in the model number of your fridge so you can see which type you have and get a line drawing that shows the replacement parts you'll need. You can order them anywhere you wish, it's just very convienent that Sears provides the info for just about all brands of appliances made.
You can find your gasket part at www.searspartsdirect.com by entering in your model number for your unit and looking at the drawings and parts list provided.
You might have to look under the inner door panel edge, hence the reason to look at the middle section or corners to make this a bit easier to do. You might have to remove the inner door panel from the gasket first, in order to get at the screws that hold the gasket onto the metal door frame.
Don't pull on the inner door panel too much, as you really don't want to crack or break it, since your goal is to only remove and replace the gasket. Take your time and you should be able to get it off and replaced.
Of course, don't remove this until you've got the new one available and then allow plenty of time to do the job, which means getting the fridge and freezer emptied completely, so have plenty of coolers available with lots of ice!
I hope you find this Very Helpful and best regards!
Merry Christmas!
Dec 14, 2009 | Roper Refrigerators
My freezer needs new door seal . Where can I purchase one on line
depending on your exact model,
most brands and mkaes of gaskets can be ordered
www.appliancepartspros.com
type in your model number on the home search page
look at whichever door you need on the left
then look for the gasket below with the right part number
hope this help
usually ships in 24 hrs
Oct 19, 2009 | Freezers
The rubber door gasket is torn, how to replace,
Get the model number off the washer
and go to appliance store who service or Sears
Jun 10, 2009 | GE WSXH208A Front Load Washer
I need a new gasket for the door.
HELLO IF YOUR BRAND IS A SUB ZERO THEN HERE'S A PARTS LIST FOR ORDER INCLUDING A DOOR GASKET http://www.repairclinic.com/Sub-Zero-Parts?s=t-UCFF+201+-%3d%3db114 IF ITS NOT A SUB ZERO WITCH THATS WHAT IT BROUGHT UP FOR YOUR MODEL NUMBER THEN YOU CAN DO A SEARCH ON THE PARTS PAGE FOR THE WEB SIGHT THAT I JUST PUT A LINK FOR UP ABOUVE
Apr 14, 2009 | Refrigerators
Delfield ST4048 Logo
43 people viewed this question
Top Delfield Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Delfield Refrigerator Expert? Answer questions, earn points and help others
