Question about GPS
My 7.3 liter diesel cruise control and horn does not work are they hooked to the same fuse anr if so what panel is it
  • 8,197 Answers
May I get the make and model Of the vehicl to help you more
Posted on Nov 12, 2010
Where is fuse for cruise control?
Fuse #19 (15 amp) controls the cruise control. It also powers the horn so check your horn. If it works then check the cruise controls ground. If the fuse is good BUT the horn still doesn't work, then check the horn relay, as it also powers the cruise control. Check all wires/connections going to these parts also.
Feb 17, 2016 | 2002 Ford Taurus
My cruise control stoped working, my speedometer still works
cruise control have there own fuse check that ,make sure it is still hooked up to throttle ,check vacuum lines and power plugs , your speedo has nothing to do with cruise,also check that it is activated,test horn ,YES horn and cruise use same relay ,make sure your brake pedal is retracted ,and that brake lights work as well, good luck with it if I can be of further help get back to me ,hope I helped you.
Woody
Aug 27, 2014 | Cars & Trucks
My cruise control doesn't work??...any
jnjkingbird, It sounds like this problem is the clock spring as I don't believe that the horn and the cruise control would share a fuse. However, they do share a circuit in the clock-spring. You can check for power at each unit (horn and the cruise control) which would confirm this. Check each fuse as well. Good luck with this.
May 29, 2011 | 2002 Lincoln LS
2004 F250 diesel Cruise control and horn stopped working after horn started blowing by itself then it stopped by itself after several minutes and now the fuise blows when you hit the horn
Hi, assuming you have cruise controls on the steering wheel, I would say your clockspring has failed. The contacts for the horn must be crossed with the cruise contacts. Replacement requires removal of the steering wheel (special tool) and airbag, etc. Please let me know if you would like instructions.
May 20, 2011 | 2004 Ford F250
Horn fuse keep blowing.and cruse control not
most likely the clock spring needs to be replaced which is located in the steering column.
Jul 27, 2010 | 2004 Ford Excursion
Cruise control stopped working
Check the switch, located on the brake pedel the stop light switch and the cruise control switch are on the brake pedel towards firewall. The cruise control switch is plastic.
Mar 25, 2010 | 2001 Ford F350 Super Duty SuperCab
The horn on my Ford F350 7.3 diesel 4X4 crewcab sitting idle in the driveway started honking and would not stop until I removed the fuse. After I removed Fuse #37 for the horn I could not get the cruise...
WHEN THE HORN IS GOING OFF PUT A GROUND WIRE TO THE BODY OF THE HORN IF THIS STILL HAPPEN CHECK YOUR HORN SWITCH IN THE STEERING IT MAY BE STIKING OR THE WIRE MAY HAVE SHORTS
Sep 15, 2009 | 2002 Ford F150 Regular Cab
1988 Ford Crown Vic Lost Cruise Control
Although I don't think the cruise is an issue for safety, reach in under hood , or in grille area and find your horn(s) and just pull the connector off them temporarily, so they won't blow & put fuse back in and see if cruise starts to work again. It's not unusual for circuits to be labeled wrong or not at all in fuse panels. Then you can turn your attention to horn problem.
Jun 27, 2009 | 1988 Ford Crown Victoria
Horn and cruise control dont work, what to do?
for the horn could be the wires or try the fuse panel,because so much used of the horn the spring inside goes bad,check that too.and check fuse for the cruise control too,good luck
May 31, 2009 | 2001 Dodge Dakota
Fix this please
If your horn doesnt work either you have to remove the steering wheel and there is the connector for the horn/cruise control. If nothing broken there, check the clock spring too!
Apr 19, 2009 | 1988 Ford Crown Victoria
GPS Logo
14 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
