Question about Kitchen Ranges
I HAVE A GE MONGRAM COOKTOP MODEL#ZEU36ARSF255 SER# RL7106310. THE BIG BURNER ON THE LEFT SIDE WHEN FACING THE COOK TOP IS MALFUNCTIONING. WHEN YOU TURN IT ON,THE CONTROL NUMBERS TURN ON (THAT IS LOW - HIGH) BUT THE BURNER NEVER TURNS RED. AFTER ABOUT 20 SECONDS IT GIVE AN F116 ERROR CODE IN THE TIMER PANEL, AND STARTS TO BEEP. THE ONLY WAY TO SHUT IT OFF IS TO HIT THE LOCK BUTTON, AND IT SHUTS OFF. I TRIED DISCONNETING THE POWER BY SHUTTING OFF THE BREAKER AND TURNING IT BACK ON AFTER 15 MINUTES, AND THE PROBLEM PERSIST. IS THERE A QUICK FIX, OR DO I NEED TO CONTACT MY WARRANTY PEOPLE. PLEASE ADVISE. CLIVE@DSTMIA.COM CELL 305-796-4899 THANKS & REGARDS CLIVE
    Genius:
  • 3,422 Answers
I strongly recommend you to get it serviced as it is still under warranty.Another thing did you have a look into the user manual for troubleshooting the error codes?
If you need anymore help let me know.
Please don't forget to rate or accept the solution.
Posted on Jun 17, 2008
  • Kitchen Ranges Master
  • 1,879 Answers
WARRANTY PEOPLE is the best choice Sir, the burner needs replacement, since the other burners are working fine.
  • monk3ybidzness
    monk3ybidzness Jun 17, 2008
    800-444-1845 for "what does that error code means"
    Genius:
  • 1,036 Answers
If it is still under warranty, Then yes give the manufacturers a call. You may get it repaired free.
    Genius:
  • 2,028 Answers
Sounds like the burner control switch has malfunctioned. If it's still under warranty, go that route
GE Profile GSP40 cooktop hot burner indicator wont light up
This is obviously a loose connection in the panel that is flexed when you put pressure on the top. The rear panel needs to be opened and checked.
Jan 22, 2013 | Cameras
I want to lift the cook top on GE range jbp82shss so that I can clean out all the dust. can I do this
Yes. Disconnect power to range. Open oven door and remove hex head screws at front edge of cooktop from the bottom side. Lift up front of cooktop. Burner units can then be removed from the underside of the cooktop. Be careful not to damage the gray insulating material around the burner elements if you remove the elements from the cooktop glass.
Mar 05, 2011 | GE JBP82SHSS Electric Kitchen Range
Burner seems to be wired backwards
You have to access the underside of the cook top. Does the back right work correctly? If so switch the wires on the back left to match the right burner.
Jul 01, 2009 | Kitchen Ranges
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 | GE Cooktops
Electric Glass GE Profile Cooktop Burner popping
yes the knob is attached to a switch and the switch to the burner by way of wires..you can get into the cook top.but with your description of whats going on i would have the switch with me and then may only have too take apart once.there is a chance your burner is bad,but as you describe the way the switch is acting is seems pretty sure just the switch.you can order switch on line you need your model and ser#
Jan 30, 2009 | GE Profile JGP636 Gas Cooktop
GE cooktop has porceline "popping" off literally.
Porceline (a coating over metal in this case) is actually a type of glass, and subject to fracture upon sudden thermal shock or physical stress. The part you indicate is WB62T10124 for a JGB939C1WW probably a bit over $150 or a WB62T10132 for a JGP939C2WW, probably a bit over $100, but the labor to replace it would be costly. If you rate this, please remember I did not manufacture this product, nor am I a GE employee, so please don't shoot the messenger.
Nov 28, 2008 | GE Profile JGP636 Gas Cooktop
Burner cap
The cook top should be bolted to the counter. Look under and look for brackets that attach the bottom of the cooktop to the sides of the counter. and also the model number should be somewere underneath. If you can get me the Model number I can get you the maintenance manual in PDF format.
Eddie Rentas
Tupper Lake NY
Jul 24, 2008 | GE 30 in. JGP336 Gas Cooktop
We have a 5-burner GE cook top/ The igition for the center burner continually fires.
the spark modual is bad in the cooktop. you can just leve it unpluged and light with a match until you can get it replaced
Nov 22, 2007 | GE 36 in. Profile JGP962 Gas Cooktop
Kitchen Ranges Logo
85 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
